Who's Online
2 registered (Bert Varady, musew), 9 Guests and 9 Spiders online.
LATEST PAINTING PHOTOS - CHUNKY 4/4'S RACING CAR
Little and Large
Grand Day Out
Mog meets Mog
National Motor Heritage Day
All to start again
by Jack The Lad
22/05/13 09:52 PM
Aero Racing 5" driving lamps
by nputtick
22/05/13 02:12 PM
Roadster dashboard
by stumog
22/05/13 11:06 AM
Morgan Aero 8 on a Ferry!
by TheCoot
22/05/13 09:30 AM
Yah - they posted it on-line
by Alistair
22/05/13 08:25 AM
Daft Garage
by Clipper
22/05/13 07:44 AM
Adjusting +8 Tming
by AJSki2fly
22/05/13 07:38 AM
fathergoose, HMSMotorsport, tide, Dk Super Dry 3W, Dr John
2870 Registered Users
Shout Box
Forum Stats
2870 Members
51 Forums
11048 Topics
Page 2 of 2 < 1 2
Topic Options
#78444 - 09/01/12 07:01 AM Re: AEROMAX back windows [Re: 1560]
Graham, G4FUJ Offline
Loc: Cheltenham, GLos. UK
Nice looking classic BMW R-series twin in the backgound - just to keep on topic! laugh2
_________________________
'01 Freelander TD4; '90 Defender 90 SW
Top
#78455 - 09/01/12 08:22 AM Re: AEROMAX back windows [Re: Graham, G4FUJ]
aeromax Offline
Loc: FRANCE
I lost two glasses on mine and then another one broke under severe cold
All of the glasses were glued using Morgan's specified glue, which is a bi composant
I was so unhappy with the issue that I went to my local body shop and discussed the matter
They used Sikaflex adhesive which requires to carefully bake the glass and mount before assembly, and then, once the two parts are bonded together, to keep these in the oven for a little while
Their views is that the adhesive used by Morgan have no chance whatsoever to work properly
I had no problem with Sikaflex for the last two years, despite some extreme cold and extreme hot conditions
Top
#78457 - 09/01/12 08:56 AM Re: AEROMAX back windows [Re: aeromax]
Aeroman Offline
Lord Trois-Roues
Loc: In transit...
When I had a Max, now owned by Mr Tony, I did not have any problems at all with the rear windows which were glued. I did not have the bolted glass fitted, despite pressure from the Works when it went in for service, as I do think that it does spoil the aesthetics.
Aeromax's solution with the Sikaflex seems to me to be the answer, if it has worked successfully. wine
Reality is an illusion that occurs due to a lack of wine wine
Top
#78462 - 09/01/12 09:22 AM Re: AEROMAX back windows [Re: Aeroman]
Jays Offline
Loc: worcestershire UK
I noticed the BMW R too Graham......I'd hate to admit my eye went to that first!
Jay
2010 4/4 "Super Sport "
Top
#78484 - 09/01/12 03:36 PM Re: AEROMAX back windows [Re: Jays]
NAC Offline
Aeroman,as you have owned an aeromax would you in your opinion have the bolts fitted to my rear windows or just leave them as they are?ive had a good look at them and they don't seem to have any visible defects in the bonding areas,I wouldn't fancy driving the car and the windows pop out,I was at dmats house and he showed me the windows in his max .....doesn't give you much confidence ?
Top
#78488 - 09/01/12 04:38 PM Re: AEROMAX back windows [Re: NAC]
DaveW Offline
Loc: Yorkshire
I think the way to look at this is that if they pop, it will be at the most inconvenient time & place possible. So probably dark, wet & windy. Therefore if you chose not to have bolts, carry some coping gear - plastic sheet & gaffer tape at the very least.
Red Roadster
Top
#78495 - 09/01/12 04:51 PM Re: AEROMAX back windows [Re: NAC]
Aeroman Offline
Lord Trois-Roues
Loc: In transit...
Hi, MMC fitted the Mark II glue solution at a service, but we did quite a number of tours to France in it and it got used during the UK winter as well, as long as no salt on the roads, and we had no problems with windows popping at all. Rich who bought the car has not had the bolts fitted, and whilst they do resolve the problem I think as I said above that it spoils the aesthetic.
I know that one of the famous members of the forum had trouble with his AeroMax windows dropping out and has had the bolts fitted, so it's really down to personal choice. If I still had an AeroMax I would certainly investigate the baked-on Sikaflex solution proposed by 'aeromax' before getting them bolted. HTH. smile
Top
#78498 - 09/01/12 05:27 PM Re: AEROMAX back windows [Re: Aeroman]
aeromax Offline
Loc: FRANCE
You need to carefully look at the place where the aluminium hinges are glued. All failures happened to me there, and I had no troubles with the 'hook' that go into the latches. It seems that extreme heat is transmitted trought the glass to the aluminium plate which can get 'twisted' by the heat and will create an abnormal pressure
Looking from the outside, should you see any sort of 'bubble', then the glue is on its way to break and your windows will get loose.
In some cases, you can see the glass delaminating
For as long as you don t open the window, they are stuck in place by the hinges hooks, even if the glue is gone on the main plate. The solution then is to have several strong rislan and link the two hinges from inside the car. It will pull the springed hinges back to place and the window will go flat as the pressure on the spring loaded hinges is blocked by the rislan
however, the window will no longer be flush or watertight
When the glue from the hinge is gone DO NOT open the window: the latches will open and the springed hinges will push your window away. They will damage the bodywork when falling
I drove once from Nice to Milan with one of the windows off, and lost another in Rome on my way back to Paris. Really annoying but even at very high speeds (In excess of 150 MPH on Italian motorways) it wasn t much more noisy that normal
But it was summer time........
When you re-glue, do ensure the aluminium plate is perfectly flat. A bit of machining was necessary on one of them. I also got the edges slightly grinded to avoid sharp angles that could break the glass. I also got the screw holes machined in a bigger diameter but that was done so that the new hole was marginally higher than the original ones. It helps to ensure the windows are perfectly watertight. On some cars, there was water ingress which was only resolved by the factory in putting a few spacers between the roof and the electric latches. It is a poor engineering solution and redrilling the aluminium brackets and the hinges is much more elegant as you don t need the spacers that are slightly visible
Top
#78503 - 09/01/12 05:50 PM Re: AEROMAX back windows [Re: aeromax]
NAC Offline
Thanks for that information....if the car has to be returned to Morgan to have the windows bolted,is this a cost to the customer or does Morgan cover the costs ??
Top
#78509 - 09/01/12 06:24 PM Re: AEROMAX back windows [Re: NAC]
Dean-Royal Offline
Loc: UK (up north)
at my guess Morgan could be covering the cost, as mine has gone up to the factory today before i take pocession, for the very reason you are discusing, if it was the resposibility of the owner i think SGT would be attemting this themselves in there workshops !
33 MAX v SPIDERMAN
Top
Page 2 of 2 < 1 2
