1 registered members (M3W55),
110
guests, and 7
spiders. |
Forums32
Topics45,130
Posts764,432
Members8,359
Most Online1,033 Dec 28th, 2019
Re: Wiper stalk AR plus 4
[Re: PaulJ]
#770928
09/03/23 08:32 AM
09/03/23 08:32 AM
Posts: 6,100 East Harling, Norfolk UK
Having read all the threads and posts on the subject I'm left baffled as to sources  So please double check Paul but my research suggests the wiper stalk assembly fitted to a range of Land Rover's is Lucas STC4016. Click below for source. ![[Linked Image]](https://i.ebayimg.com/images/g/O7EAAOSwKtlWsR21/s-l1600.jpg) The matching light switch is Lucas STC4017 (SQB160) which I have just ordered as a spare as mine can cause intermittency if turned too far. Prices vary enormously with wiper switch the more expensive but you can buy the pair new for under £100 here delivered. Note above are switches only not the central indicator self cancelling mechanism.
2018 Roadster - Red/Magnolia - Morton 1966 Land Rover S2a 88 - Lenny 1945 Moto Guzzi Airone
[Re: PaulJ]
#770932
09/03/23 09:07 AM
09/03/23 09:07 AM
Posts: 23,914 Suffolk, England
Brooklands Register contact
Suffolk, England
Yep that is the bit Richard. I have a spare from my old Roadster when the pcb was failing.
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
[Re: PaulJ]
#771077
10/03/23 03:05 PM
10/03/23 03:05 PM
Slightly off topic but just found this video on removing stalk light switch on a LR Discovery, as later Mogs use the same Lucas STC4017 (SQB160) switch and I've just bought a spare. Note steering wheel does not need to be removed and imagine there is better access to the two screws that need removing once cowls are off. https://www.youtube.com/watch?v=VmmpfvFfy20Useful part starts 2:20 in. Note the two screws mentioned are supplied fully tightened on replacement switch and after removal and clicking into place need to be fitted through tabs on central plastic moulding before tightening back into new switch body to fully secure.
[Re: RichardV6]
#771092
10/03/23 05:35 PM
10/03/23 05:35 PM
Posts: 6,015 People's Republic of South Yor...
Slightly off topic but just found this video on removing stalk light switch on a LR Discovery, as later Mogs use the same Lucas STC4017 (SQB160) switch and I've just bought a spare. Note steering wheel does not need to be removed and imagine there is better access to the two screws that need removing once cowls are off. https://www.youtube.com/watch?v=VmmpfvFfy20Useful part starts 2:20 in. Note the two screws mentioned are supplied fully tightened on replacement switch and after removal and clicking into place need to be fitted through tabs on central plastic moulding before tightening back into new switch body to fully secure. Thanks Richard, although the cut off screwdriver is a bit bodgetastic  , just use a pozi bit out of a power driver and a small ratchet ring spanner
[Re: PaulJ]
#771102
10/03/23 08:03 PM
10/03/23 08:03 PM
Agreed Jon, good engineering practice and video making don't seem to go hand in hand. Sometimes better than the "here's one I made earlier" style though where the job shown takes seconds compared with hours in practice.
I was amused by the captioned "this bit was fiddly" in second video by contrast.
[Re: PaulJ]
#771165
11/03/23 03:47 PM
11/03/23 03:47 PM
Posts: 3,450 Somerset, UK
PaulJ
Somerset, UK
Gentlemen, thank you all for your contributions, it has certainly given me a few thoughts and ideas to work on. Hopefully I will find the right part and can get back to this topic with my findings, which might also help others.
Paul [Beginning to get the best out of the ARP4]
[Re: RichardV6]
#771182
11/03/23 07:20 PM
11/03/23 07:20 PM
I was amused by the captioned "this bit was fiddly" in second video by contrast. I've named him the 'Barnsley Bodger' after watching him attack clips with a Stanley knife, and stab elec connectors with a large pozi driver, he should stick to creasoting sheds !
[Re: PaulJ]
#771193
11/03/23 08:55 PM
11/03/23 08:55 PM
Gentlemen, thank you all for your contributions, it has certainly given me a few thoughts and ideas to work on. Hopefully I will find the right part and can get back to this topic with my findings, which might also help others. Paul although the ARP4 had a plethora of differences with mainstream Classic production, I cannot for the life of me see why MMC would have departed from adoption of the normal readily available stalk switches given they look identical. The outlay and time in developing differing wiper control just for the sake of offering something different wouldn't have made economic sense. Having taken the opportunity recently to delve into the above mentioned Lucas STC4016 (see above for source) wiper stalk application I can say that it's heavily integrated with the six pin WEHRLE 60 201 002 wiper relay as shown below to implement the single wipes, wash wipe and delay functions available on the switch as well as constant two speeds. ![[Linked Image]](https://www.wehrle-electronics.com/img/1800/1260/90/data/wehrle/ShopProdukte/Upload1jpeg/WE60201002.jpg) ![[Linked Image]](https://www.wehrle-electronics.com/img/1800/1260/90/data/wehrle/ShopProdukte/Upload1jpeg/WE60201002_2.jpg) Presence of this on your car would be further confirmation although there are alternatives seemingly offering the same functions. Look forward to hearing your updates.
