8 registered (Graham, G4FUJ, Dave Turner, Alistair, Mi3Wheeler, Krod, DMAgombar, Quicksilver, lightsphere),
Guests and
Spiders online. |
2870 Members
51 Forums
11045 Topics
#84920 - 11/03/12 06:00 PM
Radiator leak
TM Photographer of 2011
Loc: Luxembourg
Hi, Today, I noticed some water missing in the expansion tank. After filling up, a little spin and the inspection afterwards I found some cooling liquid spread all over the upper left corner of the radiator, the front of the engine, and even outside on the left wing. I remember having seen radiator problems in the Aero section here. Are the same radiators used for the trad vehicles? Anyone out there with a similar experience? I don't see an obvious damage, and the hoses seem to be tight, but I suppose it's the radiator. Is it repairable, or must it be changed? I think, it's partially made of plastic, isn't it? In case it has to be changed, is there a better choice, than the model currently installed? Thanks for your advise  Sunny greetings, Ivo
Top
#84925 - 11/03/12 07:10 PM
Re: Radiator leak
[Re: Ivo]
Loc: Norway
Hi,
In the Norwegian Mog club magazine, there was an article about leaking plastic radiators on roadsters. One of the nozzles will break from fatigue. I think recommended solution to the problem is buying an aluminium radiator.
Check that all nozzles are intact, and be careful so you don't get sprayed with hot coolant.
My 2001 4/4 had a metal radiator which were starting to falla apart after 4000 miles. It were replaced with an aluminium radiator.
_________________________
GKA
Top
#84926 - 11/03/12 07:40 PM
Re: Radiator leak
[Re: Geir Karlsen]
Loc: Bucks
Hi I also had this issue with my roadster - The radiator had already been repaired and having reviewed this with fellow Moggers it became clear it is common . I know someone who is is number 4 ..... The advice here was a Aluminium one from Peter Mulberry at Mulfab- i visited peter and fitted it to my car - It is fantastic thoroughly recommend it http://www.talkmorgan.com/ubbthreads.php...dster#Post81323Regards Jon
Top
#84935 - 11/03/12 08:35 PM
Re: Radiator leak
[Re: Ivo]
Loc: Normandy, France
Hi, Today, I noticed some water missing in the expansion tank. After filling up, a little spin and the inspection afterwards I found some cooling liquid spread all over the upper left corner of the radiator, the front of the engine, and even outside on the left wing. I remember having seen radiator problems in the Aero section here. Are the same radiators used for the trad vehicles? Anyone out there with a similar experience? I don't see an obvious damage, and the hoses seem to be tight, but I suppose it's the radiator. Is it repairable, or must it be changed? I think, it's partially made of plastic, isn't it? In case it has to be changed, is there a better choice, than the model currently installed? Thanks for your advise  Sunny greetings, Ivo Hi Ivo, On my Plus 8 which was originally fitted with a copper radiator, it has been changed three times under warranty and the forth, to be quiet, I changed for a new one in aluminium (Peter Mulberry). BR. Daniel.
Top
#84956 - 12/03/12 07:24 AM
Re: Radiator leak
[Re: Vampirex]
Loc: Luxembourg
Thanks for your comments Just asked my dealer. They had quite a few radiators changed already. Seems to be a common problem. The replacement model, they now use, seems to be better. We shall see... Sunny greetings, Ivo
Top
#85000 - 12/03/12 01:21 PM
Re: Radiator leak
[Re: Ivo]
Moyen Ivo - I had the same problem on my series 1 Roadster but while it was being repaired I bought a series 2 which didn't give any radiator problems during my ownership.
Top
#85009 - 12/03/12 02:03 PM
Re: Radiator leak
[Re: Max5]
Loc: Sweden
Hi Ivo! Popped in to your site and have to say that yellow/black combination is really looking great!! Sad to hear about your radiator, a new one in alu will for sure solve it for a looong time. Here is something to cheer you up:
Top
#85164 - 13/03/12 02:54 PM
Re: Radiator leak
[Re: M3W]
Lord Trois-Roues
Loc: In transit...
I LIKE that!  Yes, it is dangerous to start up Photoshop during coffe breaks....you never know what bizarr outcome that might appear  Next one could be inspired from the Landrover/Defenders...a black/white zebra look...for that Three Wheeler around Africa tour...and for that you need a good capacity radiator (trying desperate not to go off topic). Eagerly awaiting the next instalment M3W!
Reality is an illusion that occurs due to a lack of wine
Top
