Forums32
Topics45,130
Posts764,432
Members8,359
Most Online1,033 Dec 28th, 2019
Re: brake disc
[Re: lez]
#770248
01/03/23 10:22 AM
01/03/23 10:22 AM
Posts: 11,102 Gloucestershire, UK
Hamwich
Gloucestershire, UK
Sounds to me like it might have been the mating surface on the stub axle that was at fault rather than the discs themselves?
I can't remember why, but I removed my discs about 15 years ago and when I replaced them I had a dreadful pulsing through the brake pedal as if the discs were warped. Double-checked the mounting and somehow I'd managed to trap a tiny bit of debris between the disc and stub axle mounting faces. Cleaned them up and flatted them off with a bit of emery cloth and some engineer's blue, reassembled and they've been perfect ever since.
Re: brake disc
[Re: lez]
#770257
01/03/23 03:13 PM
01/03/23 03:13 PM
IcePack
I had new disks on my 4/4 last year. The garage warned me to gently bed them in & to slowly build up the heat (harder braking) over a matter of weeks, or they would warp. Apparently for track work, they only use pre bedded in disks.
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: brake disc
[Re: lez]
#770272
01/03/23 05:48 PM
01/03/23 05:48 PM
Posts: 20,826 South Yorkshire
South Yorkshire
I was told a long time ago that new discs were heat treated before final grinding, which reduced warp in use. I was also told that this is no longer the norm.
