Morgan Aero 8
1 registered members (Bitsobrits), 123 guests, and 13 spiders.
+8Rich 123
John V6 104
OZ 4/4 100
8359 Registered Users
One for the Morgan Boy Racers..
by +8Rich. 30/05/23 11:00 PM
Green S1, based in London, spotted in Cotswolds
by verysideways. 30/05/23 08:56 PM
Roll Bars
by IvorMog. 30/05/23 08:01 PM
Used car purchase scam?
by KennethM. 29/05/23 09:50 PM
M3W - check the following
by Chris99. 29/05/23 05:12 PM
4/4 Four seater outdoor car cover
by Tim W. 29/05/23 08:11 AM
Book recommendation..
by +8Rich. 28/05/23 01:29 PM
Spotted In Amboise Loire
Wiscombe Park
Sod the rain
Forums32
Topics45,130
Posts764,432
Members8,359
Most Online1,033
Dec 28th, 2019
7024, hbatts
Aero Headlights #765312
23/12/22 10:27 PM
23/12/22 10:27 PM
CSGS Offline OP
CSGS  Offline OP
Does anyone know what vehicle the headlight assemblies on a USA Spec 2005 Aero 8 are from? Would like to replece the entire assembly.
Re: Aero Headlights [Re: CSGS] #765324
23/12/22 11:55 PM
23/12/22 11:55 PM
Taffmog Offline
Taffmog  Offline
BMW MINI if similar to UK models.Series 1 and 2 Aeros were VW ('new') Beetle.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Re: Aero Headlights [Re: CSGS] #765337
24/12/22 08:37 AM
24/12/22 08:37 AM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
2005 US Aero were the same as a UK Series 2.
Modern VW Beetle.
Be gentle fitting them as too much tension in the mounting can crack the glass from the body.
Some gratuitous S2 pictures for the sake of it.
Re: Aero Headlights [Re: CSGS] #765346
24/12/22 10:00 AM
24/12/22 10:00 AM
Newcastle Upon Tyne
James B W Offline
James B W  Offline
Newcastle Upon Tyne
and don't forget that ,with the VW Beetle lights -
VW N/S is Morgan O/S and VW O/S is Morgan N/S
- not confusing at all doh
I would also echo Alistair's advice re. over tightening; it is very easy to split the grey rubber/plastic seal if too much tension is applied.
I seem to recall that Nick had real difficulty in sourcing new replacements a year or so back;I don't know if the supply has improved.....
James
Range Rover Evoque S
Smart Brabus Convertible
Honda Monkey Z125
Re: Aero Headlights [Re: James B W] #767327
20/01/23 01:50 PM
20/01/23 01:50 PM
Buckinghamshire
NickCW Offline
NickCW  Offline
Buckinghamshire
James
If you want genuine ones be prepared to spend 6 months searching far and wide... if you don't mind aftermarket alternatives they can be sourced easily enough last time I looked.
Most will require a bit of filing to fit flush against the wings, otherwise they can sit a bit proud in places.
Hopefully mine are ok when I eventually drive it, had to do them up tight to get a nice flush fitting!
Aero 8 S1
Re: Aero Headlights [Re: CSGS] #767329
20/01/23 02:13 PM
20/01/23 02:13 PM
NE Scotland
Ewan Offline
miles of smiles
Ewan  Offline
miles of smiles
NE Scotland
Not suitable in this particular case, but if anyone needs them I have a pair of early BMW mini headlights, free to good home.
Re: Aero Headlights [Re: NickCW] #767353
20/01/23 07:33 PM
20/01/23 07:33 PM
People's Republic of South Yor...
CooperMan Offline
CooperMan  Offline
James
Probably best to pop to you local friendly MOT chap when the lightpods have bedded in, to have the headlight aim checked
Re: Aero Headlights [Re: Ewan] #767370
21/01/23 11:50 AM
21/01/23 11:50 AM
Oxford, UK
hashluck Offline
hashluck  Offline
Oxford, UK
Hi Ewan, have sent you a PM as will be fault-finding a headlamp failure on my 2015 Aero Coupe next week.
Re: Aero Headlights [Re: CooperMan] #768015
28/01/23 11:29 AM
28/01/23 11:29 AM
Buckinghamshire
NickCW Offline
NickCW  Offline
Buckinghamshire
James
Absolutely, any new lights/bulbs will need a proper allignment.
In all honesty I haven't driven it on the road in coming up for a year, as I have other bits and pieces planned - but family life is in the way at the moment, so its on the to do list..
Aero 8 S1
Re: Aero Headlights [Re: CSGS] #768039
28/01/23 03:22 PM
28/01/23 03:22 PM
Oxford, UK
hashluck Offline
hashluck  Offline
Oxford, UK
Well my headlamp 'failure' on the 2015 Aero Coupe turned out to be quite simple. Morgan Works had not plugged it back in properly after the last service visit and the connector was dangling around in the wheelarch! It took longer to jack the car up and take the wheel off than fix the issue. Annoying but glad it was as simple as that. Works also conspired to not adjust the locks correctly after some work, as the passenger door never locked and the driver door would not unlock. There is a very curious 'adjustment' system to get the actuator rod in literally just the right place. I am sure the factory are used to it but took a lot of trial and error.
