6 members (johncc, CLPlusFour, Laurens, John V6, HeadlessBlue, dmh), 200 guests, and 9 robots.
+8Rich 141
OZ 4/4 122
John V6 120
8,359 Registered Users
Dressing up for the Goodwood Revival Meeting
by Mkiss - 09/06/23 09:16 PM
Currency
by Dean-Royal - 09/06/23 10:10 AM
My new car arrived today
by John V6 - 08/06/23 10:02 PM
Is It Just Me???
by Dan_Lockwood - 08/06/23 09:28 PM
Side Wind Deflector Fitting 2004 on
by Mark666 - 08/06/23 05:50 PM
Used Stock Cams (S&S 548)
by IsleOfMog - 08/06/23 05:12 PM
Re-flashing or changing the chip
by LarryS - 08/06/23 04:57 PM
Head rest
Head rest
by JMcL, June 6
Spotted In Amboise Loire
by Clipper, May 28
Wiscombe Park
Wiscombe Park
by griffo, May 22
Forums32
Topics45,177
Posts765,170
Members8,359
Most Online1,033
Dec 28th, 2019
Good evening. I have a pair of rear Avo (New Elms) shocks. With regard to the adjustment, I assume “-“ is soft??
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
Anticlockwise on the adjuster opens the internal valve = softer
Thanks
2005 Plus 4
2020 Hyundai eKona
Another little tip. if you set the dampers to full hardness, so clockwise to stop, and count the number of clicks...if you then set them counterclockwise on both sides the same number of clicks back to your desired setting, then the result will be more equal than if you start from soft to set clockwise. i hope that makes sense.
With rear shocks you will probably want them on their softest setting, unless you are doing track time. Another thing with the AVOs is that they have tabs inside that when the shock takes a good thump they bend and lock the shock at whatever setting is on. You can adjust to your hearts content after that but with no change to the shock, so test drive on a pothole free road.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Black Rat
Black Rat
My rear AVOs are set on 6 clicks up from soft.
Keith
2013 narrow bodied + 4 Ruby.
(Release build 20201027)
Responsive Width:
PHP: 7.4.33 Page Time: 0.107s Queries: 26 (0.032s) Memory: 2.9344 MB (Peak: 3.2551 MB) Data Comp: Off Server Time: 2023-06-10 07:11:39 UTC
Valid HTML 5 and Valid CSS
