2 registered members (westgardronning, Taffmog), 107 guests, and 10 spiders.
+8Rich 220
John V6 135
RichardV6 114
CooperMan 112
OZ 4/4 94
Wheelybin, Bonnie66, RichT56, Morgandave, Ulas A White
8323 Registered Users
Cracking 4/4 Sport for sale
by +8Rich. 29/03/23 09:40 PM
ARP4 video
by Lordofthewings. 29/03/23 02:38 PM
Snow worries..
by +8Rich. 29/03/23 02:28 PM
Morgan EV3
by Lordofthewings. 29/03/23 01:58 PM
What is under this?
by Topline123. 29/03/23 12:35 PM
2013 Plus 8 Relays and Fuses
by ADC. 29/03/23 10:43 AM
Introduction plus Goodwood accommodation
by Bishmog. 28/03/23 10:39 PM
M3W season '23 started! (@ 7 °C), 12.02.2023
Rat Rod style Threewheeler
Bimble to the New Forest
Brum by the sea
LM62
Topics44,883
Posts759,578
Members8,323
Most Online1,033
Dec 28th, 2019
PhilRoyle
Page 14 of 16 1 2 12 13 14 15 16
Re: My23 brakes [Re: Derek596] #767343
20/01/23 06:33 PM
20/01/23 06:33 PM
Black Forest Germany
CLPlusFour Offline
CLPlusFour  Offline
Sorry I'm only today come to look at the brakes more closelyIn my PlusFour model year 2022 it is a single-piston brake.
The manufacturer can not be identified
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #767346
20/01/23 06:51 PM
20/01/23 06:51 PM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
And the sliding mechanism isn’t protected by a rubber covering as most cars are, they’re open to the elements and if not used often enough they will seize up.
Heron Grey Plus Four 2021
Previous:-
Connaught Green 4/4 1988
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #767381
21/01/23 01:47 PM
21/01/23 01:47 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
Is that not a dual piston? One piston either side of the disc.
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: My23 brakes [Re: TBM] #767382
21/01/23 01:53 PM
21/01/23 01:53 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
No signs of a hydraulic line connecting across to the other side?
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: My23 brakes [Re: Deejay] #767384
21/01/23 02:00 PM
21/01/23 02:00 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
It'll travel through the body of the caliper - with a single pot, the caliper usually slides in a carrier, on dual pots the pads slide on pins.
Re: My23 brakes [Re: Derek596] #767385
21/01/23 02:12 PM
21/01/23 02:12 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
My 1972 had dual pots with no connecting line.
Same with the uprated 4 pots, no line
Re: My23 brakes [Re: Derek596] #767389
21/01/23 03:01 PM
21/01/23 03:01 PM
CLPlusFour Offline
CLPlusFour  Offline
It's not easy to photograph this... played with the brightness again.
I only see a piston on the inner side where the vent is placed.
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #767390
21/01/23 03:24 PM
21/01/23 03:24 PM
Chester
Mikemog6 Offline
Mikemog6  Offline
Chester
If you take the pads out you will eliminate the guess work and know for sure, looks easy enough.
Previous Mog Plus 4 Fiat Twin Cam.
Plus Six
Re: My23 brakes [Re: Derek596] #767393
21/01/23 03:40 PM
21/01/23 03:40 PM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
As I’ve said before, it’s a single piston.
Previous:-
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #767395
21/01/23 03:51 PM
21/01/23 03:51 PM
Luddite Offline
Luddite  Offline
Thanks for posting the pic Clemens.
Unfortunately the mechanism that allows the calliper to slide back and forth as the brakes are applied and released is not obvious from the angle you took the pic from.
