Who's Online
4 registered (PJB, Michael H, numog, Andre), 19 Guests and 9 Spiders online.
BHM Track day - Goodwood (May 2013)
LATEST PAINTING PHOTOS - CHUNKY 4/4'S RACING CAR
Little and Large
Grand Day Out
Mog meets Mog
New member using my Dad's Morgan, Love it!
by Alasdair Davis
23/05/13 10:30 AM
Jach supplied by MMC
by Robbie
23/05/13 09:57 AM
Thanks for the tip Graham
by Jack The Lad
23/05/13 09:12 AM
Modern or Old?
by PaulJ
23/05/13 08:58 AM
All to start again
by Jack The Lad
22/05/13 09:52 PM
Aero Racing 5" driving lamps
by nputtick
22/05/13 02:12 PM
Roadster dashboard
by stumog
22/05/13 11:06 AM
fathergoose, HMSMotorsport, tide, Dk Super Dry 3W, Dr John
2870 Registered Users
Shout Box
Forum Stats
2870 Members
51 Forums
11053 Topics
Page 1 of 2 1 2 >
Topic Options
#84575 - 08/03/12 11:03 PM ID required please
1955er Offline
Loc: Victoria, Australia
Will be starting the dashboard replacement soon and it has ocurred to me that I have never seen the centre warning light on the dash light up and I haven't a clue what it is for. frown2
Also the two unmarked lower switches which don't appear to be connected ooo
Car is '75 4/4 4 seater. Can anyone shed some light? Thanks.
cheers Neil.
_________________________
1975 4/4 4 seater, cream over blue; Sooby Forester turbo; Bicycle; Walking poles.
Top
#84594 - 09/03/12 07:43 AM Re: ID required please [Re: 1955er]
Graham, G4FUJ Offline
Loc: Cheltenham, GLos. UK
Centre warning light is handbrake warning light on my '76 (I'll have to double check that smile ).
Switch layouts vary, but I have the same 7 switches with the Hazard lights and heater fan in the same position.
The two unused switches: one would be wired for additional drive (spot) lamps and the other? Was going to use my 7th for rear fog lamp, but I would have to find somewhere to mount a warning light...
Cheers,
'01 Freelander TD4; '90 Defender 90 SW
Top
#84597 - 09/03/12 07:58 AM Re: ID required please [Re: Graham, G4FUJ]
1955er Offline
Cheers,
Thanks Graham,
in mine the left one of the three is the handbrake warning light!........so many variations!!!!
cheers Neil.
Top
#84607 - 09/03/12 08:23 AM Re: ID required please [Re: 1955er]
M3W Offline
Loc: Sweden
When making a new dash layout it is always a good idea to add one or more extra switches/control lamps for future needs. It helps you keep a tidy dash when functions add on along the way (some of them legal like fog lights in some countries).
It also gives you:
- The chance to play around a little to create a more balanced layout (looks).
- Already assembled spares to connect if any of the other switches fail.
If you are buying exotic "hard to find" switches/control lamps, buy some extra, your grand children will cheer you for your wisdom...
Added some features on my last home made dash which I later found very useful: a hidden extra socket for navigator/mobile charging, a reading lamp underneath the dash and a flashing red immobilizer/alarm lookalike LED (with hidden switch).
cheers
Top
#84612 - 09/03/12 08:31 AM Re: ID required please [Re: M3W]
Watty Offline
Loc: West Yorkshire
Hi,
Not sure but does one of the switches turn on some sort of immobizier? I used to own a 1975 Plus 8 with a similar dash layout to yours and can remember going to France and switching this on overnight and then forgeting about it the next morning. I tried to start the car with no success, the engine turned but would't start until at the point of the battery finally giving up I looked at the dash and wondered why one of the switches was pressed down. And then it dawned on me! Worth a try.
Top
#84615 - 09/03/12 08:35 AM Re: ID required please [Re: Watty]
That's an aftermarket fit Paul.
Sensible to put it with the other switches - the first place a tea leaf would look is for one tucked up under the dash...
Neil, I doubt that they all came out of the factory wired the same - and after the cars have been through several caretakers over 30 years or so, who knows how things have been modified!
M3W - makes sense, particularly when starting afresh. smile
Top
#84698 - 09/03/12 05:06 PM Re: ID required please [Re: Graham, G4FUJ]
Vitruvius Offline
Loc: Virginia, USA
I've got a battery disconnect on my Morgan for security....
My car has no cigarette lighter so I bought a nautical outlet to install, but don't know of a good place to put it. I was wondering if anyone has any ideas. My glove box does have a door, so I would rather not locate it within the glove box. My preferred location would be not visible...
'67 +4 tourer - broken white - RHD
Top
#84700 - 09/03/12 05:13 PM Re: ID required please [Re: Vitruvius]
Guten Offline
Loc: Lincolnshire
I've just fitted one. I put it in between the seats in the vertical face of the parcel shelf - thingy. One in line blade fuse and a short length of wire and job done. O cut a cat flap in the carpet for access I may get this trimmed but untrimmed it is almost invisible. Tried it and it works well. cheers
Simon
Top
#84706 - 09/03/12 05:55 PM Re: ID required please [Re: Guten]
John +4 Offline
Loc: Bucks
It used to be standard on Mogs. My 94 car had one & my 97 car has one behind the drivers seat.
GoMog has wiring diagrams for those date cars if you need one.
Top
#84714 - 09/03/12 07:21 PM Re: ID required please [Re: M3W]
1955er Offline
It also gives you:
cheers
Thanks M3W,
they are all superb suggestions.......all taken on board. notworthy
cheers Neil.
Top
Page 1 of 2 1 2 >
