0 registered members (),
119
guests, and 13
spiders. |
Topics44,601
Posts754,507
Members8,264
Most Online1,033 Dec 28th, 2019
Re: Aero Headlights
[Re: CSGS]
#765324
23/12/22 11:55 PM
23/12/22 11:55 PM
Posts: 2,140 Wales
Taffmog
BMW MINI if similar to UK models.Series 1 and 2 Aeros were VW ('new') Beetle.
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Re: Aero Headlights
[Re: CSGS]
#765337
24/12/22 08:37 AM
24/12/22 08:37 AM
Posts: 10,032 Hampshire
Alistair
Smile, it confuses them
Hampshire
2005 US Aero were the same as a UK Series 2. Modern VW Beetle. Be gentle fitting them as too much tension in the mounting can crack the glass from the body. Some gratuitous S2 pictures for the sake of it. ![[Linked Image]](https://www.tm-img.com/images/2018/10/31/AeroS2LowFront.jpg) ![[Linked Image]](https://www.tm-img.com/images/2022/12/24/5a706043.jpeg)
Re: Aero Headlights
[Re: CSGS]
#765346
24/12/22 10:00 AM
24/12/22 10:00 AM
Posts: 1,673 Newcastle Upon Tyne
James B W
Newcastle Upon Tyne
and don't forget that ,with the VW Beetle lights - VW N/S is Morgan O/S and VW O/S is Morgan N/S - not confusing at all  I would also echo Alistair's advice re. over tightening; it is very easy to split the grey rubber/plastic seal if too much tension is applied. I seem to recall that Nick had real difficulty in sourcing new replacements a year or so back;I don't know if the supply has improved..... James
Aero8 , Series 1 - Boston Green Range Rover Evoque S Smart Brabus Convertible Honda Monkey Z125
Re: Aero Headlights
[Re: James B W]
#767327
20/01/23 01:50 PM
20/01/23 01:50 PM
Posts: 1,853 Buckinghamshire
NickCW
Buckinghamshire
and don't forget that ,with the VW Beetle lights - VW N/S is Morgan O/S and VW O/S is Morgan N/S - not confusing at all  I would also echo Alistair's advice re. over tightening; it is very easy to split the grey rubber/plastic seal if too much tension is applied. I seem to recall that Nick had real difficulty in sourcing new replacements a year or so back;I don't know if the supply has improved..... James If you want genuine ones be prepared to spend 6 months searching far and wide... if you don't mind aftermarket alternatives they can be sourced easily enough last time I looked. Most will require a bit of filing to fit flush against the wings, otherwise they can sit a bit proud in places. Hopefully mine are ok when I eventually drive it, had to do them up tight to get a nice flush fitting!
Aero 8 S1
Re: Aero Headlights
[Re: NickCW]
#767353
20/01/23 07:33 PM
20/01/23 07:33 PM
Posts: 5,655 People's Republic of South Yor...
and don't forget that ,with the VW Beetle lights - VW N/S is Morgan O/S and VW O/S is Morgan N/S - not confusing at all  I would also echo Alistair's advice re. over tightening; it is very easy to split the grey rubber/plastic seal if too much tension is applied. I seem to recall that Nick had real difficulty in sourcing new replacements a year or so back;I don't know if the supply has improved..... James If you want genuine ones be prepared to spend 6 months searching far and wide... if you don't mind aftermarket alternatives they can be sourced easily enough last time I looked. Most will require a bit of filing to fit flush against the wings, otherwise they can sit a bit proud in places. Hopefully mine are ok when I eventually drive it, had to do them up tight to get a nice flush fitting! Probably best to pop to you local friendly MOT chap when the lightpods have bedded in, to have the headlight aim checked
Re: Aero Headlights
[Re: Ewan]
#767370
21/01/23 11:50 AM
21/01/23 11:50 AM
Posts: 42 Oxford, UK
hashluck
Oxford, UK
Not suitable in this particular case, but if anyone needs them I have a pair of early BMW mini headlights, free to good home. Hi Ewan, have sent you a PM as will be fault-finding a headlamp failure on my 2015 Aero Coupe next week.
