0 registered members (),
142
guests, and 14
spiders. |
Topics44,601
Posts754,507
Members8,264
Most Online1,033 Dec 28th, 2019
Re: Heater Control
[Re: Craig Jezz]
#767558
23/01/23 12:08 PM
23/01/23 12:08 PM
IcePack
Funny my text gone missing. Smaller wire is the other end of “Bowden” cable from the dash control i lubed it using mintex brake grease as high temp tolerant. Access via one of the vents that are held in via a spring clip across the back. Mind you Morgan have changed how they control the heater every 5 mins it would seem. Mine 2011 4/4
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: Heater Control
[Re: Craig Jezz]
#767667
24/01/23 09:41 PM
24/01/23 09:41 PM
Posts: 357 Banham, Norfolk
Themorganeer
Banham, Norfolk
What’s the technique for removing and replacing these vents in their housing box?
Chris 2015 Plus4
Re: Heater Control
[Re: Craig Jezz]
#767672
24/01/23 10:43 PM
24/01/23 10:43 PM
Posts: 5,677 East Harling, Norfolk UK
By the look of it Chris, a similar technique to fitting/removing ceiling spot lights. Typically two spring loaded tangs grip and hold blindly in place. Gently prizing out one side of fitting then bending tangs towards each other when able should allow withdrawal.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
Re: Heater Control
[Re: Craig Jezz]
#767754
25/01/23 08:39 PM
25/01/23 08:39 PM
Themorganeer
Banham, Norfolk
Agreed - it must be as you say Richard.
It was access to the tangs that I struggled with in an incredibly awkward location.
Chris 2015 Plus4
Re: Heater Control
[Re: Craig Jezz]
#767872
26/01/23 07:20 PM
26/01/23 07:20 PM
IcePack
The way I got it to release was to gently pull the vent until the frame was released. Then move it to one side & using long nosed pliers, “jiggled” the wire free. Then move the vent unit the other way until it releases. Replacing is the opposite, but caution the wire clip does not interfere with the heater controls. Mine was also a bit brittle & getting oneself across the seats on your side with both arms free was kind of entertaining.
Re: Heater Control
[Re: IcePack]
#767878
26/01/23 08:11 PM
26/01/23 08:11 PM
Themorganeer
Banham, Norfolk
I know the feeling 🤪
Chris 2015 Plus4
