9 registered members (Guten, Perry_P_M3W, John Winn, Tomhez, Montegue, TBM, DickJ, super3G, Ginmoggie),
88
guests, and 11
spiders. |
Topics44,604
Posts754,560
Members8,264
Most Online1,033 Dec 28th, 2019
New Car? Count the fault codes.
#762334
23/11/22 06:17 PM
23/11/22 06:17 PM
Posts: 20,673 South Yorkshire
South Yorkshire
Son in Laws parents recently got a new VW T Roc on lease. From day 1 it has thrown up multiple fault codes. An "engineer came out" and suggested that VW changed a control module, but the dealer still has the car, and can't find a problem. The VW dealer lent them Corsa. It's been going on over two weeks. Interestingly, a Nissan was in the news recently for the same problems. https://metro.co.uk/2022/11/16/kent-couples-new-33000-nissan-has-mind-of-its-own-17771863/
Re: New Car? Count the fault codes.
[Re: DaveW]
#762339
23/11/22 06:39 PM
23/11/22 06:39 PM
Posts: 5,655 People's Republic of South Yor...
I think I'll stick with cars that have the KISS principle for as long as I can, sadly tech is just too complex in new spec cars, lots of it we don't need but it's a fashion arms race between manufacturers nowadays so we're stuffed
[Re: DaveW]
#762341
23/11/22 06:40 PM
23/11/22 06:40 PM
South Yorkshire
Would it be too conspiracy theory to suggest the chip makers are supplying a few rogue chips?
[Re: DaveW]
#762349
23/11/22 08:38 PM
23/11/22 08:38 PM
Posts: 4,438 Costock, South Nottinghamshire...
Paul F
More likely to be fall-out from cheap connectors failing to make reliable contact at the low currents used for many signals in cars. Motor manufacturers are unlikely to add the cost required for better quality connectors or for electronic solutions. Wikipedia has a reasonable explanation of the concept.
[Re: Paul F]
#762352
23/11/22 09:13 PM
23/11/22 09:13 PM
Posts: 5,681 East Harling, Norfolk UK
More likely to be fall-out from cheap connectors failing to make reliable contact at the low currents used for many signals in cars. Motor manufacturers are unlikely to add the cost required for better quality connectors or for electronic solutions. Wikipedia has a reasonable explanation of the concept. Yep no doubt that's the reason, not helped by British weather either. The phenomena was highlighted on my narrowboat when I swapped out halogen ceiling lighting for LED. The household switches coped fine with the current draw from halogens but after fitting LED's and particularly after leaving boat for several weeks unused, many of the switches had to be operated several times to clear contact oxidisation and so have the lights come on reliably given the very low current draw.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
[Re: DaveW]
#762358
23/11/22 09:48 PM
23/11/22 09:48 PM
Posts: 6,406 Renfrewshire
BobtheTrain
Renfrewshire
When we used relays, we used to use 50V DC for point detection to ensure the points were in the correct position. When it was changed to electronic equipment, we use 6V pseudo random binary and quite often the contacts in the points wouldn't pass the current.
[Re: BobtheTrain]
#762370
24/11/22 06:40 AM
24/11/22 06:40 AM
Posts: 27,166 Cheltenham, Glos. UK
Part of the "leaves on the line" failure scenario Bob?
Graham (G4FUJ) D8921 L44FOR '93 4/4 Giallo Fly 2 seat  '90 LR 90 SW '09 Alfa Romeo MiTo
[Re: Graham, G4FUJ]
#762379
24/11/22 09:17 AM
24/11/22 09:17 AM
BobtheTrain
Renfrewshire
Part of the "leaves on the line" failure scenario Bob? No, a completely different fault. BtW - leaves on the line is a real fault, they can prevent the train from dropping the track circuit and the train disappears on the signaller's panel. They can also cause slipping when braking.
[Re: BobtheTrain]
#762390
24/11/22 11:07 AM
24/11/22 11:07 AM
Part of the "leaves on the line" failure scenario Bob? No, a completely different fault. BtW - leaves on the line is a real fault, they can prevent the train from dropping the track circuit and the train disappears on the signaller's panel. They can also cause slipping when braking.  Thanks.
