7 registered members (bmgermany, RichardV6, Grumpy2, TBM, nick w, RedThree, Dada),
142
guests, and 14
spiders. |
Topics44,894
Posts759,836
Members8,324
Most Online1,033 Dec 28th, 2019
MOT
#762955
01/12/22 10:21 AM
01/12/22 10:21 AM
Posts: 4,392 Essex
Burgundymog
Black Rat
Black Rat
Essex
Yesterday was MOT time for Ruby, I checked everything before leaving and had checked everything last week too. When the tester tried the brakes the brake lights didn't work, at this point somebody came in to speak to the tester and I jumped in the car and gave the brake pedal a good kicking and lo and behold they came on. The tester said ah probably needs a squirt of WD 40 so as they were now working all's well. I was also pleased that Cains LED headlights passed muster. So good for another year. When I got home i gave the button on the the brake light switch a good squirt with WD 40 and worked the switch in and out and touch wood (Ash) it will be ok now. It seems OK.
Re: MOT
[Re: Burgundymog]
#762960
01/12/22 11:03 AM
01/12/22 11:03 AM
Posts: 2,063 Oxon
Craig Jezz
Oxon
The exact same thing happened to me at the MOT this year. It will play up again in week or two mine did, so i bought a new one. The switch you need is 1212C it was only approx. £11.00 ![[Linked Image]](https://tm-img.com/images/2022/08/05/BCB0F7D4-DAB6-4976-BA0A-0E7DA1EDAA04.jpg)
Craig Jezz
Morgan 4/4 Sports Sand
Re: MOT
[Re: Craig Jezz]
#762962
01/12/22 11:20 AM
01/12/22 11:20 AM
Posts: 4,392 Essex
Burgundymog
Black Rat
Black Rat
Essex
Cheers Craig, where did you get it from ?
Re: MOT
[Re: Burgundymog]
#762963
01/12/22 11:29 AM
01/12/22 11:29 AM
Posts: 1,219 New Forest
Lordofthewings
New Forest
The original factory-fitted switch on mine had been hacked-about to get to the connectors, a real bodge. I got my replacement on Ebay although if they are out of stock Rutter's have them (more expensive...). It's one of those jobs that needs a universal joint on your neck, and probably better close-up eyesight than mine. ![[Linked Image]](https://www.tm-img.com/images/2022/12/01/Brake-pressure-switch-3-replacement.jpeg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Re: MOT
[Re: Luddite]
#762966
01/12/22 12:14 PM
01/12/22 12:14 PM
Posts: 1,361 North Somerset, UK
Deejay
North Somerset, UK
I think Heinz went through this a while back in a detailed post..?
I suspect the switch will come in two types, one with N,C. (Normally Closed) contacts, the other with N.O.( Normally Open) contacts, and depressing the switch button reverses the contacts from one to the other status... Yeah all a bit simple, but simple to buy the wrong switch too.... With the numbers posted hopefully that will be the correct type of switch for the brake light situation.
I think RS Components may have them in stock as the yellow label looks like one of theirs..? Yes, RS have them at only £5.89 inc vat. Stock no. 103-6252. Did a search on ebay but nothing found.
Doug
2011 +4 in Rich Maroon 1972 750 “ComDom” sprinter 1958 Triton 650 1992 Triumph Trophy 900
Re: MOT
[Re: Burgundymog]
#762971
01/12/22 12:23 PM
01/12/22 12:23 PM
Posts: 6,643 Köln Germany
Heinz
Köln Germany
That's right, George:)
The 1212 types are "normally closed" for the brake light (which means that the brake pedal keeps it open when not depressed and therefore no brake lights or in other words, when the brake pedal is not depressed then the switch is depressed and vice verse) The 1213 types are "normally open" needed for the ECU. Both switches are next to each other behind the brake pedal. It is also written above in the specs I linked in English.
Re: MOT
[Re: Burgundymog]
#762975
01/12/22 12:41 PM
01/12/22 12:41 PM
Heinz
Köln Germany
My detailed thread three years ago was about the 1213 switch for the ECU. Without +8Rich's advice, I would have continued to be blind and no idea about the switch existing. I had already changed the throttle, the MAF sensor, the ignition coils and the accelerator pedal😰😰😰 (ok, all to test with used parts, but I was desperate).... a whole year of unsuccessful trying in the dark and all without any hint from OBD2. My garage also had no clue. The car stalled out of the blue and wouldn't pick up the throttle. It turned out that switch 1213 had a loose contact. This switch activates another control programme as long as you brake.
Re: MOT
[Re: Burgundymog]
#762979
01/12/22 01:20 PM
01/12/22 01:20 PM
Posts: 4,523 Costock, South Nottinghamshire...
Paul F
I now have one of each kind of switch in my travelling spares cache. Having had the brake light switch become intermittent whilst 100 miles from home, I wouldn’t want to be stuck somewhere.
