15 registered members (James B W, Alistair, Ncik P, MATTMOG, rossocorsa, IanClarkeUSA, TBM, tommog, Ricardo, CRL, Image, DavidR, mph, Ruut Bianchi, Gordon D), 150 guests, and 10 spiders.
+8Rich 118
John V6 100
OZ 4/4 99
8359 Registered Users
A different kind of mini
by PaulyG. 31/05/23 12:25 PM
look what I have bought
by B3MOG. 31/05/23 12:23 PM
Check out post in Facebook re Tour
by Morgan110. 31/05/23 10:50 AM
Two Plus 8's one a Speedster.
by +8Rich. 31/05/23 09:02 AM
One for the Morgan Boy Racers..
by +8Rich. 30/05/23 11:00 PM
Green S1, based in London, spotted in Cotswolds
by verysideways. 30/05/23 08:56 PM
Roll Bars
by IvorMog. 30/05/23 08:01 PM
Spotted In Amboise Loire
Wiscombe Park
Sod the rain
Forums32
Topics45,134
Posts764,466
Members8,359
Most Online1,033
Dec 28th, 2019
7024, hbatts
Serpentine Belt etc #768037
28/01/23 03:05 PM
28/01/23 03:05 PM
I
IcePack Offline OP
IcePack  Offline OP
I
Anyone know the part No, for the serpentine auxiliary belt on the sigma engine.2011 4/4 and indeed the tensioner unit and pulley.
I can't quite read the belt No: 6PK1203 or 6PK1208. As for the tensioner well much googling with no luck, except an eye watering priced Caterham one that looks similar.
why am I looking, well a rather noisy front of engine on cold start. Quietens once warm, but still a rather noise pulley.
thanks in advance
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: Serpentine Belt etc [Re: IcePack] #768042
28/01/23 03:45 PM
28/01/23 03:45 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
When I needed a belt for my Feb-14 4/4 with the 1.6 Sigma engine, BHM supplied a Gates 6PK1203 belt which fitted perfectly.
Do you get a squeal on start up that goes away very quickly? If so, it may be that all you need is the belt.
If you need the tensioner unit, have you tried Burton Power ?
Also, Ford have an eBay shop for parts.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Re: Serpentine Belt etc [Re: IcePack] #768062
28/01/23 07:45 PM
28/01/23 07:45 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
As I have said on another recent thread, the 6 is the number of ribs and the 1203 is the length. It is important to get that correct as the tensioner is simply spring loaded so if you get one too long, it will end up floppy..
You don’t say what sort of noise you are experiencing. If it’s a squeal, then it could be the belt slipping under load, typical of when the alternator is working hard to recharge the battery after starting. i.e battery is in poor state of charge.
If you have a squeal, a small squirt of WD40 on the belt whilst running may immediately quieten it. No cure, but rules out the pulley and tensioner.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Serpentine Belt etc [Re: IcePack] #768063
28/01/23 08:06 PM
28/01/23 08:06 PM
Lancashire
RobCol Offline
RobCol  Offline
Lancashire
OEM part for 4/4 Sigma V belt is a Gates 6PK 1203. Fitted in 5 minutes from memory a 15 mm socket on the tensioner
Rob
4/4 Sport Grey
Re: Serpentine Belt etc [Re: IcePack] #768064
28/01/23 08:16 PM
28/01/23 08:16 PM
I
IcePack Offline OP
IcePack  Offline OP
I
Great thanks for the belt no. The noise on start when cold is like a dry bearing with no squeal, but also has a clack clack noise superimposed. The clack clack almost disappears after a while but leaves the dry grating noise which also almost disappears after a run. Getting head quite close it does sound like the tensioner pulley. However it is definitely from the front of the engine. Other culprits may be the cam belt tensioner. (Cam belt changed 2 years ago) or the auxiliary idler wheel.
If I can get at least a new belt & pulley, I will have a go at running the engine without the belt for a short while from cold. Oh I am fairly sure it is not the variable cam actuators.
