Morgan Aero 8
1 registered members (Bitsobrits), 123 guests, and 13 spiders.
+8Rich 123
John V6 104
OZ 4/4 100
8359 Registered Users
One for the Morgan Boy Racers..
by +8Rich. 30/05/23 11:00 PM
Green S1, based in London, spotted in Cotswolds
by verysideways. 30/05/23 08:56 PM
Roll Bars
by IvorMog. 30/05/23 08:01 PM
Used car purchase scam?
by KennethM. 29/05/23 09:50 PM
M3W - check the following
by Chris99. 29/05/23 05:12 PM
4/4 Four seater outdoor car cover
by Tim W. 29/05/23 08:11 AM
Book recommendation..
by +8Rich. 28/05/23 01:29 PM
Spotted In Amboise Loire
Wiscombe Park
Sod the rain
Forums32
Topics45,130
Posts764,432
Members8,359
Most Online1,033
Dec 28th, 2019
7024, hbatts
Page 3 of 4 1 2 3 4
Re: CAT delete. [Re: Viper] #769396
16/02/23 10:37 AM
16/02/23 10:37 AM
Cotswolds, UK
verysideways Offline
Cotswolds, UK
Over here as long as it passes the MOT every year (inspection) then you’re fine.
Most of these cars will pass that emissions check with one cat and some heat - so make sure you drive hard on the way to the test and get the cat hot 😁
2002 Aero 8 S1, chassis number 96 - Ragusa Green Metallic
Re: CAT delete. [Re: Viper] #769399
16/02/23 12:59 PM
16/02/23 12:59 PM
Sevenoaks,Kent
Viper Offline OP
Sir S1'a'lot
Viper  Offline OP
Sir S1'a'lot
Sevenoaks,Kent
I think now though if an MOT tester sees that a CAT has been deleted then it’s a fail
Super 3 soon
2002 Aero 8 S1
Re: CAT delete. [Re: Viper] #769414
16/02/23 04:54 PM
16/02/23 04:54 PM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
I am aware of people who de-cat new cars as they have the three year period (soon to be four if you follow the gov's recent crap review of the MoT process) and enjoy the additional fun. Given the rules around car exhaust volume now in place it needs something to provide aural enjoyment. How the Aero dual sidepipes ever pass is a mystery to me.
Once into MoT they are getting very fussy now. A couple of GTR owners I speak to have a section of the exhaust made up where the cat has been removed. Each year prior to the MoT they slip the cat back in and take the test. Once approved it comes back off and the blank is fitted again. The engine map is selected for no CAT and the thing sounds just naughty. One did try and get buy with a hot engine and tight engine map but it was failed.
Re: CAT delete. [Re: Viper] #769419
16/02/23 07:38 PM
16/02/23 07:38 PM
Sevenoaks,Kent
Viper Offline OP
Sir S1'a'lot
Viper  Offline OP
Sir S1'a'lot
Sevenoaks,Kent
Everyone needs a friendly MOT man
Super 3 soon
2002 Aero 8 S1
Re: CAT delete. [Re: Viper] #769515
18/02/23 10:39 AM
18/02/23 10:39 AM
Buckinghamshire
NickCW Offline
NickCW  Offline
Buckinghamshire
The replacement bypass pipe is a good option if you don't have a friendly tester, or 4 sports cats I guess but that seems expensive..
I guess they other way round is to just bash out the insides of one and then you don't need any new bits, and visually it looks the same. cheers
Aero 8 S1
Re: CAT delete. [Re: Viper] #769550
18/02/23 04:51 PM
18/02/23 04:51 PM
aerotaff Offline
aerotaff  Offline
I was never a very good mechanic a lifetime ago but here goes. Don't bash the insides out, if you must take the box off cut with a grinder from the middle out so you can see the baffles then access the box and remove the plates carefully when the box is empty weld a plate back to the box. This is best done on the top of the box so when it is re fitted it still looks stock from the underneath.Be aware your engine may run a little leaner and therefore hotter whip your plugs out after a tank full and you should have your answer. Personally if you have sports cats and a sports exhaust I would leave well alone but we all have choices.It will sound good though...
Re: CAT delete. [Re: Viper] #769552
18/02/23 05:10 PM
18/02/23 05:10 PM
aerotaff Offline
aerotaff  Offline
Also if its a stainless exhaust weld back a stainless plate back on unless you did a good job with the grinder so the original might just fit.
Re: CAT delete. [Re: Viper] #769560
18/02/23 06:09 PM
18/02/23 06:09 PM
Sevenoaks,Kent
Viper Offline OP
Sir S1'a'lot
Viper  Offline OP
Sir S1'a'lot
Sevenoaks,Kent
I’m not going to cut or bash an existing CAT just in case it needs to go back on.
An MOT tester can’t see anything untoward as it’s all hidden on an aero
Super 3 soon
2002 Aero 8 S1
Re: CAT delete. [Re: Viper] #769562
18/02/23 06:20 PM
18/02/23 06:20 PM
aerotaff Offline
aerotaff  Offline
Sorry Viper should have read the post more closely I thought Nick was talking about the box not the cat. My cat was clearly visible from under the car well half of it was...,
Re: CAT delete. [Re: Viper] #770542
04/03/23 12:45 PM
04/03/23 12:45 PM
Buckinghamshire
NickCW Offline
NickCW  Offline
Buckinghamshire
So have you done it yet.. innocent
Aero 8 S1
Page 3 of 4 1 2 3 4
