1 members (bilibib), 221 guests, and 7 robots.
+8Rich 135
John V6 120
OZ 4/4 113
8,359 Registered Users
Beware the rogue pothole!
by vincentvg - 06/06/23 08:16 PM
Keep spotting Aeros!
by verysideways - 06/06/23 05:46 PM
Archaic immobiliser
by Tonyh157 - 06/06/23 11:06 AM
Thanks to All.
by kiwi100 - 06/06/23 03:17 AM
by Neil49 - 06/06/23 12:02 AM
Carpets and Headrests
by C2RM - 05/06/23 08:37 PM
Best Small Camera
by John V6 - 05/06/23 10:38 AM
Head rest
Head rest
by JMcL, June 6
Spotted In Amboise Loire
by Clipper, May 28
Wiscombe Park
Wiscombe Park
by griffo, May 22
Forums32
Topics45,164
Posts764,938
Members8,359
Most Online1,033
Dec 28th, 2019
NWVT
ADC Offline OP
Help!!!!
I have a 2013 Plus 8. I am having trouble sourcing the green and salmon relays for spares. Also the guide on the lid of the box doesnt match the lid
The random fuse guides are I'm afraid a Morgan normal, as far as the individual relays go RS Components have a few but there are many different suppliers but make sure they have a quenching diode fitted across the coil to prevent back emf damaging the ECU...
If you have a couple of pictures of the relays you want and their ratings and functions we should be able to help.
Regards Richard
1993 Connaught Green +8 prev
I expect these are generic diode relays but if you want genuine colour matched BMW ones.
Green relay part 61 36 8 373 700 available here
Salmon relay part 12 63 1 742 690 available here
Please double check with part numbers printed on your existing relays though.
2018 Roadster - Red/Magnolia - Morton
1966 Land Rover S2a 88 - Lenny
1945 Moto Guzzi Airone
Consider changing to solid state versions that use Mosfet technology and opto isolation to the ECU ... coil operated relays with mechanical contacts so last century https://components.omron.com/eu-en/products/relays/mosfet-relays/mosfet-relay_features
And here
https://www.e-t-a.co.uk/products/relays_ssrpc/solid_state_relays/
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Interesting stuff Rob. Just been checking though and availability seems scarce when considering retro fit to DIN established 5 pin socket. Current rating, changeover contacts and currently the need to have different relays for positive and negative switching need to be born in mind.
I think they will really take off when new cars ECU and BCU's are re-designed to take full advantage of the low switching currents. Perhaps a step too far in the meantime especially given the quirky nature of the Aero's electronics.
Interesting stuff Rob. Just been checking though and availability seems scarce when considering retro fit to DIN established 5 pin socket. Current rating, changeover contacts and currently the need to have different relays for positive and negative switching need to born in mind.
I was designing solid state relays into telephony circuits in the 1980's - they must be fairly reliable by now and no issues with wetting current although there will be a voltage drop across the "contacts".
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
ADC Offline OP
Thanks, struggling with upload pictures at the moment
ADC Offline OP
thanks
ADC Offline OP
sorry one more question I have five of the green relays and one salmon one. (ordered thanks). I can see that one green one is for the fuel pump the others? and the salmon too not listed?
ADC Offline OP
(Release build 20201027)
Responsive Width:
PHP: 7.4.33 Page Time: 0.063s Queries: 35 (0.015s) Memory: 2.9769 MB (Peak: 3.2551 MB) Data Comp: Off Server Time: 2023-06-07 03:28:36 UTC
Valid HTML 5 and Valid CSS
