0 registered members (),
142
guests, and 14
spiders. |
Topics44,601
Posts754,507
Members8,264
Most Online1,033 Dec 28th, 2019
Re: TDC and tappets
[Re: Image]
#763006
01/12/22 07:13 PM
01/12/22 07:13 PM
Posts: 23,408 Suffolk, England
Brooklands Register contact
Suffolk, England
Can't you get a top dead centre tool? It is a rod that has graduations markings so you can see tdc therefore degrees before and after. Mind you if it runs it might be better to stay way
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: TDC and tappets
[Re: Image]
#763025
01/12/22 08:38 PM
01/12/22 08:38 PM
Posts: 1,328 North Somerset, UK
Deejay
North Somerset, UK
On a 4 cylinder engine, simply use the “rule of 9” You don't need to find T.D.C. but, just view the valves when fully opened as you rotate the crankshaft. Numbering the valves from the front of the engine from 1 to 8: With number 8 fully open, adjust the gap on number 1 7 open, adjust 2 6 open adjust 3…etc . i.e. always add up to 9 Of course, to save lots of engine turning, you don't need to do them in strict numerical order…as you rotate, simply spot the valve that is fully open and then adjust the one in a position that adds up to 9.
Doug
2011 +4 in Rich Maroon 1972 750 “ComDom” sprinter 1958 Triton 650 1992 Triumph Trophy 900
Re: TDC and tappets
[Re: Image]
#763035
01/12/22 09:34 PM
01/12/22 09:34 PM
Suffolk, England
I missed the diesel bit. Sorry
Re: TDC and tappets
[Re: Image]
#763041
01/12/22 10:25 PM
01/12/22 10:25 PM
Deejay
North Somerset, UK
As it’s a triple, then it will most likely have a 120 degree crank, so think it best to follow the manual. If you cannot get to see timing marks, then the only sure way is to use a rod inserted to rest on the piston top as discussed earlier. However, my other concern is how you intend to “inch” the engine. My experience of long ago in attempting to do that using the starter is extremely hit and miss…more often than not: miss! A spanner on the crank is best or alternatively rocking it in gear, but that may not be practicable with the weight of the digger. So failing all that, my thoughts return to your original thoughts. If you set them when they show maximum slack then it should be fine, but as said, the big issue is being able to inch it gradually. If you cant get to the crank, might it be possible to get a spanner on the alternator or fan pulley, as long as glow plugs are removed to release compression of course. Alternatively, there’s the old adage: if it ain’t broke, don’t fix it! Good luck.
Doug
Re: TDC and tappets
[Re: Image]
#763050
02/12/22 06:43 AM
02/12/22 06:43 AM
Posts: 27,162 Cheltenham, Glos. UK
Good luck with removing heater plugs - if they haven't been moved in a long time...
Graham (G4FUJ) D8921 L44FOR '93 4/4 Giallo Fly 2 seat  '90 LR 90 SW '09 Alfa Romeo MiTo
Re: TDC and tappets
[Re: Image]
#763052
02/12/22 08:06 AM
02/12/22 08:06 AM
Posts: 5,677 East Harling, Norfolk UK
I would just find valve fully open position visually then turn crank 360° (assuming you can) and adjust. This works for any four stroke engine and you can be assured you are adjusting on base circle of cam.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
