1 registered members (DWil23), 53 guests, and 11 spiders.
+8Rich 220
John V6 135
RichardV6 114
CooperMan 112
OZ 4/4 102
Wheelybin, Bonnie66, RichT56, Morgandave, Ulas A White
8323 Registered Users
Cracking 4/4 Sport for sale
by +8Rich. 29/03/23 09:40 PM
ARP4 video
by Lordofthewings. 29/03/23 02:38 PM
Snow worries..
by +8Rich. 29/03/23 02:28 PM
Morgan EV3
by Lordofthewings. 29/03/23 01:58 PM
What is under this?
by Topline123. 29/03/23 12:35 PM
2013 Plus 8 Relays and Fuses
by ADC. 29/03/23 10:43 AM
Introduction plus Goodwood accommodation
by Bishmog. 28/03/23 10:39 PM
M3W season '23 started! (@ 7 °C), 12.02.2023
Rat Rod style Threewheeler
Bimble to the New Forest
Brum by the sea
LM62
Topics44,883
Posts759,586
Members8,323
Most Online1,033
Dec 28th, 2019
PhilRoyle
Page 1 of 16 1 2 3 15 16
My23 brakes #764942
20/12/22 06:23 PM
20/12/22 06:23 PM
Derek596 Offline OP
Derek596  Offline OP
I understand that the MY23 has better brakes. I wonder how much better and could we retrofit. If you, I wonder how for how much.
Re: My23 brakes [Re: Derek596] #765202
22/12/22 09:36 PM
22/12/22 09:36 PM
Stonehaven, Scotland
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
Hi, I’ve asked my dealer for a quote. They have requested the details from the factory. Planning to drive the 2023 demonstrator when it arrives to confirm it’s a worthwhile improvement. It will be interesting to hear how much the upgrade is.
Re: My23 brakes [Re: Derek596] #765341
24/12/22 09:20 AM
24/12/22 09:20 AM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
I’ve been informed by the factory that it’s not possible to upgrade, as many other things have changed including the radiator.
Heron Grey Plus Four 2021
Previous:-
Connaught Green 4/4 1988
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #765351
24/12/22 10:29 AM
24/12/22 10:29 AM
MikeFromPembroke Offline
I get the feeling that any improvements made to new CX cars will not be made available to upgrade older versions. That was the case with the exhaust anyhow.
Mike
1982 4/4
2004 Roadster S1
2010 Roadster S2
2021 Plus 6
Re: My23 brakes [Re: p8mog] #765364
24/12/22 12:34 PM
24/12/22 12:34 PM
West Somerset
Davetherave Offline
Davetherave  Offline
West Somerset
Our 2020 Plus Six has just had a radiator change. The dealer informed us it is the latest design. Now its possible that is different again to the MY2023 cars.
Dave
Plus 6 "Squeak"
Roadster departed.
Re: My23 brakes [Re: Derek596] #765389
24/12/22 03:53 PM
24/12/22 03:53 PM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
Ah well, looking like I will have to take a different route then.
To me, once the suspension was sorted out (via SSL) the weak link was the brakes. They improved once the recall work was completed (perhaps I had failing seals ?) but are still not good enough in both feel and performance.
I will upgrade the brakes as I don’t want a 2023 with all of the added paraphernalia.
Re: My23 brakes [Re: Ian Hubbard] #765414
24/12/22 10:57 PM
24/12/22 10:57 PM
Essex
Storvite Offline
Storvite  Offline
Essex
The brakes are not great, my aero 8 brakes are far superior, surely there are some performance pads that can be fitted?
Re: My23 brakes [Re: Derek596] #765428
25/12/22 06:43 AM
25/12/22 06:43 AM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
Certainly worth a try and will be step 1, but will be surprised if it works. Let’s hope I’m wrong 😀
Re: My23 brakes [Re: Derek596] #765431
25/12/22 07:34 AM
25/12/22 07:34 AM
Katikati NEW ZEALAND
NZPlusSix Offline
NZPlusSix  Offline
Hi
Our 2019 Launch Edition Plus Six has had a replacement master cylinder and a brake booster unit. And YES our master cylinder seals had failed. However while the Plus Six is a vast improvement on earlier Morgans the brakes were scary from Day One.
After the work done under warranty, the brakes, and in particular the brake pedal travel (60mm on average) was the same as before all the work. Presently the car is in the NZ Morgan dealer's workshop where it will stay until we get to the bottom of this brake problem. There will be a solution!
If MMC have managed to improve the brakes on the Y23 CX cars they surely will know what they have changed. Maybe it may not be possible, or desirable, for MMC to rectify the brake problem on earlier cars but that knowledge should be made available to all owners. I suspect that the problem could well be a mechanical and involve changing the brake pedal lever arm, hinge points etc.
The brake problem is in the same basket as the sagging suspension where the quality of the springs was the source of the problem. YES we have replaced our coil over damper units with those specified by SSL. Not only do we have the original ground clearance but we have greatly improved handling. BUT have MMC acknowledged that there was a problem? NO! Will MMC accept that the Plus Six brakes were faulty beyond the master cylinder problem? Not on your Nelly!!
Kerry
2019 First Edition Plus Six Moonstone Blue
Prev
2017 Plus 4 Auto Ivory
2011 4/4 Grey
1939 4-4 Blue
Re: My23 brakes [Re: Derek596] #765443
25/12/22 12:16 PM
25/12/22 12:16 PM
Luddite Offline
Luddite  Offline
While discussing brakes.... as they are such a new invention it is so simple to just get it wrong...!
For sure the name of the game in industry for quite some time seems to have focussed on cost cutting as opposed to improving quality of componentry, which I suppose is standard thinking for an old and somewhat selective Luddite..?
I tripped over this brake fluid vid which explains is reasonable detail the variations in brake fluid and the ways in which different fluids can affect system components so thought it was perhaps worth posting..?
https://youtu.be/M6UrH_mDBrU
My Mog is a mid 80`s Trad, has no ABS and after restoration circa 20 years ago, had DOT 5 brake fluid used in it`s system, which was fully rebuilt at the time... DOT five can not be mixed with any other brake fluids. which you will know if you watched the vid.
Re: My23 brakes [Re: NZPlusSix] #765457
25/12/22 06:07 PM
25/12/22 06:07 PM
Australia - NSW North Coast
OZ 4/4 Offline
OZ 4/4  Offline
Originally Posted by NZPlusSix
Hi
Kerry
Frustrating and a long-term blight on the vehicle and the brand....
Re: My23 brakes [Re: Derek596] #765458
25/12/22 06:10 PM
25/12/22 06:10 PM
NZPlusSix Offline
NZPlusSix  Offline
Hi Ian
Luddite could be right in that brake fluid could be part of the problem, and YES you should get your brake fluid tested for water and replaced when required. We have already done the twice in the Plus Six.
However there is nothing in your car's brake system that cannot be retro-fitted. The brake system is simply an collection of components that starts with the brake pedal and ends with the pad gripping the rotor. To rectify the situation short of ripping the whole system out you need a brake expert with considerable experience. As with your suspension problem you went to suspension design engineers, in our case Peter and Dan at SSL. You didn't just replace the springs or the dampers, but you fitted a purpose designed system. With your brake system it is not an simple as just replacing four complete assemblies. We may well have more than one simple problem so you/we will need to work through the whole system. YES starting at the end of the system by replacing the brake pads may well be a logic, simple and relatively cheap point. And yes you may well effect some improvement.
It's worth a CRACK!!
Kerry
Prev
2011 4/4 Grey
1939 4-4 Blue
Re: My23 brakes [Re: Derek596] #765464
25/12/22 06:56 PM
25/12/22 06:56 PM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
Hi Kerry,
New pads and brake fluid replacement it is then. As you say, it’s the logical thing to do and the cheapest option. Car currently in winter storage so won’t be done until April.
Hope you get your issues resolved. It does sound as though they are more significant than mine. In some respects I think I’ve been spoilt having driven Lotus for 15 years and they all had brilliant brakes I.e. Elise, Evora and Exiges. I am just trying to get a similar feel and performance.
Please keep us posted.
Cheers
Ian
Re: My23 brakes [Re: Derek596] #765486
25/12/22 11:51 PM
25/12/22 11:51 PM
I
IcePack Offline
IcePack  Offline
I
NZplus six. Yes brakes are brakes & agree this can be sorted. My 4/4 has a completely different system but exhibited similar symptoms re brake travel. It transpired that somehow race spec rear shoes had been fitted. Also the auto adjusters were badly set up. Hence the peddle travel was caused by having to expand the shoes & then not a lot of friction as normal driving, does not really heat up the rears.
How all this came about is still a mystery as I have the invoices for standard shoes not race spec.
Anyway it was all sorted free of charge by the garage owner. Really interesting in how quickly he disassembled & rebuilt the rear brakes, without removing the hubs. But they do support some well known race teams.
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: My23 brakes [Re: Derek596] #765701
28/12/22 07:37 PM
28/12/22 07:37 PM
Barry M Offline
Barry M  Offline
Iain Litchfield is the man to talk. to re. brake/suspension upgrades for the CX range.. He did the development work for Morgan on the earlier CXs and had a package that transformed the cars. However Morgan did not follow through with it as it was too expensive for them, so they cobbled their own solution together and the result was a recall for brakes and numerous reports of saggy springs and dodgy ground clearance.
I do know that Litchfield developed springs and dampers for the CXs with Nitron and much R&D went into the Nitron package. I believe the brakes Litchfield used for the package were AP Racing but I don't know any more details. Needless to say, Litchfield is not very happy with the way Morgan treated them. but you can go to them and have all or part of the package retrofitted to your CX. This is what I am doing the early part of next year.
If you don't know who Iain Litchfield is, look him up, he has quite some resume and Litchfield Motors is a stone's throw away from the Malvern Works.
Re: My23 brakes [Re: Derek596] #765705
28/12/22 08:45 PM
28/12/22 08:45 PM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
Same Litchfield that did all the Japanese import stuff when 22B and GTR was all the rage.
I did not realise that they were so close.
Re: My23 brakes [Re: Alistair] #765708
28/12/22 09:18 PM
28/12/22 09:18 PM
People's Republic of South Yor...
CooperMan Offline
CooperMan  Offline
Did they develop the 'Godzilla' GTR ? I know the Litchfield name from somewhere...
Re: My23 brakes [Re: Derek596] #765715
28/12/22 10:05 PM
28/12/22 10:05 PM
Barry M Offline
Barry M  Offline
He is probably the best known BMW tuner in the country and yes he did the GTRs and Supras etc, etc, but his workshop was full of Ferraris, Lambos and McLarens when I was there a couple of weeks ago most being race prepared. There was also a Porsche that had been so modded that I couldn't work out what it was (and forgot to ask).
He is a guru and has been in the top tier for many years.
Morgan were shortsighted (mad) not using the package he developed, as the recall must have cost them far more £££ than the extra cost of the Litchfield package over their failed solution.
Typical Morgan mentality...
Re: My23 brakes [Re: Derek596] #765723
29/12/22 12:20 AM
29/12/22 12:20 AM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
ThAnks for sharing. I will contact Lichfield in the new year.. 👍👍👍
Re: My23 brakes [Re: Derek596] #765733
29/12/22 08:29 AM
29/12/22 08:29 AM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
Let us know how you get on, if all goes well there could be a long queue, me for one.
Previous:-
Black Plus 8 1998
Re: My23 brakes [Re: p8mog] #765753
29/12/22 11:05 AM
29/12/22 11:05 AM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
So much for the new year.............I couldn't wait. Phoned this morning and spoke to Tom in service. He was really helpful and would be happy to answer any other questions from forum members.
As already shared they did some work earlier for MMC and the brake upgrade consisted of PAGID RS29 front brake pads and higher grade brake fluid. Prices £526 and £200, respectively (inc. VAT). You could save a little on the brake fluid by not going for the racing fluid. Tom indicated the major improvement came from the pads and not the brake fluid change.
We also discussed engines and he shared that they did a 420hp PlusSix upgrade last week, £600 (inc. VAT).
The lead time they need is circa 4-6 weeks notice.
All in all, to say I am interested, is an understatement. I suspect we will be visiting Lichfield Motors and MMC in July.
Thanks to Barry M for the initial Lichfield Motors info.
Re: My23 brakes [Re: Ian Hubbard] #765754
29/12/22 11:13 AM
29/12/22 11:13 AM
Lampeter, Wales
Jon G4LJW Offline
Jon G4LJW  Offline
Lampeter, Wales
Good to know. Thanks for posting this info!
Re: My23 brakes [Re: Derek596] #765755
29/12/22 11:14 AM
29/12/22 11:14 AM
Brake upgrade sounds interesting, but I ain’t brave enough to go for any power upgrade…..
Mike
1982 4/4
2004 Roadster S1
2010 Roadster S2
2021 Plus 6
Re: My23 brakes [Re: Derek596] #765765
29/12/22 12:26 PM
29/12/22 12:26 PM
Barry M Offline
Barry M  Offline
The 420hp power upgrade last week was me, The extra power is nice (of course) but the tune was mainly to alter the "Snappy" torque created by the Morgan map. By moving the torque curve much farther down the rev range, the car is now a delight and the power is much more progressive and most importantly, much easier and more predictable to drive - how it should have been in the first place!
Re: My23 brakes [Re: Derek596] #765767
29/12/22 12:35 PM
29/12/22 12:35 PM
Hi Barry, thanks for the information, I’ll never say never….be interested in you thoughts after living with it for a while.
Mike
1982 4/4
2004 Roadster S1
2010 Roadster S2
2021 Plus 6
Re: My23 brakes [Re: Derek596] #765768
29/12/22 12:52 PM
29/12/22 12:52 PM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
Ah, I was wondering if it was you.
The power upgrade sounds sublime. I will have to get it now. For £600 it is a 'no brainer'.
How have your insurance company been with the power upgrade? Did it impact the premium much?
Re: My23 brakes [Re: Derek596] #765769
29/12/22 12:53 PM
29/12/22 12:53 PM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
sorry, responding to Barry M
Re: My23 brakes [Re: Derek596] #765771
29/12/22 12:57 PM
29/12/22 12:57 PM
Barry M Offline
Barry M  Offline
Ian
I would rather not answer the insurance question :-)
Re: My23 brakes [Re: Derek596] #765773
29/12/22 02:10 PM
29/12/22 02:10 PM
France, Dunkerque
gaston Offline
gaston  Offline
France, Dunkerque
I work in the field of damaged cars in France. I can guarantee you that there will never be anyone who will dig into your electronic box.If you wanted to, do it and don't tell your insurer. You risk nothing.
Re: My23 brakes [Re: Derek596] #765798
29/12/22 04:53 PM
29/12/22 04:53 PM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
I am too honest, I declare everything. Currently with LV, declared when fitted sports exhaust and SSL suspension and it was £50extra/mod. Suspect 420bhp will take it outside of LV underwriting and I will have to go to a specialist.
Re: My23 brakes [Re: Derek596] #765812
29/12/22 07:31 PM
29/12/22 07:31 PM
Hampshire
Alistair Offline
Alistair  Offline
Hampshire
Don't forget it is not a Morgan map, it is a crate engine from BMW and is optimised to deliver low emissions during the WLTP cycle. I always say a new engine map is not just for power but also for tractability.
Re: My23 brakes [Re: Derek596] #765820
29/12/22 10:09 PM
29/12/22 10:09 PM
Barry M Offline
Barry M  Offline
I am not sure that is true, as the Supra map is not the same as Morgan's, presumably to account for extra weight. It may be remapped by Toyota before sale, but it is not the same map. The Z4 may have yet another map, I don't know.
They will all be mapped to comply with specified emissions parameters, but I am fairly sure there is a degreee of customisation involved.
Re: My23 brakes [Re: Derek596] #765877
30/12/22 05:35 PM
30/12/22 05:35 PM
NZPlusSix Offline
NZPlusSix  Offline
This thread is drifting into the matter of re-mapping the engine computer. A good topic and certainly worthwhile to explore. Strangely I find our Plus Six very docile to drive round town and the power band great but you never know what a bit of fine tuning will do. You/I don't know what changes MMC made during the production un. I do know that you cannot go in to the car computer with Toyota software - we have tried! You need to have a Morgan version.
Ian - more to the point YES change the brake pads, and while the brake fluid change may not make a big difference, change it as the brake fluid, as in our case, had picked up too much moisture and that affects hot operation.
The only question is, "Are you going to keep us waiting until July to find out if it has worked?"
Prev
2011 4/4 Grey
1939 4-4 Blue
Re: My23 brakes [Re: Derek596] #765880
30/12/22 06:00 PM
30/12/22 06:00 PM
Barry M Offline
Barry M  Offline
Our Plus six was unpredictable when you put your foot down to overtake in auto or sports mode. It would sometimes drop a couple of gears and you would find yourself at high revs with rear wheels spinning up. This didn't happen in manual of course, but the original map made the car a bit of a baby at low revs and the turbo didn't get going until higher revs were reached. There was no lag to speak of but the boost was too low for too long if that makes sense. This led to the snappy torque that is so talked about within the B58 community.
I apologise for the thread drift.
Re: My23 brakes [Re: Derek596] #765882
30/12/22 06:06 PM
30/12/22 06:06 PM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
I’ve been thinking the same….,,,,,,,i will do the brakes April but will have to wait until July for the remap.😀😀👍👍
Re: My23 brakes [Re: Derek596] #765883
30/12/22 06:08 PM
30/12/22 06:08 PM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
Sorry reply was to NZPlusSix
Re: My23 brakes [Re: Derek596] #765902
31/12/22 01:28 AM
31/12/22 01:28 AM
NZPlusSix Offline
NZPlusSix  Offline
Barry - it sounds like your engine management computer was way out of line and you were right to get it re-mapped. As I have said our Plus Six is great in every respect when accelerating, cruising, overtaking etc.
BUT when it comes to stopping then that is another story! The car is presently at the Morgan agents to be worked on until we have better brakes. In their defense I must say that they have loaned us a near new Mazda CX-5 SUV - all the bells and whistles including "self-steering"!
I would most certainly like to hear from other Plus Six owners as to their brakes and even better those who have made real improvements. The number One thing I'm trying to improve is a reduction in brake pedal travel from the 60mm I presently have. Ever other car I have have excellent brakes - the Jaguar E-Pace brakes are almost too severe.
Prev
2011 4/4 Grey
1939 4-4 Blue
Re: My23 brakes [Re: Derek596] #765913
31/12/22 11:22 AM
31/12/22 11:22 AM
Barry M Offline
Barry M  Offline
We have factory brakes on our Plus Six and they have no discernible issues and have good feel. Interestingly, Morgan confessed to us that they had no idea why the brakes were so much better than the ones on the demonstrator, but it had been noted by several Morgan staff who had driven it. There is no excess pedal travel and stopping is progressive and predictable. Litchfield also commented on how much better they are than they expected.
I have a feeling that the pads are not the standard pads, as the car was a development car before we bought it from the factory, but I haven't had them out to check. This may not be the whole story though and as I say, no-one at the Morgan Works had any explanation.
I will still fit the Litchfield upgrade later this year, but our car's brakes seem to be a bit of a "happy accident".
Re: My23 brakes [Re: Derek596] #765923
31/12/22 01:10 PM
31/12/22 01:10 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
Barry, it would be helpful to compare your brake system at any point with a normal so so one.
Re: My23 brakes [Re: NZPlusSix] #765932
31/12/22 02:41 PM
31/12/22 02:41 PM
West Somerset
Davetherave Offline
Davetherave  Offline
West Somerset
Our 2020 Plus Six came with a fairly wooden feel to the brakes from new.. After the general recall M/Cylinder replacement the brakes "feel" seemed slightly better, but not by a huge margin. The pedal travel still seemed long though. The car then had to go back shortly after the M/Cylinder replacement for another issue and I mentioned the brakes again to the dealer, who undertook further work on them.. I do not know what was done, but the brakes now feel better again, plus there is slightly reduced pedal travel. I suspect the brakes were re-bled, from my own experience with ABS on motorcycles it can be tricky to completely purge the system of all air, even with a purpose designed bleeding system. I had a BMW K1200RS which took me two days to get the air completely out of the ABS pump.
Dave
Plus 6 "Squeak"
Roadster departed.
Re: My23 brakes [Re: Derek596] #765933
31/12/22 03:03 PM
31/12/22 03:03 PM
France, Dunkerque
gaston Offline
gaston  Offline
France, Dunkerque
I bled my brakes a month and a few hundred kilometers after changing the master cylinder. Now it's perfect and I no longer have the feeling of having a sponge under my feet.
Re: My23 brakes [Re: Derek596] #765934
31/12/22 03:18 PM
31/12/22 03:18 PM
Luddite Offline
Luddite  Offline
I am no expert on anything let alone brakes.. and always happy to be corrected if I am wrong.
Were I suffering poor brakes I might be inclined to crawl underneath and use brake hose clamps to close all the flexible lines and then check pedal travel. The idea of locking them all off is to test all of the kit involved in creating and initially distributing pressure to the system, such as servo ABS etc. Neither the servo or the abs system will operate without the engine running, though brakes should still operate with a dead engine and no ignition, just that it takes more pedal pressure to gain a "reasonable" braking.
Pedal travel with all flexible hoses locked off/clamped should be as good as it ever could be.... With possible issues and the cap removed from the fluid reservoir I would be looking for either signs of bubbles of fluid flow within the reservoir indicating possible master cylinder seal failure allowing fluid or air to escape back past the seal into the reservoir..
By releasing the clamps and comparing pedal travel on each individual brake drum/disc set-up it should be possible to detect if there might be an issue affecting one brake more than the others.
Logic dictates that if brake shoes are not correctly adjusted it can require more pedal travel/fluid displacement to bring the shoes into contact with the drums to them create the braking effect
With discs there is no adjustment to go wrong, however on poorly maintained brakes I have seen seized pistons in a calliper that stop one side of the caliper pushing it`s piston out and the pad being unable to move. in this situation it is possible that the piston(s) on the opposite side of the calliper do operate normally when the pedal is pressed forcing the pad to contact the disc which in turn forces the disc to flex to the extent that it is forced over to make contact with the seized pad on the other side of the calliper.. The effect of this feels not a lot different in relation to pedal pressure and the amount of spring normally associated with applying the brakes, however the brakes are less efficient when out on the road.
Mixing fluid types or thewrong type of fluid can cause all sorts of issues for seals, ABS etc....
Re: My23 brakes [Re: Derek596] #765935
31/12/22 03:42 PM
31/12/22 03:42 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
Reading your post, George, I would also think that a brake system is not witchcraft.
Re: My23 brakes [Re: Derek596] #765955
31/12/22 10:09 PM
31/12/22 10:09 PM
Luddite Offline
Luddite  Offline
It is good to know that I am not totally waisting my time typing and that on occasion someone might read any one of my rambles...Thanks Heinz..
Re: My23 brakes [Re: Derek596] #765967
01/01/23 06:52 AM
01/01/23 06:52 AM
NZPlusSix Offline
NZPlusSix  Offline
I think Barry, or rather Barry's Plus Six holds the key to solving our brake problems. As we now have replacement brake master cylinders and brake booster units we must now look at the brake pads and/or the brake calipers. My guess is the Barry's development car has different brake pads fitted.
What is disappointing is that once MMC realized that the brakes on the development car were superior to their demonstrator that they did not ask WHY? Instead MMC have their dealers and clients all "chasing their tails" to get to the bottom of this problem.
Regards
Kerry
Prev
2011 4/4 Grey
1939 4-4 Blue
Re: My23 brakes [Re: NZPlusSix] #765971
01/01/23 08:30 AM
01/01/23 08:30 AM
Bergisches Land (near Cologne)
Jens Offline
Jens  Offline
Bad when you have to say that after buying a new £100,000+, 335 hp sports car... frown2
2003 Morgan 4/4 2-seater
Re: My23 brakes [Re: Derek596] #765973
01/01/23 09:06 AM
01/01/23 09:06 AM
NZPlusSix Offline
NZPlusSix  Offline
Fortunately we have an excellent Morgan agent in New Zealand, Pearce Bros., and they are determined to put the brakes right under warranty.
Don't get me wrong this is by far the best Morgan I have purchased, but like the first of any new model car there can be teething problems. I would just like to good brakes to stop the car!!
Regards Kerry
Prev
2011 4/4 Grey
1939 4-4 Blue
Re: My23 brakes [Re: Derek596] #765977
01/01/23 10:32 AM
01/01/23 10:32 AM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
The Plus Four only has a front single pot calliper!
Previous:-
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #765984
01/01/23 11:15 AM
01/01/23 11:15 AM
Black Forest Germany
CLPlusFour Offline
CLPlusFour  Offline
Are you satisfied with the brakes on your PlusFour in terms of pedal travel and braking performance p8mog ?
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: p8mog] #765989
01/01/23 11:58 AM
01/01/23 11:58 AM
Luddite Offline
Luddite  Offline
Thanks for the heads up on the Plus Four having only a single pot calliper p8mog thumbs
Even in such a situation it is possible that the disc can be deflected under braking in a situation where the rails on which the pad travels to meet the disc become seized with corrosion, which seems unlikely to play any part in the case of any reasonably well maintained Morgan.. ?
Re: My23 brakes [Re: Derek596] #765992
01/01/23 12:18 PM
01/01/23 12:18 PM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
NO, The brake pedal drops about 2” on startup even after the master cylinder upgrade, thank god it’s an auto as the handbrake is a joke. But I can’t justify spending 30 grand plus on exchanging it for a MK23 model. Someone somewhere must be able to come up with a suitable alternative.
I did a small experiment, I put a small scratch on the inner and outer of the rotor, it took over 2000 miles to remove the mark on the outer and over 3000 on the inner.
The trouble is in my opinion is , the pads are to hard and the sliding mechanism isn’t covered it’s open to the elements and if left standing for a while will seize.
Previous:-
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #766086
02/01/23 10:44 AM
02/01/23 10:44 AM
Luddite Offline
Luddite  Offline
All this chat on brake issues caused me to try to update my limited knowledge on brake systems.... Jeez the extra degree of complexity and no doubt cost to make it safer for the brain dead to pilot vehicles on the road is somewhat astounding... For sure the days of DIY are all but done and dusted for owners of modern vehicles, except for those with a real determination and ability to get in amongst their machinery...
I have no idea of the master cylinder type fitted to the Mogs with issues, but it seems some units have an electric motor driving a hydraulic pump which pressurises a ECU controlled multi valve unit dependant on read back from wheel speed sensors.... Seems the KISS principal has long since been binned..!
https://youtu.be/RfAzB_IcWuk
p8mog, on the assumption that you have your foot on the brake pedal, it is interesting the distance that your pedal drops on engine startup, though not unusual on old style servo assisted systems which multiplied pressure applied to the brake pedal by utilising vacuum derived from the inlet manifold. I guess if there is an electric pump and ABS system it may not be unusual that something similar occurs on your Morgan..?
Also interesting that you suspect one side of a wheel disc receives more pressure from the brake pad than the other and perhaps indicated by a degree of less wear on the disc via your test... My expectation might be that the pad wear generally shows up any such situation..with the pad on one side of the calliper being more worn than the other..? As discussed earlier with a brake design where the pistons are mounted on one side of the caliper only and a rail system of some sort employed to ensure even pressure applied to the pads on both sides, any restriction of movement on the rail system will cause uneven pad wear... and thus affect braking performance.
I am again guessing that when you criticise the handbrake performance and find comfort in that your Mog has an auto box, you are typing of the ability to park safely by using the P selection which can lock up an auto box...? Whereas when driving I ever found comfort in the ability to slow down by dropping down through the gears in a manual gearbox and careful use of the handbrake lever to avoid locking up the rear wheels... All of which has been removed in the case of auto boxes and electrically operated handbrakes..?
Hard pads are generally designed to work when brakes are up to temperature as on a race track or fast road driving, where brakes are regularly and perhaps heavily applied causing the discs and pads to retain heat... The down side is that they do not work too well when cold and require more pedal pressure to create a reasonable retardation effect... The correct choice of pad should be based upon your average usage... Sorry not trying to teach my granny to suck eggs.. just that I do like the KISS principal...
These days with so many hobby vehicles laid up for long periods it would seem there may be more potential for corrosion issues affecting brake systems and electrics.
Given the amount of seals likely to exist in an ABS master cylinder unit, I can only begin to imagine the possible problems caused if ever the wrong type of brake fluid was introduced to the system...?
I repeat, I am NO expert, just thinking in type and could be entirely wrong about anything.
Re: My23 brakes [Re: Derek596] #766093
02/01/23 12:05 PM
02/01/23 12:05 PM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
The simple truth is, the factory made a mistake with the braking system, if the brakes had been right in the first place, then three years the on factory wouldn’t have had to replace them.
I do hope that a replacement 4 pot calliper will be available at some point from hopefully Mulfab?
Previous:-
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #766100
02/01/23 02:42 PM
02/01/23 02:42 PM
Barry M Offline
Barry M  Offline
I have been thinking about this over the past. couple of days and as Ludite has said, (Paraphrasing) "Brakes is brakes" The one thing that can throw a spanner in the works of what is a fundamentally simple system, is control interference, in our case, in the form of an ABS system.
I haven't studied the Morgan system, but using only logic, I would guess there is a high chance that the issues being experienced by owners are somehow rooted in the ABS.
No-one seems to be talking about the ABS and it is technically beyond me, but it is surely a suspect in the enquiry?
Re: My23 brakes [Re: Derek596] #766107
02/01/23 03:26 PM
02/01/23 03:26 PM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
As I’ve said before, I’ve never felt the ABS working under very heavy braking! Other cars I drive, under heavy braking you can feel it through the brake pedal.
Previous:-
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #766109
02/01/23 04:06 PM
02/01/23 04:06 PM
Chester
Mikemog6 Offline
Mikemog6  Offline
Chester
ABS, ANTI LOCK BRAKING, only works when the senors located on the hub detect a wheel locking up, when the wheel locks up the ABS pump kicks in, the effect is like cadence braking in the old days when you would pump the brake pedal so you could still steer your way out of trouble, ABS would not operate under heavy braking if the wheels did not lock up. Under normal braking conditions the ABS will have no effect.
Previous Mog Plus 4 Fiat Twin Cam.
Plus Six
Re: My23 brakes [Re: Derek596] #766110
02/01/23 04:07 PM
02/01/23 04:07 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
I did not know that the CX cars have ABS...Has anyone ever felt it in action on wet or slippery roads?
Re: My23 brakes [Re: Derek596] #766115
02/01/23 05:10 PM
02/01/23 05:10 PM
Luddite Offline
Luddite  Offline
Mikemog6, Im with you all the way on ABS being similar to old style cadence braking, however I suspect it may be worth investigating ABS further, as for me ABS works under emergency braking much the same as it does in normal braking... The First car I drove with ABS was a Porsche 944 and I purposley put the nearside wheels on a grass verge with the offside wheels on Tarmac and conducted the equivalent of an emergency stop ... the 944 pulled up straight and true..No drama.. Much to my surprise I must admit...
As ever more than happy to be corrected.
Re: My23 brakes [Re: Derek596] #766118
02/01/23 05:45 PM
02/01/23 05:45 PM
CooperMan Offline
CooperMan  Offline
I wonder if Litchfield's upgrades to softer pads and brake fluid involve to easy upgrade to DOT 5.1 fluid ? It has viscosity improvers for 'cold' brake feel and ultimately a higher boiling point (without the hassle of full swop to silicone based fluids)
Re: My23 brakes [Re: Derek596] #766119
02/01/23 05:49 PM
02/01/23 05:49 PM
CooperMan Offline
CooperMan  Offline
These are the multiple pipes from the ABS unit located in the Plus Six, gets nice and warm in the engine bay...
Re: My23 brakes [Re: Derek596] #766120
02/01/23 05:54 PM
02/01/23 05:54 PM
CLPlusFour Offline
CLPlusFour  Offline
What brake fluid is in it now. A change usually means new seals and new hoses.
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: CLPlusFour] #766127
02/01/23 06:56 PM
02/01/23 06:56 PM
CooperMan Offline
CooperMan  Offline
DOT 4 as standard, easy to upgrade to 5.1 with just the usual flush through and bleed (which should be done every 2 yrs or so with DOT 4) compatible with existing seals & hoses etc
5.1 is not to be confused with 5 which is silicone based and should not be mixed
Re: My23 brakes [Re: Derek596] #766133
02/01/23 07:09 PM
02/01/23 07:09 PM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
CooperMan, when I called Lichfield and spoke to Tom the other day, he gave two choices, the best being CASTROL SRF. I can’t remember the other. So Silicone based.
He did say that the improvement from the brake fluid was less than the pads. Given we have all had new fluid this summer, perhaps test to make sure it has not absorbed too much moisture. Assuming fluid within limits, just change pads.
Cheers
Ian
Re: My23 brakes [Re: Derek596] #766145
02/01/23 08:10 PM
02/01/23 08:10 PM
CLPlusFour Offline
CLPlusFour  Offline
Are you sure ? In my opinion Castrol Racing SRF is a DOT 4 brake fluid.
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #766149
02/01/23 08:59 PM
02/01/23 08:59 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Cheers
Ian
Castrol SRF racing brake fluid conforms to DOT3 and DOT4 specification. But unless you want to operate your car under racing conditions why would you need such confused2
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: My23 brakes [Re: Derek596] #766151
02/01/23 09:05 PM
02/01/23 09:05 PM
Malvern Hills
Jono Offline
Jono  Offline
Malvern Hills
ABS on my Plus 6 kicks in regularly, as I live up a very steep gravel track on side of the hills. The ice hung around before Christmas, but main roads all clear, so going down track, ABS was kicking in , I could feel it through pedal, and it wasn’t skidding down track with wheels locked. It was still an arse clenched moment though.
Re: My23 brakes [Re: Derek596] #766153
02/01/23 09:30 PM
02/01/23 09:30 PM
I
Ian Hubbard Offline
Ian Hubbard  Offline
I
CLPlus4 and RichardV6, thanks for clarifying. That will teach me to quickly check on Google 😀
RichardV6, agreed you don’t need it
Re: My23 brakes [Re: Derek596] #766156
02/01/23 10:51 PM
02/01/23 10:51 PM
Hampshire
Alistair Offline
Alistair  Offline
Hampshire
Based on the comments above?
If the CX brake system was weak and unable to create strong pressure then the wheels would not be able to lock up and so the ABS would never kick in. Given the comments from several people saying the system felt soft on the pedal and reports of pressure fail it would make sense.
Do we know if it is fair to say they underspec'd it or was the volume of components that arrived following the prototype being below spec? I figure they gave the prototype a good hard run a few times before they said yes. It's not like the factory team don't enjoy a good drive?
I follow a Mini forum and find the discussion around the installation of "track" discs & pads humorous. They spend ages discussing which uprated road/track pads to fit then, once fitted, moan about the fact that they are dead, noisy and numb. Before they had them fitted did they ever find the pedal hit the bulkhead? Do they really brake that late and hard?
I have fitted uprated discs and brakes to the ML63 as it weighs 2+ tonnes and I have felt fade a couple of times when in a rush. EBC are among several good vendors making aftermarket upgrades for the MB. Given the standard brakes are Brembo it's quite a step to improve things. So it has EBC uprated front discs and Yellow Stuff road/track pads plus uprated Brembo discs and Yellow Stuff pads on the back. When they are cold they take longer/harder to stop the car from any given speed. So the uprated bit is not really an improvement for the daily traffic. If I am pushing the lorry around Basingrad roundabouts on a clear day they are brilliant once warmed through. I am only surprised that the front spoiler does not have scrape marks on the bottom given how well they work when up to temp. So the benefit is only really seen in extremis. You just have to be aware of what you are looking for.
Re: My23 brakes [Re: Derek596] #766169
03/01/23 03:00 AM
03/01/23 03:00 AM
Glos.
DWil23 Online content
DWil23  Online Content
Glos.
I remember doing an emergency stop from 70+ mph in a Plus Four at Bicester Heritage on the Morgan Experience session in August. Assume that had standard brakes. Could feel the ABS kicking in and stopped quite quickly and kept pretty straight with a little input. Haven’t noticed any ABS yet in normal winter breaking on my car, but still limited miles and not pushing it for obvious reasons.
David
MY22 Plus Four, Alligator (AML Racing) Green ! 😍
Re: My23 brakes [Re: Derek596] #766177
03/01/23 08:55 AM
03/01/23 08:55 AM
Luddite Offline
Luddite  Offline
So easy to become confused with all this chat...
Best not to think of alternative brake fluids, stick to manufacturers specifications.
The days of owners modifying modern Morgans is fast disappearing along with the generation of baby boomers who thought modifying their Morgans to "improve" them was very much a part of the Morganeers culture.
Part of the modification culture seemed to be based upon bragging rights as opposed to actual driver demands on the vehicle... Racing spec anything incorporated into a road car can create a pig of a machine to spend time in when in traffic.
Morgans are light vehicles and unless driven hard will take a while to get race spec pads up to their best operating temperature on the road..if ever..?
I have no idea as to which type of ABS system might be fitted to any Morgan.
Either long travel or soft pedal would seem to go against normal driver expectations. If a soft pedal is combined with poor retardation performance on the road, I would have to understand why this could occur and exactly what caused it, also what repair techniques were involved to resolve the issue...
With brakes being the primary safety system on any car my expectation would be that even in a situation of total electrical or ECU failure that the hydraulic aspects of the system would provide "reasonable" retardation effect. Though logic determines that on an electrical system failure, an electrically operated handbrake activation may be lost..! Worth looking into the design of that..?
I suspect that any MOT equipped garage could take no more than 15 minutes to check the efficiency of braking on each wheel for you, including handbrake performance, for a reasonable cost. No need to wait till an MOT is due.
Re: My23 brakes [Re: Luddite] #766184
03/01/23 10:06 AM
03/01/23 10:06 AM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
A lot of sense there George!
It would be interesting to know from those who have long pedal travel, whether that shortens if the brakes are pumped repeatedly. If so, I would look to re - bleed. Just because it’s been done during recent factory recall, doesn’t guarantee it was done successfully. (due to time pressures etc)?
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: My23 brakes [Re: Derek596] #766188
03/01/23 10:47 AM
03/01/23 10:47 AM
West Somerset
Davetherave Offline
Davetherave  Offline
West Somerset
The following is just my opinion.
A soft brake pedal often pointed to air in the system, sometimes this gives a feel of longer travel.
In the days prior to ABS and servo assist you could check this by rapidly pumping the brake pedal, if the pedal went hard and travel reduced and then when left for 5 to 10 minutes went back to a soft pedal again it pointed to air in the system. Even a very small amount of air can make quite a difference on a brake system.The ABS pump itself can be difficult to completely bleed depending on its type and its position in the brake circuits. I do not know what make/type of ABS pump Morgan have used in the Plus 6 ( no parts scematic available to owners ). My experience with motorcycle early ABS pumps was that it took quite a few goes to get the air out of the pump, some even had bleed nipples on the pump itself. There was also a set sequence to bleed the early ABS systems.
In my previous post I mentioned that after our Plus Six M/Cylinder replacement I was not happy with the pedal travel/feel and asked the dealer to look at it again. I am fairly certain they re-bled the system. After their second intervention the brakes on the Plus Six are acceptable and better than pre M/Cylinder change.
Lastly, ref poor handbrake.. Our Plus Six initially had an excellent handbrake, but was noisy from cold in the area of the NSR wheel. The noise sounded like rubbing but gradually stopped after 1 to 2 miles as everything warmed up. The dealer looked at it and reported that the brake pads needed cleaning and light greasing in their retaining area. After this work the brake noise from the NSR wheel area was gone, but the handbrake was lousy, would not hold on a 5 deg incline, so it went back to the dealer and they adjusted it.. Its now back to working well and its not producing noise. So from this I am inclined to think that adjustment on the Plus Six handbrake is borderline and does not take much to either work well or not at all.
Dave
Plus 6 "Squeak"
Roadster departed.
Re: My23 brakes [Re: Deejay] #766204
03/01/23 02:21 PM
03/01/23 02:21 PM
Luddite Offline
Luddite  Offline
Deejay, thanks for commenting. Had I that degree of sense in my yoof, I would have saved a lot of cash spent on modifications that demanded further modifications and ultimately threw many a practical machine out of balance and made it a pig to ride/drive except when operating the very narrow window of performance I had created.... and that I did so man more times than once.... blush
Dave, in my limited experience air in the system is usually associated with leakage, or may be found when the system requires bleeding after having work carried out on it and not being properly bled.... For sure some machines can be far more ackward to bleed than others..
The soft pedal that can be realy scary, is the one where as an example... After lay-up, where a caliper may have partially seized and is holding a pad or pads against the disc to the extent it is no more than rubbing, perhaps not in any way first noticed when one fires up the Mog to head out for that first run in the sun, brake pedal feel s fine, brakes seem to be working well, then after a few miles, the pedal hits the carpet under braking.... The rubbing pad has heated the caliper and disk and in the process boiled the fluid, which can manage in a shorter period of time if the fluid has not been changed as recommended, and as a result has a high water content, the water boiling at a lower temperature than good condition brake fluidwould ever do so...?
As always just thinking in type..
Re: My23 brakes [Re: Luddite] #766224
03/01/23 06:14 PM
03/01/23 06:14 PM
West Somerset
Davetherave Offline
Davetherave  Offline
West Somerset
Ref the air, yes totally agree. But its quite possible that A: The factory did not get all the air out at time of manufacture and B: The dealers could have had the same issue when the M/Cylinder recall happened. Bleeding some ABS systems can be tricky. This may account for a small % of cars reporting poor feeling brakes and longer travel. I am not saying this is the total reason, as there seems to be quite a lot of reported variation in brake quality. But it could be one of the reasons for some cars. Also the CX cars are relatively new, most will not have done high milage, so the hardware should be in good to fair condition...
Dave
Plus 6 "Squeak"
Roadster departed.
Re: My23 brakes [Re: p8mog] #766233
03/01/23 07:51 PM
03/01/23 07:51 PM
CooperMan Offline
CooperMan  Offline
That's a bit low spec, ok for a Ford Fiesta, Is the P Six a better spec ?
Re: My23 brakes [Re: CooperMan] #766240
03/01/23 10:18 PM
03/01/23 10:18 PM
RichardV6 Offline
RichardV6  Offline
Agreed. I thought they only used single piston floating calipers on the rear of modern cars as they better support cable operated handbrake action as well.
Re: My23 brakes [Re: Derek596] #766246
04/01/23 02:47 AM
04/01/23 02:47 AM
NZPlusSix Offline
NZPlusSix  Offline
I think we are boxing round the question that the thread posed "Are the brakes on the M23CX cars better?"
Somebody needs to test drive a Plus Six that the dealer claims is up to the specs re braking performance, then test drive a 2023 Plus Six demonstrator. Original reviewers of the Plus Six commented on the soft pedal and the long brake pedal so it was a known. What we don't know is an accurate comparison between the models. If there is a difference then we need to find out what has been changed.
Presently my dealer is in contact with MMC as to what to change on our car to get maximum brake performance. Watch this space!
Kerry
Prev
2011 4/4 Grey
1939 4-4 Blue
Re: My23 brakes [Re: NZPlusSix] #766248
04/01/23 05:55 AM
04/01/23 05:55 AM
OZ 4/4 Offline
OZ 4/4  Offline
Looking forward to the answer...
Re: My23 brakes [Re: Derek596] #766258
04/01/23 01:25 PM
04/01/23 01:25 PM
Luddite Offline
Luddite  Offline
RAMBLE ALERT..!
As I typed a while back it is so easy to get confused with all this chat, and I am perhaps more guilty than most when it comes to rambling on...(-:
On the other hand the chat has caused my old brain cells to become more active than they might otherwise be, which at my age might be considered worthwhile.. (-:
I suspect we have all learned by now that mistakes abound in discussions, I know I have typed a few myself and been grateful for them to have been corrected by more knowledgable folk.
Back to fundamentals on brakes... or at least trying to brake (no pun intended) down the complexities of operation into a form of more basic understanding..?
As suggested best to stick to manufacturers spec on much, especially brake fluid. No harm in seeking better understanding and if so motivated this link has had some work put into simplifying things, even if the presentation is less than professional..?
https://youtu.be/SdnSlBG71G4
As no one has yet asked, I think DOT as in brake fluid and much else equates to Department Of Transport..?
Bleeding ABS.... I have only ever bled two ABS systems and managed to do so without causing issues which may just have been down to luck..? Both NON-MORGAN.
The likely more modern and complex system was on a sports car where each calliper had two bleed nipples, one for each side of the calliper which had four pistons in total. Apparently during bi-annual fluid changes it seems possible if not likely that the garage mechanics will seek to save time and reach through the spokes of the wheel and use the outer nipple on the caliper to bleed it leaving the harder to reach nipple untouched...?
OK call me a cynic by all means, but it seems quite often on this marque that the inner and harder to reach brake nipple is often found to sheer off when disturbed for bleeding purposes whereas the outer and easier to reach nipple often loosens without issue...
If I might be in any way correct in my assumptions, it would then seem obvious that only one side of each calliper bled in such a way will have the benefit of it`s brake fluid being replaced and in such circumstances over time and if the same flawed bleeding process is followed then dependant on the passage of time who knows what age the brake fluid might be contained within the inner section of the caliper and just how much quicker it might come to the boil under braking creating some degree of increase in pedal travel...Hmm..?
If you come across seized nipples that seem likely to sheer, or have a caliper with a sheered nipple, there as specialists in removing sheered nipples, though the task is simpler if the nipples is not sheered off, but not impossible.. Even on painted callipers, where I believe some form of ultrasonics is involved in the removal process. Such specialists can also supply original nipples or stainless if preferred...
Bleeding... As has been typed it seems there may well be a variety of processes suggested dependent on which system is in use..?
I used gravity and nothing else... and it has worked out well to date, brake pedal felt fine and vehicles pulled up straight and true.. I had removed two callipers, the front offside and the rear nearside and had closed off both flexible pipes with clamps to save loosing all the fluid with whatever complications that might have created in the ABS system.. After replacement of each calliper, starting with the rearmost one first and with the fluid reservoir topped up first released the clamp on the flexible, followed by opening up one nipple at a time on that calliper, the one closest the flexible hose opened first and left opened watching the fluid begin to appear in spurts until the air bubbles stopped spurting, hopefully indicating that side of the calliper was full of fluid, I then checked and topped up the brake fluid in the reservoir, and then followed the same process on the outer side of the calliper, after which I again checked the reservoir. I then checked the pedal travel which seemed OK, it took a couple of pumps to extend the pistons in the caliper I had just bled to the extent that the brake pads made firm contact with the disc. At which stage I then let the system sit for a couple of minutes and checked the brake pedal action for travel and to check if it would pump up and change the length of travel, which it did not...
Exactly the same process for the replacement and bleeding of other calliper with exactly the same results... After topping up the reservoir and replacing it`s cap, I then fired the engine up and again tested pedal travel, which felt fine, followed by a road test which again seemed to confirm I had created no issues when I bled the brakes..
Using no more than logic... It seems that for the brakes to conform to my expectations of fail safe design, that all circuit ABS control valves would surely be opened, to then allow the master cylinder to create pressure to all circuits were the brake pedal pushed down, with no need for the engine to be running or electricity applied to the ABS control system..? Thus with the cap removed from the reservoir gravity bleeding with a bit of forethought seemed to work well enough for me.. I stress again this was NOT on a Morgan.
As for attempting to find answers on brake efficiency one car against another, even with the same driver on exactly the same road surface and in exactly the same weather conditions tyre type and on and on and on... I suspect the variation in assessment could be considerable..? As suggested in my last I suspect any MOT or garage with brake testing equipment can compare and provide readings for all four wheels independantly of each other or in combination, along with handbrake performance on each wheel.... Thus anyone who cares to can create reasonably accurate comparable readings for brake performance to share with others, the only variable other than the performance of the brake testing machinery, would perhaps be the amount of pedal pressure required to be applied create the readings obtained..?
Pedal travel can be relatively simple to measure reasonably accurately..?
My guess is that UK construction and use, if not EU regs, will contain a number of specifications for brake usage and efficiency figures as a minimim for a variety of vehicles as no doubt will MOT regulations..?
Again using no more than logic with zero professional training....As for what the problem might be with Morgan brakes if any.... I would hope that they were bled as required before they left the factory for anything other than that would be too much to ask me to accept as in any way reasonable from a motor manufacturer.
Simple logic would also seem to dictate ..As the MMC do not manufacture brake components other than perhaps the pedal arrangement and linkages specific to Morgan, that MMC are then dependant on other manufacturers supplying DOT approved parts, it would seem to be incumbent upon the MMC to consider the compatibility of the combination of all the parts used to make up the whole system, including the type of brake fluid that the MMC would then specify for use in the vehicles brake system..?
With ABS in circuit given the many valves and seals in that system let alone all the seals elsewhere in the system, the choice of fluid seems best not to be taken lightly..?
As ever more than happy to be corrected if I have been wrong in any of my assumptions
Last edited by Luddite; 04/01/23 01:27 PM. Reason: missed out the warning I could be wrong
Re: My23 brakes [Re: Derek596] #766264
04/01/23 03:29 PM
04/01/23 03:29 PM
CLPlusFour Offline
CLPlusFour  Offline
Let's come back to the detailed question of whether the brakes from MY23, which are supposed to be better, can be converted to MY22 and earlier.
The question for me here is what components are actually installed.
Which brake fluid does MMC specify?
Which brake booster is used?
Which brake master cylinder is used?
Which brake caliper with how many pistons?
Which brake pads are used?
Which ABS is installed? Definitely a four-channel system, as you can see from the photo.
Unfortunately I don't have a picture of the brake disc and caliper.
Are the components on the PusFour and PlusSix the same?
Maybe one or the other member can answer one or the other question.
Once the questions for the different model years up to MY23 have been answered, the question of retrofitting can be answered.
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #766266
04/01/23 04:03 PM
04/01/23 04:03 PM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
The MY23 brake system cannot be retrofitted, I believe that the ABS unit is by Bosch. I would hope that on the MY23 Plus Four it would be twin pots on the front rather than the single pot as on my MY21 Plus Four.
Previous:-
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #766277
04/01/23 06:10 PM
04/01/23 06:10 PM
CooperMan Offline
CooperMan  Offline
Didn't the factory try flipping the existing front calipers to a reverse (upside-down) orientation on the early Plus range if owners complained of poor brake feel / squealing ?
Re: My23 brakes [Re: Derek596] #766278
04/01/23 06:12 PM
04/01/23 06:12 PM
Luddite Offline
Luddite  Offline
Apology for not having the ability to answer any of the logical questions and thanks for posting the pic Clemens. Interesting that the brake fluid reservoir is remote from the master cylinder, perhaps selected relative to maintaining the lowest possible bonnet line.
Another worthwhile question might be related to whether or not the ABS unit has a pump and if it`s ECU is built into the unit.
I did a bit of web wandering and was surprised to find a variety of faults related to Bosch ABS control units some where it affected speedometer read out, though found NO Bosch unit on the site below listed as being fitted to Morgan.
Bosch ABS Pumps & modules (ecutesting.com)
Seems the only mention of the brake rectification process carried out by the MMC has been related to a soft pedal and master cylinder replacement... No mention of MMC carrying out known work on any other part of the brake system..or have I picked that up wrong..?
Having noted the Litchfield comments...To further expand in the theme of modification for those interested in such pastimes and that Morgan might even have made use of something like this..? :-
ABS M5 Kit | Bosch Motorsport (bosch-motorsport.com)
A neighbour had two Nissan GTR`s from different eras, and told me he had planned to have the underside of the older one ice blasted and returned to look as new, the quote for all the work was reported as circa £10k with quite a few months to wait before they could take the car in.... Could all just be neighbourhood chat, though the cars were very real.
Re: My23 brakes [Re: CooperMan] #766279
04/01/23 06:15 PM
04/01/23 06:15 PM
RichardV6 Offline
RichardV6  Offline
I think that was just to stop the squealing at low speeds Jon. After the mod they then only squealed in reverse innocent
Re: My23 brakes [Re: RichardV6] #766286
04/01/23 07:10 PM
04/01/23 07:10 PM
Suffolk, England
John V6 Offline
Brooklands Register contact
John V6  Offline
Suffolk, England
This is what I understood by the mod.
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: My23 brakes [Re: Luddite] #766289
04/01/23 07:30 PM
04/01/23 07:30 PM
CooperMan Offline
CooperMan  Offline
RAMBLE ALERT..!
DOT (in brake fluid) comes from the US standard Department of Transportation test for boiling point
Can be confusing for the UK users as DOT (in roadbuilding specs) is Dept of Transport, and even MOT which was Ministry of Transport
Re: My23 brakes [Re: Derek596] #766291
04/01/23 07:45 PM
04/01/23 07:45 PM
CLPlusFour Offline
CLPlusFour  Offline
Luddite as far as I can see the ABS has an ECU and certainly a pump on the other side of the block as I know ABS systems. Have unfortunately no better photo ... which I made during my visit four weeks ago in the factory
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #766316
05/01/23 09:03 AM
05/01/23 09:03 AM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
Re: My23 brakes [Re: Derek596] #766318
05/01/23 09:18 AM
05/01/23 09:18 AM
CLPlusFour Offline
CLPlusFour  Offline
thanks Thierry for the picture thumbs
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #766323
05/01/23 09:34 AM
05/01/23 09:34 AM
Barry M Offline
Barry M  Offline
So there could be software issues with the ABS ecu or the main ecu, assuming they talk to each other, both or either of which could be causing excess pedal travel and/or inefficient braking. You will need someone cleverer than me to sort that lot out IF that is the case!
Re: My23 brakes [Re: Derek596] #766325
05/01/23 09:42 AM
05/01/23 09:42 AM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
I may have imagined this, but I'm sure I read somewhere on TM that someone had an excessve pedal travel after the brake cylinder fix, took it back to the dealer who re-bled the system and they then had a massive improvement. Can't remember who!
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: My23 brakes [Re: Derek596] #766326
05/01/23 09:44 AM
05/01/23 09:44 AM
Barry M Offline
Barry M  Offline
By the way, the Plus Six has 4 pot calibers (2 pistons on either side if the disc). I cannot tell the make of the calipers as they are sprayed yellow with a Morgan decal and no manufacturer marks can be seen from outside the wheel.
Re: My23 brakes [Re: Derek596] #766328
05/01/23 10:06 AM
05/01/23 10:06 AM
Luddite Offline
Luddite  Offline
Cooperman thanks for confirming and adding info re the DOT acronym.
Thierry, thanks for your pic of the ABS unit confirming it has an integral pump.
Clemens with the benefit of your pics, it seems that the master cylinder is of the dual circuit type, and operates with servo assistance.
As ever I claim no expertise, I come here in the hope of learning.
I suspect the dual circuit master cylinder will supply braking pressure to two wheels on each circuit.
With the engine running and thus supplying vacuum to the servo, the servo will multiply the pedal applied pressure, which should provide all braking power required and which alters braking performance relative to the variation of pedal pressure applied by the driver.
In a situation of servo failure, increased pedal pressure is required to equal the same braking effect as was the case when the servo was operational.
With the car stationary and a foot applying pressure to the brake pedal, then the engine started, it can often be the case that the pedal will move further under the originally applied pressure, suggesting that an increased amount of pressure has been applied to the brake circuit..?
If any one hydraulic circuit fails, i.e due to fluid leakage, then both wheels on that one circuit will loose pressure, the remaining two wheels on the other circuit will still have braking power applied relative to the pedal pressure applied, however I suspect the pedal travel will increase before pressure build up in the remaining operational circuit is achieved.
I expect if one circuit fails, a brake failure indication will appear on the dash, and the relevant signal sent to the ABS unit`s ECU in order that it operates according to the way it has been configured to operate it`s valves in a circuit fail situation....?
I do not know the lay out of dual circuits configuration on new Morgans, could be diagonally across the car or front and rear fed separately.
This vid seems to provide a reasonable generic explanation of ABS operation for any one wheel.
https://www.youtube.com/watch?v=-IUZWwMm7nY
I spent some time wandering the web in an attempt to define the ABS unit`s hydraulic pump motors exact function (if fitted) and failed to do so to my own satisfaction/understanding.
if anyone knows the exact function of the pump, I would be grateful if they could educate me/us.
If you watched the vid via the link above, it suggests the purpose of the pump is to "return" fluid in a pulsing action back up the same line that is supplying pressure to any one circuit of brakes, these being the pulses which can be felt through the brake pedal when the ABS unit is called into action.
I do wonder if any fluid is being "returned" as suggested in the vid..? It seems more likely that the pulsing of the valve is that which is felt at the pedal and it is the pump that generates the pulsing pressure felt while at the same time the valve is being electrically pulsed to restrict pressure to the brake at risk of locking the wheel, the pump relieving the pedal generated pressure at the wheel by working against it, described in the vid as "returning" fluid..???
Given that I suspect any one of the two lines supplying pressure generated by the master cylinder to then merely pass through the inactive ABS unit and on to the two wheels in that one circuit, It would seem that if/when the ABS unit is called into action, that "pumping" fluid back up the line to the master cylinder would affect the brake pressure being applied to both wheels on that one circuit..?
I have found web site suggestions that the ABS pump supplies pressure to the wheel brakes, as opposed to "returning" fluid to the master cylinder as in the vid, or perhaps more likely to be making pulses felt through the pedal to advise that the ABS unit is active..?
As is ever with ECU controlled units they can be programmed to operate in a variety of different ways relative to the variation of inputs at any one moment in time, and trying to apply simple electro/mechanical logic is unlikely to cover all possible operational scenarios.
To add to the complication of gaining full understanding, it seems manufacturers may be unlikely to provide a step by step guide as to the way the ECU`s outputs are designed to operate relative to input signals, tending to quote intellectual copyright protection as a reason for not providing information on the programming/configuration of any ECU`s control strategy...? All of which creates probable misunderstanding when using electro/mechanical logic when attempting to understand the stages of operation of any particular control unit..
With the above in mind it seems possible that a few different interpretations of actual operation of the same unit may be found out in the www..?
Always happy to be corrected if I have got anything wrong.
Re: My23 brakes [Re: Derek596] #766330
05/01/23 10:50 AM
05/01/23 10:50 AM
CLPlusFour Offline
CLPlusFour  Offline
Hi Luddite, perhaps the term hydraulic pump is simply confusing. In an ABS system, this is an eccentric pump, so a motor with an eccentric bearing. This is exactly the unit that is called M in your video and the downstream eccentric pin. I hope my explanation is understandable ... despite my limited english
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: CLPlusFour] #766331
05/01/23 11:45 AM
05/01/23 11:45 AM
Luddite Offline
Luddite  Offline
Your English is far better than my very few words of German... I had trouble trying to find the words to explain my thinking and although I am a Scot, Engilsh is my native language.. hide blush
Thank you for taking the time to respond. In my web searches I learned of the pumps method of producing pressure, though I was unable to find out exactly what the hydraulic pressure it created was actually used for when the ABS system was activated...? There seems to be some different explanations as to its purpose out in the www. crazy2
Re: My23 brakes [Re: Derek596] #766332
05/01/23 12:57 PM
05/01/23 12:57 PM
CLPlusFour Offline
CLPlusFour  Offline
The purpose of the pump is only to generate the pressure that would otherwise come from the brake pedal. The ABS, if it is active because a wheel indicates zero rotation, separates the pressure from the pedal on the brake pistons and the pressure from the pump takes over this task. About the four valves in the ABS block is then controlled on which brake disc pressure is exerted or not.
Another mode of operation of the pump does not exist to my knowledge.
Here is another video https://www.youtube.com/watch?v=RfAzB_IcWuk
Have first inserted the wrong video. Now it fits ... sorry banghead
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #766339
05/01/23 03:51 PM
05/01/23 03:51 PM
Chester
Mikemog6 Offline
Mikemog6  Offline
Chester
At last CLplusfour as stated the facts, I have been watching with amusement some of the misleading comments, ABS is not TC traction Control or any other form of anti skid control it just stops the brakes locking up so you can steer your way out of trouble under severe braking when the wheels lock
I have had ABS ECU failed and the brakes still functional normally.under normal braking.
Well done CLplusfour
Plus Six
Re: My23 brakes [Re: Mikemog6] #766353
05/01/23 06:06 PM
05/01/23 06:06 PM
Luddite Offline
Luddite  Offline
Clemens, great vid, thanks for posting.. thumbs
As it seems such a simple matter to make mistakes, I am not of the type to be amused by "misleading comments" such as
" ABS is not TC traction Control or any other form of anti skid control it just stops the brakes locking up so you can steer your way out of trouble under severe braking when the wheels lock"
My limited understanding is that ABS is primarilly designed to prevent "skidding" of any or all wheels that might struggle to grip on a road or other surface under braking..?
Also ABS function seems designed not only to maintain the ability to steer out of trouble under braking on a poor road surface, but also to assist in braking efficiently in a straight line in tricky conditions when otherwise wheels might lock-up, potentially causing loss of directional control..?
As ever more than happy for my thinking to be corrected if/when I get things wrong.
Re: My23 brakes [Re: Derek596] #766389
06/01/23 01:17 PM
06/01/23 01:17 PM
France, Dunkerque
gaston Offline
gaston  Offline
France, Dunkerque
ABS prevents skidding for braking. Traction control prevents skidding when accelerating.
I will probably repeat myself but a second bleeding of the brake system greatly improves braking. My plus four now behaves like a normal car.
Re: My23 brakes [Re: gaston] #766401
06/01/23 04:25 PM
06/01/23 04:25 PM
West Somerset
Davetherave Offline
Davetherave  Offline
West Somerset
Agree ref bleeding, same thing on our Plus Six..
Dave
Plus 6 "Squeak"
Roadster departed.
Re: My23 brakes [Re: Derek596] #766414
06/01/23 06:40 PM
06/01/23 06:40 PM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
This month i am going for the overhaul . I will ask the bleeding again.
We will see the results later.
Re: My23 brakes [Re: Derek596] #766419
06/01/23 07:27 PM
06/01/23 07:27 PM
RichardV6 Offline
RichardV6  Offline
I wonder how many have heard of or better been taught cadence braking which when performed in a practiced manner maximised braking action in conditions of minimal grip by taking advantage of retardation before tyres completely lost grip then quickly repeated in a dabbing action. In so doing, as well as stopping in shortest distance, it allowed some degree of steering in an emergency.
ABS simply seems to be an automatically applied and electronically monitored version of this efficient form of braking in marginal grip conditions.
Re: My23 brakes [Re: RichardV6] #766423
06/01/23 08:15 PM
06/01/23 08:15 PM
New Forest
Lordofthewings Offline
New Forest
I learned that technique in the 1960s and still employ it today (in all our cars). Especially when approaching a junction (e.g. to turn left) because it causes the brake lights to flash -- as a warning to the idiots behind who insist on getting just a couple of feet away while I'm completing the turn.
Re: My23 brakes [Re: Derek596] #766425
06/01/23 09:19 PM
06/01/23 09:19 PM
Luddite Offline
Luddite  Offline
On the off chance that there are any here who might be interested in looking at ABS units in a bid to get to grips with possible issues, I found this vid to be rather interesting in terms of the software configuration.
In this case a replacement ABS unit was fitted by a garage to resolve a problem and apparently the vehicle still had issues the garage seemed unable to resolve. It seems this guy may hire himself out as some sort of higher level tec, who specialises in resolving digital issues...
I found it interesting the number of sequences involved in using the programmer/scan tool that were involved in resolving the issue, any one of which if not performed in precisee sequence could have created an issue..?
To save all the chat if you beam in at circa 02:10 you can follow his processes.
https://youtu.be/0aacrGIAQYo
Interesting..?
Re: My23 brakes [Re: RichardV6] #766426
06/01/23 09:21 PM
06/01/23 09:21 PM
CLPlusFour Offline
CLPlusFour  Offline
That is exactly right
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #766431
06/01/23 10:37 PM
06/01/23 10:37 PM
Katikati NEW ZEALAND
NZPlusSix Offline
NZPlusSix  Offline
Just how ABS works is not the question unless at this very time you are skidding on ice or in the NZ mud on the road!
I would like to hear from someone who has driven a 2023 Plus Six as to how the brakes were especially in comparison to older model Plus Six.
I understand that the 2023 version also has Traction Control which once again you will not need unless you are skidding on ice or mud!
All I want is short brake pedal travel and more positive braking!
Kerry
2019 First Edition Plus Six Moonstone Blue
Prev
2017 Plus 4 Auto Ivory
2011 4/4 Grey
1939 4-4 Blue
Re: My23 brakes [Re: Derek596] #766440
07/01/23 09:55 AM
07/01/23 09:55 AM
CLPlusFour Offline
CLPlusFour  Offline
Kerry I'm afraid I can't answer that question for you. In Germany are still no MY23 for a test drive available. I am the next week or the week after next at my dealer near Stuttgart to pick up my PlusFour. I will ask when that is possible.
Can imagine that in UK or directly in Malvern a test drive is possible earlier. Maybe a TM member from the area has the possibility to report
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: RichardV6] #766487
07/01/23 06:54 PM
07/01/23 06:54 PM
People's Republic of South Yor...
CooperMan Offline
CooperMan  Offline
I prefer Cadence to ABS, which of useless in snow and ice on downhill sections, much better to use the old fashioned seat of the pants 'feel' for when you have grip or not, ABS just cuts braking off far too early in some situations
Re: My23 brakes [Re: Derek596] #766496
07/01/23 08:31 PM
07/01/23 08:31 PM
howard Offline
howard  Offline
why not just take a suspect car down to your MoT station where the equipment exists to measure the effectiveness of the brakes and take the opinions out of the subject?
The problem with this sort of discussion is that doubt feeds on doebt. Its a bit like someone saying to you in the pub "does this beer taste off to you".
Re: My23 brakes [Re: Derek596] #766499
07/01/23 08:58 PM
07/01/23 08:58 PM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
The first production CX’s must be due for their first MOTs soon so let’s see what happens? It should answer many questions.
Heron Grey Plus Four 2021
Previous:-
Connaught Green 4/4 1988
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #766514
08/01/23 08:11 AM
08/01/23 08:11 AM
RichardV6 Offline
RichardV6  Offline
I very much doubt that CX vehicles would ever be so bad in terms of retardation or pedal travel such that it would warrant an advisory or even a comment from MOT tester.
Vagaries of handbrake efficiency on Aero's and ARP4 with rear disc braking are more likely to be noticed however. I may have missed but thankfully can't recall any complaints of handbrake efficiency on CX series though.
Re: My23 brakes [Re: Derek596] #766517
08/01/23 08:21 AM
08/01/23 08:21 AM
CLPlusFour Offline
CLPlusFour  Offline
There was a thread Richard
Plus 4 CX Hand Brake
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: CLPlusFour] #766520
08/01/23 08:41 AM
08/01/23 08:41 AM
RichardV6 Offline
RichardV6  Offline
Thanks Clemens - and a thread in which I participated blush
Put it down to oldgit
Thankfully not all CX models suffered from poor handbrake though, so maybe setup rather than design.
Re: My23 brakes [Re: Derek596] #766751
11/01/23 11:08 AM
11/01/23 11:08 AM
CLPlusFour Offline
CLPlusFour  Offline
Asked my dealer about the brakes yesterday when I picked up my PlusFour.
1. demonstration vehicles MY2023 are available in Germany only from mid-March.
2. my PlusFour MY 2022, one of the last ones built, has four piston brakes in the rear and front. I'm going to take a wheel off this weekend and check it out.
3. if I thought the brakes were not good, harder brake pads can be used. I had a good impression of the brakes on my short ride of 120 kilometers yesterday. The pedal stroke is short, the pressure point is good and I had the braking performance was good. But this is only a first impression and now the car is in winter sleep in my garage
4. the dealer told me in the conversation that with the first delivered PlusSix vehicles the brakes were very bad. But this has been fixed in the meantime.
Answer all not the question of Kerry
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #766754
11/01/23 12:50 PM
11/01/23 12:50 PM
Luddite Offline
Luddite  Offline
In general terms harder/ racing pads are less efficient when cold and thus require more pedal pressure to slow down when not up to temperature, thus perhaps not ideal for city type traffic situations or when just cruising around the countryside...? Whether compounds have changed since my last involvement with hard pads to improve their efficiency when cold... ???
Re: My23 brakes [Re: CLPlusFour] #766812
11/01/23 11:13 PM
11/01/23 11:13 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
That sounds very positive and absolutely credible, Clemens. I wish you and your Plus Four all the best as soon as you can enjoy it in the spring.
Re: My23 brakes [Re: Derek596] #766869
12/01/23 06:34 PM
12/01/23 06:34 PM
NZPlusSix Offline
NZPlusSix  Offline
Hi Clemens
Many thanks.
Certainly sounds like MMC are on top of the brake situation on latest models. I'm sure that the problems with pedal travel and soft feel can be solved on the earlier Plus Six models. Mine is still at the dealers, however the weather in NZ has been wet and windy and certainly not what you want for driving a Morgan! Hopefully summer will finally arrive!
Kerry
Prev
2011 4/4 Grey
1939 4-4 Blue
Re: My23 brakes [Re: Derek596] #767127
17/01/23 02:56 AM
17/01/23 02:56 AM
MogCX Offline
MogCX  Offline
After the master cylinder upgrade, as others have reported above, I noticed a slight improvement in the brake pedal feel; it's not as squishy as before.
But, not all the time. After driving for a while (30 minutes or so) the pedal noticeably gets spongy again. The funny thing is that if the car is given a decent rest it firms up. This leads me to believe it is heat related - possibly the rubber in the master vacuum warming up? That corner of the engine bay does get pretty hot.
Anybody else noticed this? Only me?
Re: My23 brakes [Re: Derek596] #767131
17/01/23 08:13 AM
17/01/23 08:13 AM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
After washing my car the braking is very good , pedal is very strong no travel , and abs works on dry road . But after two or three braking it is gone the pedal is soft again.
Those cars have lot of personality
Re: My23 brakes [Re: Derek596] #767133
17/01/23 10:59 AM
17/01/23 10:59 AM
Barry M Offline
Barry M  Offline
Thierry - That sounds like air in the system somewhere to me, anyone else agree?
Re: My23 brakes [Re: Derek596] #767135
17/01/23 11:13 AM
17/01/23 11:13 AM
Luddite Offline
Luddite  Offline
My Morgan is of mid 80`s vintage has no ABS or servo and other than the pics kindly posted here by others I have not even seen the brake system that folks are having issues with, and I am NO expert on brakes, just thinking in type in the hope it might help.
MogCX, interesting that you think HEAT could be an issue.... The servo design is to multiply the pressure applied to the brake pedal, and IF it`s internal diaphragm was failing then I would expect the brake pedal to feel HARDER in that it would require more pressure to slow the car down.
Thierry Again it seems heat could be an issue..? Rarely used vehicles can have sticky brake action caused by corrosion build up on wheel related components, pads, pins, wheel cylinders, hand brake linkages, any one of which can cause the pads/shoes to rub the disc/ drum which can build up heat, and which over time can transfer to the brake fluid. If the brake fluid has aged to the extent that it has water content then the water content can boil creating a soft pedal, or the pedal can go all the way to the floor.
With a sticky brake action it may be noted that one wheel has more brake dust on it than the others.
Another check perhaps worth trying is to go for a drive with minimum use of brakes pull over and if you can reach in and touch the discs or drums with a pre-wetted finger tip to compare the disc/drum temperatures....If you burn your finger tip, don`t be too surprised.. (-:
A sticking brake can do so intermittently.
Last thought would be to look for any brake pipe that could gain heat from the exhaust or anything else...
Highly unlikely would be a brake pipe section acting as an earth and carrying enough current to cause it to heat and pass that heat to the brake fluid..
Barry, in general terms air in the system is usually associated with brake fluid loss, which can provide a clue as to where the issue might lie, as well as reduction in brake fluid level over time...With no fluid loss the expectation might be that the master cylinder might be suffering a seal failure.
As has been mentioned previously be sure not to mix brake fluid types,
Re: My23 brakes [Re: Derek596] #767139
17/01/23 12:18 PM
17/01/23 12:18 PM
Chester
Mikemog6 Offline
Mikemog6  Offline
Chester
After having my Plus Six back from the dealers following the master cylinder replacement, my brakes felt the same, so I bleed them again and now they are operating as they should.
Plus Six
Re: My23 brakes [Re: Mikemog6] #767142
17/01/23 12:45 PM
17/01/23 12:45 PM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
this will be done next week
Re: My23 brakes [Re: Derek596] #767144
17/01/23 01:58 PM
17/01/23 01:58 PM
Barry M Offline
Barry M  Offline
I don't think residual air in the system would lead to fluid loss, this is only possible if it leaks out somewhere (which could be where the air is getting in). Air not removed during bleeding a system with no leaks would lead to the compressible air making the brakes feel soft. this air could be anywhere in the system and may sometimes be more noticeable than others depending on where it is and whether it is in the form of. bubbles or micro bubbles spread throughout the fluid.
Some cars are notoriously hard to bleed and the Morgan CX may just be one of them
Re: My23 brakes [Re: Derek596] #767152
17/01/23 05:42 PM
17/01/23 05:42 PM
NZPlusSix Offline
NZPlusSix  Offline
My Plus Six arrives back from the dealers today after further work on the brakes. They are driving the car back round 180kms so it will have a good test run. In order to properly bleed the brakes they borrowed a power bleeder - conventional methods could not get all the air out of the system. I will let you know how they are myself after a good long run.
Kerry
Prev
2011 4/4 Grey
1939 4-4 Blue
Re: My23 brakes [Re: Derek596] #767154
17/01/23 06:05 PM
17/01/23 06:05 PM
Luddite Offline
Luddite  Offline
Residual air...??? I`m guessing for that to exist that the suggestion might be that system may not have been properly bled... As I have typed previously, I have bled an ABS system using gravity only, which worked well enough.
I guess with ABS it may be possible that if part of the system has been drained, air could be trapped behind a closed valve and not released back into the system until the ABS is activated for the first time after the drain down...?
Re: My23 brakes [Re: Derek596] #767155
17/01/23 06:43 PM
17/01/23 06:43 PM
France, Dunkerque
gaston Offline
gaston  Offline
France, Dunkerque
On the CX, it is impossible to purge by gravity. The ABS system is placed too low.
Re: My23 brakes [Re: Derek596] #767170
17/01/23 08:21 PM
17/01/23 08:21 PM
Luddite Offline
Luddite  Offline
Gaston thanks for the heads up on that. I`m guessing that for gravity bleeding not to apply I suspect that the fluid reservoir would require to be lower than the bleed nipples on the callipers..?
I appreciate that the ABS unit may be lower than the nipples but would expect that not to have any bearing relative to gravity bleeding.... However I have been wrong before, and will be again, thus more than happy to be corrected.
Re: My23 brakes [Re: Derek596] #767172
17/01/23 08:30 PM
17/01/23 08:30 PM
CLPlusFour Offline
CLPlusFour  Offline
Looking at the routing of the lines, it is quite possible that the bleeding is the problem.
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #767190
18/01/23 12:57 PM
18/01/23 12:57 PM
Barry M Offline
Barry M  Offline
It appears that all Morgan dealers will have to invest in modern vacuum bleeding equipment which they wouldn't have needed for the trad cars.
Most specialist performance companies will already have this, but I would guess most Morgan dealerships probably don't.
Vacuum bleeding should solve any residual air problems, but it won't be any good if any braking components are fault/leaky.
The more I think about it, the more I think most of the braking problems described in various posts on here are due to inadequate purging of air, possibly due to the brake line plumbing and/or positioning of the ABS unit.
I don't think leaky seals will cause a soft pedal feel (except maybe in extreme cases) unless they are also allowing air back into the system as the fluid weeps past the seal.
I know there was a faulty batch of brake components during early CX production, but I think all the "brake feel" issues discussed here are likely to be due to inadequate bleeding leaving some air in the system.
Re: My23 brakes [Re: Derek596] #767343
20/01/23 06:33 PM
20/01/23 06:33 PM
Black Forest Germany
CLPlusFour Offline
CLPlusFour  Offline
Sorry I'm only today come to look at the brakes more closelyIn my PlusFour model year 2022 it is a single-piston brake.
The manufacturer can not be identified
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #767346
20/01/23 06:51 PM
20/01/23 06:51 PM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
And the sliding mechanism isn’t protected by a rubber covering as most cars are, they’re open to the elements and if not used often enough they will seize up.
Previous:-
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #767381
21/01/23 01:47 PM
21/01/23 01:47 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
Is that not a dual piston? One piston either side of the disc.
Re: My23 brakes [Re: TBM] #767382
21/01/23 01:53 PM
21/01/23 01:53 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
No signs of a hydraulic line connecting across to the other side?
Doug
1958 Triton 650
Re: My23 brakes [Re: Deejay] #767384
21/01/23 02:00 PM
21/01/23 02:00 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
It'll travel through the body of the caliper - with a single pot, the caliper usually slides in a carrier, on dual pots the pads slide on pins.
Re: My23 brakes [Re: Derek596] #767385
21/01/23 02:12 PM
21/01/23 02:12 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
My 1972 had dual pots with no connecting line.
Same with the uprated 4 pots, no line
Re: My23 brakes [Re: Derek596] #767389
21/01/23 03:01 PM
21/01/23 03:01 PM
CLPlusFour Offline
CLPlusFour  Offline
It's not easy to photograph this... played with the brightness again.
I only see a piston on the inner side where the vent is placed.
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #767390
21/01/23 03:24 PM
21/01/23 03:24 PM
Chester
Mikemog6 Offline
Mikemog6  Offline
Chester
If you take the pads out you will eliminate the guess work and know for sure, looks easy enough.
Plus Six
Re: My23 brakes [Re: Derek596] #767393
21/01/23 03:40 PM
21/01/23 03:40 PM
Shrewsbury
p8mog Offline
p8mog  Offline
Shrewsbury
As I’ve said before, it’s a single piston.
Previous:-
Black Plus 8 1998
Re: My23 brakes [Re: Derek596] #767395
21/01/23 03:51 PM
21/01/23 03:51 PM
Luddite Offline
Luddite  Offline
Thanks for posting the pic Clemens.
Unfortunately the mechanism that allows the calliper to slide back and forth as the brakes are applied and released is not obvious from the angle you took the pic from.
Re: My23 brakes [Re: Derek596] #767405
21/01/23 05:21 PM
21/01/23 05:21 PM
RichardV6 Offline
RichardV6  Offline
Can anyone explain the advantage of single piston brake calipers when used on the front of a vehicle? The assymetric operation requiring provision and maintenance of a floating caliper body would surely offset any manufacturing savings.
I can see the advantage of using them on the rear as it aids mechanical handbrake linkage as on our F54 Mini, but that also has them on the front so there appears to be some modern thinking I'm missing confused2
Re: My23 brakes [Re: RichardV6] #767408
21/01/23 05:40 PM
21/01/23 05:40 PM
CooperMan Offline
CooperMan  Offline
Absolutely no hydraulic advantage, (in fact negative as you have to conteract the friction of the slider & they don't retract well when corroded) the only real 'advantage' is significant reduced cost to vehicle manufacturer, I'm sorry but they look very underspec for a 200hp + car. Even the basic later trads got the Caparo 4 pot calipers
Re: My23 brakes [Re: Luddite] #767409
21/01/23 05:59 PM
21/01/23 05:59 PM
CLPlusFour Offline
CLPlusFour  Offline
Sorry ... the picture is from yesterday. Wheel is back on and car again in another garage.
For me, that was clearly a one piston brake. Since I had the last ten years only with motorcycles to do I can also be wrong.
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: CooperMan] #767411
21/01/23 06:20 PM
21/01/23 06:20 PM
RichardV6 Offline
RichardV6  Offline
Thanks Jon entirely my thinking. The assymetric operation is always going to mean one pad contacts the disc before the other and the slightest friction and spring action in the floating linkage will reflect on some degree of uneven pad wear. Even my hybrid push bike has twin pot hydraulic calipers front and rear though.
For a moment I considered single pot calipers benefitted ABS but as that appears to work by electronically modulating brake pressure I cannot see the connection. Unless of course the ABS module used on CX is matched only to these single pot calipers [Linked Image]
Maybe production costs are that much lower with only one body casting, no cross fluid feeds, either internal or external, and only one bleed nipple to worry about. At least our Mini has dust covers over the sliding pins though. Lack of these if that's the case on latest CX models seems a further negative long term.
Re: My23 brakes [Re: Derek596] #767431
21/01/23 11:24 PM
21/01/23 11:24 PM
MattB Offline
MattB  Offline
Looking at the brand markings on the top of the callipers it looks like the manufacturer is 920Engineering.
See: https://shiftec.com/about/
Looks to be a bit of a messy history/status of brand names and ownership, but on the face of it 920E appear to have a good pedigree in motorsport.
Ignoring specs for a second, what I would say is the hire Plus Four I drive in 2021 had much worse brake performance and feel than both my Plus Four and that of the one I drove on the Driving Academy day (which was absolutely fine after 2 x 1 hour sessions on “track” at Bicester Heritage). The owners manual makes it clear that they are single piston callipers on the Four, front and rear, albeit with different size discs. The Six has four pot front callipers. Whilst I have no issues today it would be something I might look to upgrade in the future; if only to maintain braking performance over repeated descents in the Alps. If anyone is interested it looks like the dampers are made by SPAX, at least from what I could see on my front dampers with the wheel still on.
Re: My23 brakes [Re: Derek596] #767436
22/01/23 07:30 AM
22/01/23 07:30 AM
CLPlusFour Offline
CLPlusFour  Offline
I also have no problems at all with my brake. However, I have only driven a few kilometers with my PlusFour.
Matt where do you find in an owner manual a specification of the brake ? The manual I have only has very superficial statements on how the vehicle should be operated. Can you take a picture of the manual and the brake specification page and post it here? That would be great
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: Derek596] #767437
22/01/23 07:34 AM
22/01/23 07:34 AM
Luddite Offline
Luddite  Offline
Clemens your pic was a good effort, how were you to know what might be the most interesting angle for those of us who ever want more...? (-:
I thought there was mention of using a caliper upside down ( swapping left to right..?) to counteract brake squeal...???? Were that the case I hope they did not leave the bleed nipple in it`s original position on the caliper, mounting the swapped over callipers effectively upside down with the bleed nipple now at the lowest point in the callipers cylinder, as it would then be bound to cause a soft pedal, given the likelihood of air to ever be left trapped in the upper reaches of the callipers cylinder...??
Single piston calipers would seem to be no more than a cost cutting design, but I too have been wrong more than once before..
Just thinking in type, claiming zero expertise.
Re: My23 brakes [Re: CLPlusFour] #767439
22/01/23 08:22 AM
22/01/23 08:22 AM
MattB Offline
MattB  Offline
Of course Clemens, here’s a link to the PDF:
https://www.morgan-motor.com/wp-content/uploads/2022/09/Plus-Four-Owners-Handbook-Digital.pdf
Page 8 in the file / marked as page 5 in the print.
I suspect the choice is down to cost and weight (unsprung mass), but I also wonder if size plays a part with the wire wheel option and strange offsets. One thing I found strange when I ordered mine is I was told that Morgan had stopped offering the colour callipers earlier in the year. I was wondering why that was, but thought it may have been due to the MY23 change coming but then the recall happened. One thing I haven’t seen mentioned (apologies if I missed it) is that the ESC stability control will use the brakes in order to work - that may be the most significant factor in any change to specification or supplier, assuming all else was equal (which we now know it isn’t).
Re: My23 brakes [Re: Derek596] #767440
22/01/23 08:35 AM
22/01/23 08:35 AM
CLPlusFour Offline
CLPlusFour  Offline
Thanks Matt for the link. thumbs This is of course exactly the manual I have.
I must confess I have not paid any attention to the general technical specification. That was as I must now realize very stupid of me. banghead
In any case, it is now definitely clear that a PlusFour front and rear one piston brake is installed.
I look next time in the books before I dismantle tires
Clemens
PlusFour MY 2022
Re: My23 brakes [Re: MattB] #767443
22/01/23 09:03 AM
22/01/23 09:03 AM
RichardV6 Offline
RichardV6  Offline
If I had these calipers fitted to my car I don't think I would want to advertise the fact with fancy colour options innocent
Looking at historical and current facts. All the trad range until their demise had four piston calipers at the front. The Plus Six still does apparently. The Plus Four has many complaints of brake performance. I don't subscribe to the excuses of cost or unsprung weight which would be minimal. If I'm missing something in the bigger picture I would love to know what it is confused2
Re: My23 brakes [Re: Derek596] #767444
22/01/23 09:20 AM
22/01/23 09:20 AM
MattB Offline
MattB  Offline
Don’t the trads have drum brakes at the rear?
Re: My23 brakes [Re: MattB] #767446
22/01/23 10:10 AM
22/01/23 10:10 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Yes - and all that's needed. ARP4 was the only road car exception.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: My23 brakes [Re: Derek596] #767449
22/01/23 10:25 AM
22/01/23 10:25 AM
West Somerset
Davetherave Offline
Davetherave  Offline
West Somerset
Last week while checking the underside of the Plus Six for a pre MOT lookover. I can confirm the Plus Six does have 4 pot calipers on the front, they are of a overall physical size similar to the Caparo 4 pots fitted to the 3.7 Roadster, but the Plus Six caliper 4 pot has a different manufacturer marking.. The Plus Six rear caliper has a mechanical cable operated handbrake mechanism integral to the caliper, it appears to be single pot, but I did not see a slider or slider pins to allow it to equalize as pressure is applied to operate the brake, but at the time I was not looking specifically to see how the rear operated. Just a quick lookover to make sure everything was secure and not leaking etc.. The wheels are back on now, so I missed the opportunity to take a second look. I see looking at the website for 920E as previously posted that they were originally AP then became Caparo and now 920E their web site does not show examples of all their calipers as some images are missing.
Dave
Plus 6 "Squeak"
Roadster departed.
Re: My23 brakes [Re: RichardV6] #767451
22/01/23 10:41 AM
22/01/23 10:41 AM
Luddite Offline
Luddite  Offline
My mid 80`s +8 Trad has two pot callipers, drums on the rear, no servo or ABS, has good firm pedal action to the extent that I can lock the wheels, which I know is not the best possible braking action. When multi-pot calipers became available for Mogs on the aftermarket, I imagined that they might just equate to locking the wheels with less pedal pressure, a subject Colin AKA spanner juggler engaged in some years back.. I have memory issues, though think Colin suggested that more pots in the callipers equated to more pedal "feel" in the braking process, though how that might work in panic braking... Hmm..?
Re: My23 brakes [Re: Derek596] #767452
22/01/23 10:55 AM
22/01/23 10:55 AM
RichardV6 Offline
RichardV6  Offline
I always assumed the extra pots were needed to apply even pressure over the longer pads used George, hence four, six and even eight pot.
By increasing pad area a lesser hydraulic brake pressure can achieve the same retardation so allowing increased feel. Careful choice of master to slave cylinder ratio together with increased feel would not increase likelihood of brakes locking, but would probably reduce brake fade given increased pad contact area.
Re: My23 brakes [Re: Derek596] #767462
22/01/23 12:28 PM
22/01/23 12:28 PM
Luddite Offline
Luddite  Offline
Richard, from that which you typed above It seems we may agree, in that more pots and larger pads per calliper can relate to less pedal pressure to create a similar effect than a calliper with fiewer pots ..? That being the case it would seem that fitting multipot callipers to a pre ABS Morgan might as I suggested equate to quicker lock-up under panic braking..?
Re: My23 brakes [Re: Derek596] #767478
22/01/23 02:43 PM
22/01/23 02:43 PM
RichardV6 Offline
RichardV6  Offline
In fairness I did suggest above George that choice of master to slave ratio (read mechanical advantage) could be tailored to not increase likelihood of lock up in panic situation.
Re: My23 brakes [Re: Derek596] #767482
22/01/23 03:35 PM
22/01/23 03:35 PM
Luddite Offline
Luddite  Offline
Richard, thanks for taking the time to respond, very much appreciated, your fair mindedness was never in doubt..
I wonder how many if any who retro fitted multi-pot callipers to their Morgans, or any other car, even contemplated fitting an alternative master cylinder...?
I on the other hand would have done, as the result of fitting a new master cylinder to a Mk1 Ford Escort, many years ago, when according to the part number the cylinder supplied was the correct part for the year of manufacture, but the brake pedal travel was discovered to be excessive after I fitted it...? With a bit of investigation I found that Ford had changed the bore of the master cylinder mid year and I had been supplied with the wrong part, which looked very similar.
If designing a multi-pot calliper for the aftermarket it may just be a consideration to ensure that the overall fluid displacement required is similar to that of the original larger cylinders, or perhaps just a tad more, thinking that a little bit more pedal travel might be acceptable... Other than that, selling multi-pot callipers to the home mechanic/enthusiast which also required the expense of upgrading to a matched master cylinder, could cause folk to think of reassessing the initial purchase decision, and risk reducing sales of the calliper..?
As ever just thinking in type.
Re: My23 brakes [Re: Luddite] #767489
22/01/23 04:33 PM
22/01/23 04:33 PM
RichardV6 Offline
RichardV6  Offline
I agree that by adopting larger total piston area of calipers compared to OE you will increase pedal travel. However this also means you are increasing mechanical advantage. In so doing you have the double whammy of increased likelihood of locking brakes from both the mechanical advantage and likely increased pad area if upgrading from say two to four pot. A reduction in caliper piston area would be better, or a more than compensating increase in master cylinder piston size.
As an example many years ago I improved the braking on my Guzzi Spada touring bike by fitting P09 Brembo calipers up front, an increase from 38 to 42mm pistons and attendant larger pads. I also increased master cylinder size from 15 to 17mm though to compensate and leave similar lever movement.
I do wonder if this may explain the dissapointment others have felt after fitting expensive caliper/disc upgrades to their Classics. If the new calipers have smaller pistons the pedal will feel very hard but requiring a heavier foot than previously. Possibly not what they were expecting!
Re: My23 brakes [Re: RichardV6] #767524
22/01/23 10:47 PM
22/01/23 10:47 PM
MattB Offline
MattB  Offline
Well I’d certainly be looking for wheels that hide those as much as possible innocent wink
Obviously I’m jesting there, as the reason I originally wanted the coloured callipers was purely for aesthetics with the black wheels. On one of my spec options the idea was to link a flash of that colour with some stitching on the inside. Very un-Morgan, I’m afraid. What’s funny though is how people go for big brake kits with multi-piston callipers for aesthetic reasons, as opposed to upgrading for performance. Floating single piston callipers are not new on some performance cars, even a premium and heavy one known as the E92 M3 if my memory serves me right (the V8 one). Granted there aren’t many and certainly not in recent years that stand out.
I dare say Morgan chose this spec due to cost, although looking at it in the garage the piston is fairly large and there isn’t much room between the calliper and the alloy in the Plus Four design. Yet there is so much more to outright braking performance and resistance to fade than how many pistons are used, and the desire for many to simplify this in the world of tuning is misplaced. The lack of symmetry in clamping force, flexing and reduced distribution of pressure of course influence braking feel, but as you know there are many factors that will influence the overall braking performance and fade resistance. Pad compound/material and friction, heat management and dissipation/cooling, swept area, front/rear balance, fluid, tyres etc, even ignoring the influence of things like weight transfer and dive/damping. On paper yes the Plus Four callipers lack headline grabbing technical specs (in comparison to my other cars they are very under spec) and are hardly anything you’d want to show off as performance car brakes in flashy colours, but subjectively in normal road use I find mine effective and measured if not a standout feature. I also found them to be better than I expected on the driving academy at Bicester, maintaining good bite and performance lap after lap at ‘well’ beyond road speeds. Maybe I got lucky as they do seem better than that hire one I had 18 months ago, although I can’t be alone as I recall some reviews have been positive about braking too. That said I’ll definitely consider future upgrades if only for the fact I want to create a Plus Four that is even more performance orientated in time. Suspension first though; very un-Morgan again. I also recognise the best way to improve braking and performance generally will be to upgrade the driver first (me!) and I’d argue that will be the same for most on here.
Objectively who knows; I’ll assume that none of us have the data from controlled test environments to understand how they compare in repeated high speed stops vs the 4-pot/drum-equipped trads or other cars. Maybe I should try and borrow a vBox and Mira proving grounds.
As a slight aside my GR Yaris went in for a service last week and I was given a normal Yaris Hybrid as a courtesy car. The difference in braking setup was so stark, with the Hybrid having such sharp and over servoed brakes that I nearly went through the windscreen just navigating the forecourt. Horrid set up.
I hope those that have issues or find the braking not to their liking do get it resolved satisfactorily. Equally I hope we can all get out soon and enjoy our Morgan’s whatever flavour we have (said from a very icy part of the UK currently).
PS, Clemens you’re more than welcome on the link to the manual, I found it surprising just how much tech detail was in that. I recalled seeing the braking details when trying to read up as much as I could when waiting for build news during the recall.
Page 1 of 16 1 2 3 15 16
