6 members (Graham, G4FUJ, Mikemog6, Ubiquitous, Socalm3w, dmh, petemog), 198 guests, and 10 robots.
+8Rich 137
OZ 4/4 120
John V6 116
8,359 Registered Users
2.0L Duratec Lambda Sensor
by carchap - 08/06/23 04:30 AM
Beware the rogue pothole!
by vincentvg - 06/06/23 08:16 PM
Keep spotting Aeros!
by verysideways - 06/06/23 05:46 PM
Archaic immobiliser
by Tonyh157 - 06/06/23 11:06 AM
Thanks to All.
by kiwi100 - 06/06/23 03:17 AM
by Neil49 - 06/06/23 12:02 AM
Carpets and Headrests
by C2RM - 05/06/23 08:37 PM
Head rest
Head rest
by JMcL, June 6
Spotted In Amboise Loire
by Clipper, May 28
Wiscombe Park
Wiscombe Park
by griffo, May 22
Forums32
Topics45,166
Posts765,009
Members8,359
Most Online1,033
Dec 28th, 2019
Hi all,
I've just had a call from my exhaust fabricator who is also creating an induction modification on my 2012 Plus 4. He's about to remove the whole factory airbox assembly but wants to know if he needs to remove the bonnet to do so?
Can someone confirm if the factory airbox can be removed without the bonnet coming off, or does it need to be removed?
thinking
Thanks, Dave.
Rog Offline
Yes this monstrosity can be wiggled out with the bonnet in place. Worth lifting the coil pack and binning the mount bracket too.
Roger
RJW Offline
I removed mine with bonnets in place. Glad to see the back of it. ITG intake filter now fitted which takes supposedly cooler air via the gap above the radiator.
Bob.
Bob.
The air above the radiator may be cooler, but there isn’t so much of it as it gets diverted over the top of the cowl.
Anyone interested in airflow over a Morgan body could have a look at the “Morganatica” site. Under section 02 entitled “Bodywork & Chassis”, click on “Aerodynamics”. There you will find an extremely interesting and revealing paper by Duncan Charlton. He has carried out some very extensive research into airflow over a Morgan body. As well as showing that airflow at the top of the cowl grille is minimal, he also finds that covering of the spare wheel hole actually diminishes top speed; other useful bits like how to simply decrease wind in the face from the sidescreen area. Well worth a read.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Excellent chaps, I've passed the information on to Matt at Fusion Fabrications thumbs
Bob.
What an informative article. I will be fitting a different air filter arrangement once I'm back on both feet; noting that the airflow into the engine bay is positive near to the windscreen is a bit of a revelation.
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
Black Rat
Black Rat
As above mine came off without removing bonnets.
Keith
2013 narrow bodied + 4 Ruby.
The article on aerodynamics Doug referred to is here. As he suggests interesting reading especially the increased drag when spare wheel not spec'd and hole covered!
2018 Roadster - Red/Magnolia - Morton
1966 Land Rover S2a 88 - Lenny
1945 Moto Guzzi Airone
I'd be grateful if people who've removed the airbox could share photos of their filter solution.
Thanks, Dave.
Thanks, Dave.
Here’s mine, but it’s a 4/4 so probably a different set up for the Duratec ?
Craig Jezz
Morgan 4/4 Sports Sand
(Release build 20201027)
Responsive Width:
PHP: 7.4.33 Page Time: 0.074s Queries: 35 (0.012s) Memory: 2.9793 MB (Peak: 3.2547 MB) Data Comp: Off Server Time: 2023-06-08 05:52:45 UTC
Valid HTML 5 and Valid CSS
