1 registered members (DWil23),
53
guests, and 11
spiders. |
Topics44,883
Posts759,586
Members8,323
Most Online1,033 Dec 28th, 2019
Re: Torque setting for spoked wheel nuts
[Re: Paul F]
#759631
29/10/22 07:18 AM
29/10/22 07:18 AM
Posts: 5,884 East Harling, Norfolk UK
It is very important not to over-tighten as the threads are easily damaged.
Particularly relevant for those with 2 metre long breaker bars and custom spinner removers!
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
[Re: RichardV6]
#759632
29/10/22 07:34 AM
29/10/22 07:34 AM
Posts: 2,055 Oxon
Craig Jezz
Oxon
Particularly relevant for those with 2 metre long breaker bars and custom spinner removers! My spinner tool & breaker bar is mainly used for undoing the spinners, the long bar isn’t necessarily used for tightening.
Craig Jezz
Morgan 4/4 Sports Sand
[Re: RichardV6]
#759640
29/10/22 08:33 AM
29/10/22 08:33 AM
Posts: 23,636 Suffolk, England
Brooklands Register contact
Suffolk, England
Particularly relevant for those with 2 metre long breaker bars and custom spinner removers! Mine is used to undo them Richard (see picture, made from Thule roof bar , Mulfab spanner & clips). ![[Linked Image]](https://www.tm-img.com/images/2021/04/21/20210421_171538.jpg) I have a hex nut socket on a short bar to fit them. I don't like swinging hammers next to the wings.
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
[Re: Paul F]
#759653
29/10/22 10:14 AM
29/10/22 10:14 AM
AndyMog57
Hi Paul,
I recall we discussed this back in May at the auto test. I have sourced a 70mm A/F socket (Facom) stocked by Machine Mart, which I am just off to buy now. My drive back from Oakmere on the 4th in torrential rain resulted in the Via Gellia road turning the inside of the wheels white (quarry slurry on the road), hence the need to remove the wheels and clean them properly. Only just walking again after the surgery so this is my first opportunity to address the issue.
I will call the factory technical department on Monday and try and get a definitive answer, which I will then post here. After a working lifetime in engineering, the thought of tightening something as critical as a wheel retaining nut 'hammer tight', frankly makes me shudder!
Thanks everyone for all the input, gratefully received and appreciated. For what it's worth, and based on experience, I suspect 110Nm is about right as all wheel nuts should self-tighten with driving. Of greater concern is getting the wheel nuts off without potentially adding the possibility of damaging bodywork when swinging a mallet.
KR, Andy
Andy 2022 Plus Four / San Marino Blue
[Re: John V6]
#759655
29/10/22 10:16 AM
29/10/22 10:16 AM
AndyMog57
I'm with you there, John. Hence the original question.
'Hammer tight' leads to visions of damaged bodywork!
[Re: AndyMog57]
#759668
29/10/22 11:36 AM
29/10/22 11:36 AM
Posts: 20,749 South Yorkshire
South Yorkshire
I carry the same tool as Jon in my Roadster. When I bought my Roadster, the front nearside nut had been overtightened. The symptoms were that it was tight all the way off, and could not be removed by hand, the spanner was needed all the way. I tested the nut on the rear, and it was fine, meaning that the damaged threads were on the hub.
When I upgraded the front brakes, I took the opportunity to replace that hub unit, which I did, and the nut now comes off by hand.
[Re: AndyMog57]
#759673
29/10/22 11:49 AM
29/10/22 11:49 AM
Suffolk, England
Yes I clean & redo the copper slip on the nut & rhe splines, BUT A WARNING THE SPLINES CAN BE RAZOR SHARP IF WORN.
My front nuts (ooh Matron) always seem more tight than the rears.
[Re: AndyMog57]
#759917
31/10/22 07:07 PM
31/10/22 07:07 PM
AndyMog57
As promised, I made a call to the factory this afternoon and spoke to one of the shop floor mechanics who deal with wheel fitment. And this is what he told me:
Put your supplied wheel nut spanner in a vice and bend it twice to introduce a crank at the nut end of the spanner. Grease the threads with copper slip before reassembly. Fit the retaining nut by hand and hand tighten. Tighten the nut with the spanner until no longer able to turn the spanner. Strike the spanner shank until a change in tone is audible. At this point, the nut is as tight as required .
I was informed that they have NEVER used torque wrenches for wheel nut fitment and use the ‘good old fashioned spanner and mallet method’.
So there we go, a typical ‘Morganism’! There we are, a proper noun develops to become a verb!
I will attempt to measure the torque whilst undoing all the wheel nuts and see if I can establish a mean torque level. Further reporting at a later date.
[Re: AndyMog57]
#759920
31/10/22 07:37 PM
31/10/22 07:37 PM
Posts: 1,500 Northern Germany
bmgermany
Northern Germany
I will attempt to measure the torque whilst undoing all the wheel nuts and see if I can establish a mean torque level. Further reporting at a later date. Unfortunately, this will not help, as the breakaway torque (I hope the translation is correct) is very high...
