17 registered members (MJF, PeteMalvern, teifistar, TBM, Chris99, verysideways, Grumpy2, Robbie, RichardV6, OZ 4/4, +4competion, paulmog, GrumpyPa, Gambalunga, Montegue, yrr13, nippymog), 147 guests, and 18 spiders.
+8Rich 236
John V6 136
OZ 4/4 115
CooperMan 107
RichardV6 104
Stephen Beckett, Modesto, Wheelybin, Bonnie66, RichT56
8325 Registered Users
Monty Gets Further Developments
by Montegue. 01/04/23 08:24 AM
Owners Handbook Surprise
by Ron C. 31/03/23 07:13 PM
Rest shock absorber adjustment
by Topline123. 31/03/23 05:55 PM
rear shocks
by Grumpy2. 31/03/23 04:33 PM
Super Duper 3 launch tomorrow..
by +8Rich. 31/03/23 02:52 PM
Smart Meter Fun
by DaveW. 31/03/23 11:52 AM
M3W season '23 started! (@ 7 °C), 12.02.2023
Rat Rod style Threewheeler
Bimble to the New Forest
Brum by the sea
LM62
Topics44,895
Posts759,844
Members8,325
Most Online1,033
Dec 28th, 2019
Wingman
Page 3 of 3 1 2 3
Re: Heater Control [Re: Craig Jezz] #767556
23/01/23 12:05 PM
23/01/23 12:05 PM
I
IcePack Offline
IcePack  Offline
I
[Linked Image<br>See the smaller lower wire. This is the other end of the “Bowden” cable from the dash control. I used some mintex brake grease to lube the cable. It is high temperature tolerant. You gain access via a heater vent, which are held in via a spring clip across the back.</div>
<br>
</div>
<div class=
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: Heater Control [Re: Craig Jezz] #767558
23/01/23 12:08 PM
23/01/23 12:08 PM
I
IcePack Offline
IcePack  Offline
I
Funny my text gone missing.
Smaller wire is the other end of “Bowden” cable from the dash control i lubed it using mintex brake grease as high temp tolerant. Access via one of the vents that are held in via a spring clip across the back.
Mind you Morgan have changed how they control the heater every 5 mins it would seem. Mine 2011 4/4
Re: Heater Control [Re: Craig Jezz] #767559
23/01/23 12:17 PM
23/01/23 12:17 PM
I
IcePack Offline
IcePack  Offline
I
The removed Vent.
[Linked Image</div>
<br>
</div>
<div class=
Re: Heater Control [Re: Craig Jezz] #767667
24/01/23 09:41 PM
24/01/23 09:41 PM
Banham, Norfolk
Themorganeer Offline
Banham, Norfolk
What’s the technique for removing and replacing these vents in their housing box?
Chris
2015 Plus4
Re: Heater Control [Re: Craig Jezz] #767672
24/01/23 10:43 PM
24/01/23 10:43 PM
East Harling, Norfolk UK
RichardV6 Online NoMood
By the look of it Chris, a similar technique to fitting/removing ceiling spot lights. Typically two spring loaded tangs grip and hold blindly in place. Gently prizing out one side of fitting then bending tangs towards each other when able should allow withdrawal.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: Heater Control [Re: Craig Jezz] #767754
25/01/23 08:39 PM
25/01/23 08:39 PM
Banham, Norfolk
Banham, Norfolk
Agreed - it must be as you say Richard.
It was access to the tangs that I struggled with in an incredibly awkward location.
Chris
2015 Plus4
Re: Heater Control [Re: Craig Jezz] #767872
26/01/23 07:20 PM
26/01/23 07:20 PM
I
IcePack Offline
IcePack  Offline
I
The way I got it to release was to gently pull the vent until the frame was released. Then move it to one side & using long nosed pliers, “jiggled” the wire free. Then move the vent unit the other way until it releases. Replacing is the opposite, but caution the wire clip does not interfere with the heater controls.
Mine was also a bit brittle & getting oneself across the seats on your side with both arms free was kind of entertaining.
Re: Heater Control [Re: IcePack] #767878
26/01/23 08:11 PM
26/01/23 08:11 PM
Banham, Norfolk
Banham, Norfolk
I know the feeling 🤪
Chris
2015 Plus4
Page 3 of 3 1 2 3
