4 members (BobtheTrain, teifistar, James B W, chanteclair), 162 guests, and 13 robots.
+8Rich 141
OZ 4/4 120
John V6 120
8,359 Registered Users
Dressing up for the Goodwood Revival Meeting
by Mkiss - 09/06/23 09:16 PM
Currency
by Dean-Royal - 09/06/23 10:10 AM
My new car arrived today
by John V6 - 08/06/23 10:02 PM
Is It Just Me???
by Dan_Lockwood - 08/06/23 09:28 PM
Side Wind Deflector Fitting 2004 on
by Mark666 - 08/06/23 05:50 PM
Used Stock Cams (S&S 548)
by IsleOfMog - 08/06/23 05:12 PM
Re-flashing or changing the chip
by LarryS - 08/06/23 04:57 PM
Head rest
Head rest
by JMcL, June 6
Spotted In Amboise Loire
by Clipper, May 28
Wiscombe Park
Wiscombe Park
by griffo, May 22
Forums32
Topics45,177
Posts765,172
Members8,359
Most Online1,033
Dec 28th, 2019
#762038 19/11/22 01:37 PM
Sensei Offline OP
Hi, preparing our 1973 +8 for the winter here in Scandinavia, I'm about to change the radiator anti-freeze coolant (yes, suitable for aluminium engines). By adding more of this stuff to protect down to some - 30 C, there is an enhanced risk of leaks. We have encountered leaks before, mainly at the bottom hose connection to the radiator. Currently I'm using two clips, which kind of cured the problem. Question is now if we should use a Radiator Sealant /Stop leak additive to prevent leaks? Would there be anything that talks against this? And is it a permanent fix? Thanks for your views and advise. Cheers /Finn
Finn. 1973 Morgan +8. 1959 Austin Healey 3000 BN7 2-seater. 2009 Mazda MX-5 2.0 PRHT.
I would advise against using sealants which could gum up some critical part.
When using two hose clips ensure the screw adjusters are 180° apart or nearly so.
Use a refractometer to measure actual freezing temperature of your coolant once circulated around engine. The one linked also measures battery electrolyte specific gravity.
2018 Roadster - Red/Magnolia - Morton
1966 Land Rover S2a 88 - Lenny
1945 Moto Guzzi Airone
K seal is the only one I recommend and use in the race cars
Getting a pinhole leak from track debris can really spoil your weekend
K seal stays liquid in the cooling system- until it finds a hole then it seals it
I know Lister Storm LeMans car qualified for the 24hr race using K seal to seal up a failing head gasket- which is a good enough recommendation for me!
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Another vote for K Seal too, all the breakdown callout lads who know their stuff carry it
+ yet another vote for K-seal smile
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
After a boil up in the queue for the Blackwall Tunnel one evening (almost 4 hours to do 1/2 mile!) I asked around what precautions to take before taking the car to Techniques for a proper inspection, and they recommended K-Seal very strongly.
Like Simon they use it in all their race prepared cars just as a precaution.
I take Richard's point about it being better without, but more modern formulations have largely ameliorated that one.
Andy G
1999 +8 , Indigo Blue.
I experienced a weeping gasket between the timing chain cover and the engine block but only after the engine cooled down. A TM expert recommend K-seal which did the trick and that was four years ago.
Dave
98 +8 Corsa Red
74 MGB Red
Sensei Offline OP
Both hoses have been changed to original OEM and the clamps have been changed to stainless solid types, not the flimsy wire type clamps. In the bottom I've installed 2 clamps. We didn't have a puddle of coolant under the car, but merely traces. The problem turned out not to be the radiator itself or the drain tap, but stems from the lower radiator spout not being 100% round any longer. As I've learned that cooling system sealant is used even on new cars, I have no problem using it. Just happy the problem has been solved. Thanks for your advise and inputs. Cheers
(Release build 20201027)
Responsive Width:
PHP: 7.4.33 Page Time: 0.060s Queries: 30 (0.014s) Memory: 2.9474 MB (Peak: 3.2550 MB) Data Comp: Off Server Time: 2023-06-10 08:45:20 UTC
Valid HTML 5 and Valid CSS
