0 registered members (), 119 guests, and 12 spiders.
+8Rich 123
John V6 104
OZ 4/4 100
8359 Registered Users
One for the Morgan Boy Racers..
by +8Rich. 30/05/23 11:00 PM
Green S1, based in London, spotted in Cotswolds
by verysideways. 30/05/23 08:56 PM
Roll Bars
by IvorMog. 30/05/23 08:01 PM
Used car purchase scam?
by KennethM. 29/05/23 09:50 PM
M3W - check the following
by Chris99. 29/05/23 05:12 PM
4/4 Four seater outdoor car cover
by Tim W. 29/05/23 08:11 AM
Book recommendation..
by +8Rich. 28/05/23 01:29 PM
Spotted In Amboise Loire
Wiscombe Park
Sod the rain
Forums32
Topics45,130
Posts764,432
Members8,359
Most Online1,033
Dec 28th, 2019
7024, hbatts
Re: Indicators stopped working [Re: Ian Wegg] #772188
21/03/23 05:43 PM
21/03/23 05:43 PM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
Pleased you have located the problem Ian! smile
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'09 Alfa Romeo MiTo
Re: Indicators stopped working [Re: Ian Wegg] #772463
24/03/23 07:39 AM
24/03/23 07:39 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Holden seem to have switches Ian here. Given others have had similar problems might be useful to carry a spare whilst still available.
2018 Roadster - Red/Magnolia - Morton
1966 Land Rover S2a 88 - Lenny
1945 Moto Guzzi Airone
Re: Indicators stopped working [Re: Ian Wegg] #773734
04/04/23 12:35 PM
04/04/23 12:35 PM
South Shields
Leroy Offline
Leroy  Offline
South Shields
Discovered something odd today, an guessing it might be relay related. All indicator lights are working. Turning left normal, hazards work as normal, but turning right, they are rapid, like you get when you have a bulb out, but they both flash. If this is a relay issue, can anyone advise where it is, and which one it is to replace please. I'm guessing it's under the dash, above the gear stick. TIA
2004 Series 1 Roadster
Re: Indicators stopped working [Re: Ian Wegg] #773737
04/04/23 01:24 PM
04/04/23 01:24 PM
Aberdeenshire
Image Offline
Image  Offline
Aberdeenshire
If you turn on your sidelight or press the brakes do these flash/flicker as well ? ... if so suspect the earth first.
Re: Indicators stopped working [Re: Ian Wegg] #773749
04/04/23 03:11 PM
04/04/23 03:11 PM
Essex
Burgundymog Offline
Black Rat
Burgundymog  Offline
Black Rat
Essex
Yes I would suspect earth or a fault in one of the bulbs even though they flash.
Keith
2013 narrow bodied + 4 Ruby.
Re: Indicators stopped working [Re: Burgundymog] #773752
04/04/23 03:31 PM
04/04/23 03:31 PM
South Shields
Leroy Offline
Leroy  Offline
South Shields
The side that's flashing fast, the rear bulb is dimmer. Last year this bulb wasn't working and caused the same rapid flashing as you'd expect. It was due to a corroded connector that I solved by cleaning it up some what by squirting electrical cleaner inside. Maybe if the contacts are poor again, it isn't drawing as much power to that bulb, therefore causing the rapid flash. Could this be the case?
Re: Indicators stopped working [Re: Image] #773753
04/04/23 03:32 PM
04/04/23 03:32 PM
South Shields
Leroy Offline
Leroy  Offline
South Shields
Tried this and all good.
Re: Indicators stopped working [Re: Ian Wegg] #773777
04/04/23 04:31 PM
04/04/23 04:31 PM
South Shields
Leroy Offline
Leroy  Offline
South Shields
All cured. Burgundymogs suggestion got me thinking about the wiring. A good squirt of electrical cleaner into the connectors and it cured the problem.
Re: Indicators stopped working [Re: Ian Wegg] #773785
04/04/23 05:38 PM
04/04/23 05:38 PM
Suffolk, England
John V6 Offline
Brooklands Register contact
John V6  Offline
Suffolk, England
Well done
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
