10 registered members (PPD, Mike D, smudger1, KennethM, John07, Grumpy2, JohnPlus8, rossocorsa, SFG, Mogdavid),
67
guests, and 13
spiders. |
Topics44,897
Posts759,877
Members8,325
Most Online1,033 Dec 28th, 2019
LED Headlights v Beam Deflectors
#768323
01/02/23 09:48 AM
01/02/23 09:48 AM
Posts: 104 North of the Wall, UK
ProfessorM
Morning all
Here's a question for all M3W's and Super 3's who have LED headlights in the UK...
Do you need to fit beam deflectors when travelling in Europe, or (as some web searching suggests) LED headlights tend to have flatter beams so do not require them?
Your thoughts/knowledge would be greatly appreciated!
Heron Grey & Typhoon British Green Super 3 !
Re: LED Headlights v Beam Deflectors
[Re: ProfessorM]
#768346
01/02/23 02:44 PM
01/02/23 02:44 PM
Posts: 1,576 Oxon
PaulV
Oxon
I think you will find the "flat pattern" LED headlights are either US spec or for motorbikes. AFAIK there is no aftermarket LED headlamp unit that includes a switch for LHD vs RHD like you see in some conventional cars - you need the beam deflector...
[Re: ProfessorM]
#768365
01/02/23 07:29 PM
01/02/23 07:29 PM
Posts: 5,890 East Harling, Norfolk UK
My parallel test of OE halogen and replacement dedicated LED headlamps revealed the cut offs were very similar in shape, just more defined with the LED optics and for good reason given brightness.
If I travelled abroad regularly I would be tempted to buy a cheap pair of LHD headlamps with matching connectors to allow quick swap.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
[Re: ProfessorM]
#768371
01/02/23 08:09 PM
01/02/23 08:09 PM
ProfessorM
Thanks all for your wisdom and examples. I think I'll err on the side of caution and just put the deflectors on. On reflection it saves a complex conversation in broken French with local police...!
[Re: ProfessorM]
#768380
01/02/23 09:11 PM
01/02/23 09:11 PM
Posts: 3,737 Port Orchard, WA.
LightSpeed
Port Orchard, WA.
Halogen Vs OEM lamps in the OEM buckets. Low Beams. ![[Linked Image]](https://www.tm-img.com/images/2022/02/03/LowBeam.jpg) High Beams ![[Linked Image]](https://www.tm-img.com/images/2022/02/03/HighBeam.jpg) Halogen Lamps that were discussed in previous Threads. Inexpensive, light weight and work fairly well.
[Re: LightSpeed]
#768381
01/02/23 09:17 PM
01/02/23 09:17 PM
Posts: 1,576 Oxon
PaulV
Oxon
...Halogen Lamps that were discussed in previous Threads. Inexpensive, light weight and work fairly well. Indeed. Took mine (M3W, standard halogen bulbs) for a night time run to the local MTWC meetup. Didnt miss anything except maybe range on low-beam causing me to slow down to 50 in the countryside with oncoming traffic... but that in itself is no bad thing.
[Re: ProfessorM]
#768384
01/02/23 09:32 PM
01/02/23 09:32 PM
LightSpeed
Port Orchard, WA.
If I need more power I can pull off the amber lens covers and go for super bright. ![[Linked Image]](https://www.tm-img.com/images/2021/07/15/FogsMorgan.jpg) Hella LED Lamps.
