Who's Online
10 registered (Andyman, Boshly, Budster, Clipper, Kaou, Soleng, Parisa, meabh, Bonniya, deano), 40 Guests and 10 Spiders online.
Luggage Packed
1923 Darmont Special 3W
British Ambassador opens China Showroom
Darmont Special 3 Wheeler
More Aeromax Teasers
SU carbs and fast idle
by Dick H
19/06/13 06:16 PM
AERO REGISTER UPDATED
by Gajet
19/06/13 05:34 PM
Roadster rear brake pipes.
by NeilM
19/06/13 05:18 PM
Spotted Mog
by Gambalunga
19/06/13 03:30 PM
Clutch cable
by brownbaker
19/06/13 10:19 AM
Depressing news for open air motoring enthusiasts
by pandy
19/06/13 08:13 AM
2007 AeroS3 wiring diagram
by TRMAN
19/06/13 08:03 AM
Colin Lewis, farfinator, EdR, Jim Myers, The Seeker
2921 Registered Users
Shout Box
Forum Stats
2921 Members
51 Forums
11353 Topics
Page 7 of 7 < 1 2 3 4 5 6 7
Topic Options
#87692 - 08/04/12 07:57 PM Re: 3 Wheeler Modification [Re: asbojohn]
AQM Offline
Loc: Denmark
Originally Posted By: asbojohn
I had looked at something similar bu the diameters are wrong, I've also thought about mounting a cricket or snooker ball in the end, trouble is nothing obvious works.
Might need to find a metal fabricators and get something turned out of ali
Bummer.
What about getting a tube that goes slightly up and out bend into shape, that has a smaller tube inside to fit into the ends of the chassis tubing (think "beach buggy front en miniature")?
If you do it like that (or similar), you can use a small screw/hex to fasten it in each tube.
Top
#87694 - 08/04/12 08:48 PM Re: 3 Wheeler Modification [Re: Graham, G4FUJ]
asbojohn Offline
le Asbo du Bling
Loc: Cambridgeshire
Originally Posted By: Graham, G4FUJ
Originally Posted By: 1560
keep that radiator (oil) clear!!!!
Thought that was a heatsink for the charging regulator?
Cheers,
That's certainly what it looks like.
_________________________
Why have one colour when you can have them all wink
Top
#87695 - 08/04/12 08:53 PM Re: 3 Wheeler Modification [Re: AQM]
asbojohn Offline
le Asbo du Bling
Loc: Cambridgeshire
Bummer.
Found these earlier
Cricket balls
Top
#87696 - 08/04/12 09:27 PM Re: 3 Wheeler Modification [Re: asbojohn]
AQM Offline
Loc: Denmark
LOL, how British is that!?
Top
#88231 - 13/04/12 01:36 AM Re: 3 Wheeler Modification [Re: AQM]
Vitti4.3W Offline
Loc: Germany/Brazil
Help me out, whats it all about a Cricket ball?
Manfred
Try to catch the wind in a M3W
Top
#88243 - 13/04/12 07:32 AM Re: 3 Wheeler Modification [Re: Vitti4.3W]
asbojohn Offline
le Asbo du Bling
Loc: Cambridgeshire
If you remove the front number plate holder you are left with 2 ugly looking ends of chassis tube. I've been looking around for decorative items to put on the ends, hence the cricket balls as a suggestion.
Hope this helps.
Did also think about these
Smilie Balls
Top
#88331 - 14/04/12 02:31 AM Re: 3 Wheeler Modification [Re: asbojohn]
Vitti4.3W Offline
Loc: Germany/Brazil
Thanks, I understand it now.
Manfred
Top
#89046 - 19/04/12 09:24 PM Re: 3 Wheeler Modification [Re: Vitti4.3W]
ivanford Offline
Loc: Northern Ireland
A quick update on my latest modifications / changes:
Exhaust heat shields now refinished in black powdercoat. There should be a sufficient air gap from the exhaust pipe to stop the coating from burning. I see on the latest MMC price list that black heat shields are now available as a £200 + vat option.
Removed the naff 'hot' sticker on top of the engine, in fact it had already started to lift on one edge.
Made up a battery tender lead to plug into the accessory socket.
Got my factory paint touch up and tended to a few minor paint stone chips.
I have also bought the MMC outdoor fitted cover.
Top
Moderator:  Aeroman
