1 registered members (M3W55), 110 guests, and 7 spiders.
+8Rich 123
John V6 104
OZ 4/4 100
8359 Registered Users
One for the Morgan Boy Racers..
by +8Rich. 30/05/23 11:00 PM
Green S1, based in London, spotted in Cotswolds
by verysideways. 30/05/23 08:56 PM
Roll Bars
by IvorMog. 30/05/23 08:01 PM
Used car purchase scam?
by KennethM. 29/05/23 09:50 PM
M3W - check the following
by Chris99. 29/05/23 05:12 PM
4/4 Four seater outdoor car cover
by Tim W. 29/05/23 08:11 AM
Book recommendation..
by +8Rich. 28/05/23 01:29 PM
Spotted In Amboise Loire
Wiscombe Park
Sod the rain
Forums32
Topics45,130
Posts764,432
Members8,359
Most Online1,033
Dec 28th, 2019
7024, hbatts
brake disc #770159
28/02/23 10:29 AM
28/02/23 10:29 AM
GLOUCESTER
lez Offline OP
lez  Offline OP
GLOUCESTER
has any one had there brake discs skimmed on the car with centre wheel nuts watched a video of it being done and the machine used bolts onto wheel studs.
LES
PLUS 4
FORD FIESTA ST 2
Re: brake disc [Re: lez] #770167
28/02/23 12:19 PM
28/02/23 12:19 PM
Essex
Burgundymog Offline
Black Rat
Burgundymog  Offline
Black Rat
Essex
No but Melvyn Rutter has a machine that does it on the car, give him a ring he is very helpful.
Keith
2013 narrow bodied + 4 Ruby.
Re: brake disc [Re: lez] #770175
28/02/23 02:09 PM
28/02/23 02:09 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
I never had any problems on previous Morgans with wider tyres. But when I got my 4/4 in 2014, it was really its only weak point. I don't know if the brake discs are more vulnerable with the very narrow tyres of the 4/4 or what the reason is. I got new brake discs under warranty every 6000 km, replaced four times, so in total five sets of brake discs over 30000km. Unfortunately, the workshop had no prescription except to keep changing them. Before each change, the car was pretty much undriveable. The brake discs were so warped that the sole of my foot hurt from the rattling of the pedal. If I was otherwise happy with my old garage, but they couldn't solve the brake disc problem. In the end they blamed me... something like that only happens when you park the car wet etc.
Then I tried another Morgan workshop in Germany, André Koopmann. He did it exactly as you describe in your post, lez. He took brand new discs. They even were already pulsating slightly. He ground down the new discs and I have had absolute peace and quiet for over 70,000 km. It was like a miracle.
Re: brake disc [Re: lez] #770190
28/02/23 05:10 PM
28/02/23 05:10 PM
Wiltshire
RJW Offline
RJW  Offline
Wiltshire
I had a similar problem with my Plus 4 with centre lock wheels. The first pair of discs were replaced under warranty due to warping. The new ones were okay for a while and then went the same way. I then found a garage in Langport in Somerset who skimmed the discs on the car. All has been fine since with no indication of warped discs i.e. no pulsing of the brake pedal. I’ve no idea what the cause of the warping is but the skimming fixed it.
Bob.
Re: brake disc [Re: lez] #770202
28/02/23 06:33 PM
28/02/23 06:33 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
I vaguely remember reading somewhere that cast iron discs need to be “weathered” before fitting. If subjected to heat cycles prior to this, they can warp.
If my memory is working OK (it doesn’t always!), could be that skimming on the car is done after the discs have had several heat cycles and they warp no more.
To this end, when I had new discs fitted to my 4/4 in October 2022, I resolved to be very gentle with the brakes for a while. 12 months later, they have yet to warp. It would be lovely to think that I have a fix!
Can any metallurgists confirm or ridicule my hypothesis?
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Re: brake disc [Re: lez] #770205
28/02/23 07:16 PM
28/02/23 07:16 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
My theory is not so much the burn-in cycle. I suspect that a really flat grinded brake disc has a good chance of always staying flat. But a brake disc with the smallest waviness can become exponentially wavier within a short time. Obviously, the very narrow wheels of the 4/4 can amplify this effect? Maybe because they run less stable round as it is the case with a wider tyre?
Another guess...the brake discs on other Trad models were, I heard, bought in, representing a reliable industrial standard.. Morgan cast the brake discs of the 4/4 themselves for quite a while (so I was told, I don't know). But they weren't really straight in the first place, so grinding them down before first use makes a lot of sense.
Re: brake disc [Re: Paul F] #770207
28/02/23 07:40 PM
28/02/23 07:40 PM
People's Republic of South Yor...
CooperMan Offline
CooperMan  Offline
Paul, in short yes
Re: brake disc [Re: lez] #770211
28/02/23 07:50 PM
28/02/23 07:50 PM
CooperMan Offline
CooperMan  Offline
Les, Mr Rutter is the only dealer I know who has the proper adaptor to do your hubs, my previous Roadster was the first one it was tested on some years ago and used to be used in his adverts (you can just make out my expensive Bilstein shocks) it completely cured the pulsating brake pedal
https://melvyn-rutter.co.uk/service-repair/morgan-car-service-and-repair/
Re: brake disc [Re: lez] #770224
28/02/23 10:18 PM
28/02/23 10:18 PM
Northern Germany
bmgermany Offline
bmgermany  Offline
Northern Germany
My break disk were skimmed by Morgan-Park this way. I even got a short video from this work...
Re: brake disc [Re: lez] #770246
01/03/23 09:09 AM
01/03/23 09:09 AM
North East Derbyshire
Lord Unstone Offline
Never heard of that before, I get new discs, have them fitted, brakes are fine for many miles...On a variety of cars....fitted by some top mechanics...
Richard S
1993 4/4
1966 S2a Landie
1966 VeloSolex
1929 Bernard WO pump
1940 Petter McLaren
