Who's Online
20 registered (N22MOG, Easter, Jack The Lad, Edgar 1969 4/4, Robbie, HJP, Heinz, Jays, wolf, johntinline, deano, Brian - NZ, Martyn Culling, tmg513, RoadsterIV, Jens, flyfisher, herman01, Krod, Andrewr), 26 Guests and 12 Spiders online.
More Aeromax Teasers
An aside from model aircraft!
More model aircraft from Wellesbourne
Wellesbourne Wings & Wheels
Classic Car Show Pics
New Morgan in France - going to Romania
by Kaou
18/06/13 09:12 PM
Morgan 3 Wheeler License in Texas
by Crowbar
18/06/13 09:03 PM
freeing a bulb
by sawman
18/06/13 06:38 PM
modification radiator +4 2007
by atalante83
18/06/13 06:04 PM
FOR SALE - Morgan Aero Coupe - Near New
by dogmanjack
18/06/13 03:36 PM
Engine doesnt start when warm
by bones
18/06/13 01:16 PM
Engine Bay Bracing Bar
by m3boy
18/06/13 01:11 PM
Colin Lewis, farfinator, EdR, Jim Myers, The Seeker
2921 Registered Users
Shout Box
Forum Stats
2921 Members
51 Forums
11342 Topics
Page 7 of 8 < 1 2 3 4 5 6 7 8 >
Topic Options
#57193 - 06/03/11 09:02 AM Re: Kingpins - DaveW's How To........... [Re: sawman]
DaveW Offline
Loc: Yorkshire
That box is a cover over the universal joint on the steering column. On my Roadster its fixed with self tappers and is easy to remove. It's not structural, but helps to keep the wet out.
_________________________
Red Roadster
Top
#57204 - 06/03/11 10:55 AM Re: Kingpins - DaveW's How To........... [Re: DaveW]
sawman Offline
Loc: Newcastle Upon Tyne
Any idea it I can just get a replacement to screw on? mine doesnt seem to be made of metal - seems sort of fibrous!
Top
#57207 - 06/03/11 10:59 AM Re: Kingpins - DaveW's How To........... [Re: sawman]
DaveW Offline
Loc: Yorkshire
The cheapest fix is to make a template out of cardboard, then make your own from thin aluminium sheet - around 1mm should do fine.
If you can't do that then try a Dealer, although I suspect that they are cut to fit each car.
Red Roadster
Top
#57208 - 06/03/11 11:17 AM Re: Kingpins - DaveW's How To........... [Re: DaveW]
sawman Offline
Sounds like a job for next weekend
Top
#87298 - 05/04/12 04:00 PM 4/4 King PIns [Re: DaveW]
Vancouver Offline
Loc: Gloucestershire
My 2009 4/4 Sport had its first MOT Test yesterday, which it passed, but with a comment which said:
"Nearside front lower Axle King pin has slight play in pin and/or bush"
They showed me that holding the wheel top and bottom when jacked up that the rock was quite noticeable although difficult to say how much.
Having recently bought the car, I have a copy of a Sales Invoice which shows new pins and bushes were fitted by MMCC January 2011.
Is this slackness/movement normal ?
Jack
Top
#87324 - 05/04/12 07:24 PM Re: 4/4 King PIns [Re: Vancouver]
DaveW Offline
Loc: Yorkshire
How many miles covered since January 2011?
I have a theory that if the kingpin bushes are not reamed with care, it's possible to create a bit too much play right from the start. It's early to have had them changed after two years anyway. What was the mileage in January 2011? Either the new bushes were not reamed accurately, or you've been driving on roads which have generated a lot of abrasive dust.
Have a close look at the state of the pins inside the rebound springs and see if a good greasing on the bottom nipple helps.
Red Roadster
Top
#87325 - 05/04/12 07:30 PM Re: 4/4 King PIns [Re: Vancouver]
Hamwich Offline
Loc: Gloucestershire, UK
How many miles has the car done since the kingpins were fitted? Has the front suspension been regularly greased? Has the car got rebound spring gaiters fitted?
If neglected, it's entirely possible to knacker a bush in 10k miles, and the nearside lower bush is always the first to wear. But if it's not done many miles and has been looked after, it may be that the tester was being a bit too picky.
If/when you have the bushes redone, fit hardchrome kingpins and a set of rebound spring gaiters, then you'll not have to worry again.
Top
#87326 - 05/04/12 07:35 PM Re: 4/4 King PIns [Re: Hamwich]
Martyn Culling Online   happy
Loc: Snorbans, UK
If neglected, you can do a bush in 2000 miles. Has to be seriously neglected though.
1930 Super Sport Aero 'The Elk'
Top
#87327 - 05/04/12 07:48 PM Re: 4/4 King PIns [Re: Martyn Culling]
Hamwich Offline
Blimey, how would you do that? By driving them on a beach with no grease at all in?
Top
#87328 - 05/04/12 08:12 PM Re: 4/4 King PIns [Re: Hamwich]
Vancouver Offline
I bought the car in November 2011 and looking at the Morgan Motor Co Ltd Invoice dated January 2011 the car had done approx 14000 miles in that time? Since that time I have added only about 100 miles
__________
Jack
Edited by Vancouver (05/04/12 08:13 PM)
Top
