1 registered members (M3W55),
110
guests, and 7
spiders. |
Forums32
Topics45,130
Posts764,432
Members8,359
Most Online1,033 Dec 28th, 2019
Wiper stalk AR plus 4
#770844
08/03/23 01:58 PM
08/03/23 01:58 PM
Posts: 3,450 Somerset, UK
PaulJ
Somerset, UK
My wiper stalk has stopped operating, it just doesn't click into position and stay there. It will still operate the wiper at full speed, but I suspect will need replacing.
The problem is that I don't know who the OE supplier is. I was told by someone they thought it was Land Rover Discovery, but having checked I don't think it is. I'm not sure my ARP4 has the same as stalk as all Plus 4s, I'm guessing it does, so, can anyone tell me what vehicle the stalks are from please. I am sure I can make a small saving by buying from a specialist rather than an MMC dealer?
Paul [Beginning to get the best out of the ARP4]
Re: Wiper stalk AR plus 4
[Re: PaulJ]
#770845
08/03/23 02:04 PM
08/03/23 02:04 PM
Posts: 175 North East Derbyshire
Lord Unstone
I had the same problem, and bought the wrong one...think I may even have 2....Where abouts are you?
Richard S 1993 4/4 1966 S2a Landie 1966 VeloSolex 1929 Bernard WO pump 1940 Petter McLaren
[Re: PaulJ]
#770849
08/03/23 03:03 PM
08/03/23 03:03 PM
Posts: 32,426 Devonshire
Devonshire
Paul, if you send these good folks a picture I'm sure they could help you. Like you I think it's a Disco one but maybe there are a few versions of them. I recall a German colleague on here getting stuck away from home and a Landy dealer had a replacement on the shelf.
Regards Richard
1999 Indigo Blue +8 2009 4/4 Sport Green prev 1993 Connaught Green +8 prev
[Re: +8Rich]
#770863
08/03/23 03:53 PM
08/03/23 03:53 PM
Posts: 6,710 Köln Germany
Heinz
Köln Germany
Paul, if you send these good folks a picture I'm sure they could help you. Like you I think it's a Disco one but maybe there are a few versions of them. I recall a German colleague on here getting stuck away from home and a Landy dealer had a replacement on the shelf. Maybe a similar story happened here, but if it was mine, you have a very good memory, Richard. Only in my case it was the rotary switch (in the turn signal lever on the left side of the steering column) for the driving lights. I had only parking light by the error. Whether in the ARP4 the same parts were installed I do not know of course. But in my 2014 4/4 it is from a Freelander!, I don't know what generation of Freelander, but up to 2015 because it happened that year. In the link below is my original post about the breakdown from 2015 with text under the last picture. Really Richard, if you still know that then all respect for your gray cells. http://www.talkmorgan.com/ubbthread...-you-driven-your-morgan-today#Post286892
[Re: Heinz]
#770869
08/03/23 04:17 PM
08/03/23 04:17 PM
Devonshire
Paul, if you send these good folks a picture I'm sure they could help you. Like you I think it's a Disco one but maybe there are a few versions of them. I recall a German colleague on here getting stuck away from home and a Landy dealer had a replacement on the shelf. Maybe a similar story happened here, but if it was mine, you have a very good memory, Richard. Only in my case it was the rotary switch (in the turn signal lever on the left side of the steering column) for the driving lights. I had only parking light by the error. Whether in the ARP4 the same parts were installed I do not know of course. But in my 2014 4/4 it is from a Freelander!, I don't know what generation of Freelander, but up to 2015 because it happened that year. In the link below is my original post about the breakdown from 2015 with text under the last picture. Really Richard, if you still know that then all respect for your gray cells. http://www.talkmorgan.com/ubbthread...-you-driven-your-morgan-today#Post286892It was you I was thinking of Heinz, always good to see that the grey cells recall some things, not the right side switch but close  I thought it was great that the garage sorted you out mid holiday.
Regards Richard
[Re: PaulJ]
#770870
08/03/23 04:22 PM
08/03/23 04:22 PM
Heinz
Köln Germany
I found an old photo here (the last two photos in the first long post) of my wiper lever and turn signal lever: http://www.talkmorgan.com/ubbthreads.php/topics/338887/momo-prototipo-fitted-for-4-4When I compare it to this photo of an ARP4 from the net, it looks very similar if not exactly the same. So I am also guessing the Freelander (until 2015 may be even older) as the donor especially since our cars were built at almost the same time. ![[Linked Image]](https://tm-img.com/images/2023/03/08/B21F9109-DB6B-48AC-BECF-CE9258DDACA0.png)
[Re: PaulJ]
#770874
08/03/23 04:31 PM
08/03/23 04:31 PM
Devonshire
This looks close looking at your last post Heinz ?
Regards Richard
[Re: +8Rich]
#770876
08/03/23 04:41 PM
08/03/23 04:41 PM
Heinz
Köln Germany
This looks close looking at your last post Heinz ? Yes, Richard, and they note the Freelander 1 below in the text, I had not seen your reply.
