0 registered members (),
130
guests, and 8
spiders. |
Forums32
Topics45,130
Posts764,432
Members8,359
Most Online1,033 Dec 28th, 2019
Re: Moss transmission collar
[Re: Dennismorgan65]
#770606
05/03/23 08:44 AM
05/03/23 08:44 AM
sprinty
Ask Billy Bellinger from JB Sports Engineering
Morgan 4/4 Sport Competition
#770654
06/03/23 09:18 AM
06/03/23 09:18 AM
Posts: 2,203 London
MOG 615
London
Tricky one
The only sure way to do the job properly is to remove the transmission, gearbox from rear, engine and bell housing to front.
Then you can access the clutch sleeve easily , get it freed off, cleaned up and the bell housing machined and sleeved to prevent it happening again.
You can try all sorts of release agents into every orifice on the bell housing and gentle heat, but ( I hope I am wrong) with only a limited chance of success.
If you do decide to remove the transmission , come back on here as there are several tips that you easily make use of , to future proof the work
Good luck
#770671
06/03/23 03:00 PM
06/03/23 03:00 PM
Posts: 5,145 Llanelli
Ray
Llanelli
On my 69+8 the sliding pin broke in the slot .I managed to remove the transmission tunnel and gear lever.,then the bolts to the gearbox mounts and the bolts to the bellhousing . finally I managed to roll the gearbox upside down.luckiy the bolt thread tapped out. It was a lot ove work but less than taking the engine and box out.
