Who's Online
2 registered (Richard - Aus, Taffmog), 10 Guests and 11 Spiders online.
Little and Large
Grand Day Out
Mog meets Mog
National Motor Heritage Day
Top Gear Verdict
by Mi3Wheeler
21/05/13 08:04 PM
Killerton Classic Car Day
by AJSki2fly
21/05/13 06:26 PM
I believe the same could be said of Classic Cars
by A11OGE
21/05/13 10:35 AM
+4's with Ecotec swap, a question for you
by flaagan
21/05/13 09:24 AM
Rare Astons - Old and New
by Clipper
21/05/13 07:26 AM
New Member with M3W
by rickmazer
20/05/13 10:44 PM
Prescott photos - with a bit of luck!
by sospan
20/05/13 08:21 PM
gobel, Mats, davewhite, sailingmad, rickmazer
2863 Registered Users
Shout Box
Forum Stats
2863 Members
51 Forums
11039 Topics
Page 1 of 2 1 2 >
Topic Options
#89419 - 23/04/12 05:00 PM M3W oil light comes on with hazard warning lights?
ivanford Offline
Loc: Northern Ireland
When I switch on the hazard warning lights with the ignition switched off the engine oil pressure warning light also illuminates with the hazard warning light on the rev counter.
With the ignition switched on and or with the engine running it does not.
Will a few others check if there car is doing the same.
I'm a bit concerned that I may have a minor wiring issue which might disable the oil pressure warning light.
Edited by ivanford (23/04/12 06:56 PM)
Top
#89428 - 23/04/12 05:54 PM Re: Oil light comes on with hazard warning lights? [Re: ivanford]
DaveW Offline
Loc: Yorkshire
It's not reflecting from inside the gauge is it? When this happens it's usually a dodgy earth.
_________________________
Red Roadster
Top
#89431 - 23/04/12 06:01 PM Re: Oil light comes on with hazard warning lights? [Re: ivanford]
Wirewheel Offline
Loc: South Warwickshire
Hi Ivanford, just checked my Sept 2011 plus4 and no oil light on, with hazards on.
Sorry Ivanford assumed you were talking about your plus4 SS.
Edited by Wirewheel (23/04/12 06:03 PM)
Edit Reason: Wrong vehicle?
Top
#89436 - 23/04/12 06:57 PM Re: Oil light comes on with hazard warning lights? [Re: Wirewheel]
ivanford Offline
It's on the three wheeler, I just want some one else to check if it's the same on their trike.
Top
#89441 - 23/04/12 07:30 PM Re: Oil light comes on with hazard warning lights? [Re: ivanford]
herman01 Offline
Loc: Sweden
Similar on mine M3W:
When I switch on the hazard warning lights with the ignition switched OFF, the engine oil pressure warning light illuminates steady and the hazard warning light twinkles. (separate lamps)
With the ignition switched ON the engine oil pressure warning also illuminates steady.
(warning hazard on or off)
I have not tested with the engine running, but I suppose the engine oil pressure warning light is turned off... sherlock (to late hour to wake up everybody!)
M3W 2012 (nr 32)
Top
#89461 - 23/04/12 10:29 PM Re: Oil light comes on with hazard warning lights? [Re: herman01]
ivanford Offline
Thanks Herman, that makes me confident that they are all like this and that I don't have a problem.
Top
#89557 - 24/04/12 09:09 PM Re: Oil light comes on with hazard warning lights? [Re: ivanford]
Utah9110 Offline
Loc: Florida, U.S.A
Ivanford, I think the correction is you do have a problem...and they are all like that.
It's these little things that worry me when it comes to Morgan ownership. I'm all about putting up with these little things...but here in the States it would be a 400mi trip to get my 3W serviced by a trained technician - is it worth it? Hardly.
Top
#89615 - 25/04/12 08:14 AM Re: Oil light comes on with hazard warning lights? [Re: Utah9110]
ivanford Offline
Hi Utah
I don't even have a dealer here!!
If I need a dealership I have to put the car on a ferry over to the UK mainland (very expensive).
Luckily the M3W isn't a very complex vehicle, almost a motorcycle with three wheels.
But you are absolutley correct, all these little issues should not be present in these vehicles.
Top
#89652 - 25/04/12 11:25 AM Re: Oil light comes on with hazard warning lights? [Re: ivanford]
1560 Offline
Goodwood Drifter
Loc: european union
why not??? part of the whole "charm" that makes a MOG stand out of the crowd!!!
MMC has less employees than Toyota has secretaries for their reliability-engineers
2012 3whlr
Top
#89653 - 25/04/12 11:29 AM Re: Oil light comes on with hazard warning lights? [Re: 1560]
Brian V Offline
Loc: Jersey, Channel Islands
On the whole I'd rather my Morgan stood out from the crowd because of the good things about it, not because of the faults it has (had).
Top
Page 1 of 2 1 2 >
Moderator:  Aeroman
