Who's Online
2 registered (Mi3Wheeler, Richard - Aus), 2 Guests and 17 Spiders online.
Little and Large
Grand Day Out
Mog meets Mog
National Motor Heritage Day
Top Gear Verdict
by Mi3Wheeler
21/05/13 08:04 PM
Killerton Classic Car Day
by AJSki2fly
21/05/13 06:26 PM
I believe the same could be said of Classic Cars
by A11OGE
21/05/13 10:35 AM
+4's with Ecotec swap, a question for you
by flaagan
21/05/13 09:24 AM
Rare Astons - Old and New
by Clipper
21/05/13 07:26 AM
New Member with M3W
by rickmazer
20/05/13 10:44 PM
Prescott photos - with a bit of luck!
by sospan
20/05/13 08:21 PM
gobel, Mats, davewhite, sailingmad, rickmazer
2863 Registered Users
Shout Box
Forum Stats
2863 Members
51 Forums
11039 Topics
Page 3 of 5 < 1 2 3 4 5 >
Topic Options
#90071 - 27/04/12 08:27 PM Re: Handbrake cable [Re: Jays]
ivanford Offline
Loc: Northern Ireland
I put handbrake cables on a VW Polo recently, it was fairly easy and didn't take very long. I removed both brake drums, but only stripped one at a time, so that I could easily see how it all went back together again. The hardest bit was putting the brake shoe springs back on.
Top
#90100 - 27/04/12 10:19 PM Re: Handbrake cable [Re: ivanford]
Jays Offline
Loc: worcestershire UK
If I can't fiddle the cable on, the plan is to just remove the lower spring and ease the rearmost shoe off from the bottom pivot to give a bit more room. Hopefully I wont have to disturb the upper springs which look a real pain!
_________________________
Jay
2010 4/4 "Super Sport "
Top
#90101 - 27/04/12 10:26 PM Re: Handbrake cable [Re: Jays]
Easter Offline
A dodge I picked up when fitting a Triumph m/cycle centre stand spring is to pack the spaces between the coils with washers before re fitting to pre stretch the spring then carefully remove once in situ - without loosing an eye in the process arr
Top
#90103 - 27/04/12 11:15 PM Re: Handbrake cable [Re: Jays]
minikeefy Offline
Loc: Nth. Bucks, England
I would recommend this link to Morganatica It has a good explanation on the Rear brakes (download the PDF file) and advice about refitting shoes. I have tried to get the special AP clips mentioned but had no response from them. I need to find out how to get these replacement springs before I substitute my new EBC Green Shoes.
Any ideas, any one??
Keith
Car 54 - 'Le Mans 62' 4/4 - MSCC - 14089
Top
#90137 - 28/04/12 09:19 AM Re: Handbrake cable [Re: Jays]
Cain Offline
Loc: Cambridgeshire
Hi Jays
Did mine January, Not to bad to do.
Drum off remove spring that holds shoes to back plate, you can then get to the end of the handbrake cable fit new cable in reverse. Before drum can go back on back of auto adjuster, feed cable through original cable route (note some have been fixed in the middle of the wood floor what fun) on replacement ignore middle fixing as it is held both ends. Failing to back off break adjustment will result in not being able to attach to the handbrake leaver.. Drive car to allow brakes to auto adjust. then adjust handbrake. you will need to do this a few times as the cable stretches.
Cain
Mine went in the same place, it is because of the acute turn into the drum, as 4/4 sports have a narrow axel, this is not a problem on wide axel models
Top
#90183 - 28/04/12 03:15 PM Re: Handbrake cable [Re: Cain]
Jays Offline
Thanks for that Cain...useful information. Did you manage to fit the cable from underneath or from inside the car?
Jay
Top
#90276 - 29/04/12 09:26 AM Re: Handbrake cable [Re: Jays]
Cain Offline
Loc: Cambridgeshire
Under the car Jay, I also disconnected the prop at the diff end and zip tied it out of the way for ease of working as my cable was fixed in the prop tunnel. Note I did not re-fix in in middle of prop tunnel as I see no need as it is fixed at both ends of the tunnel.
Cain
Top
#90303 - 29/04/12 02:37 PM Re: Handbrake cable [Re: Cain]
Jays Offline
I'm still working on it! The cable was fastened down in 3 places and also some wiring was zip tied to it in two places so in the end I had no choice but to take the transmission tunnel off......which means seats out etc. I was intending to take the gearbox cover off but with all the screws fixing it to floor and bulkhead, it still won't shift and I don't want to force it. Looking down through it though there is clearly enough room to get in from below to attach the new cable.
Jay
Top
#90304 - 29/04/12 03:01 PM Re: Handbrake cable [Re: Jays]
Wirewheel Offline
Loc: South Warwickshire
Hi Jays, have you heard of these people based in Coventry. They hire out ramps to DIY'ers. Just a thought. They are called rampandwrench.co.uk
I have not used them myself but have found this place just in case.
There used to be one in Bromsgrove however they seem to have stopped trading.
Edited by Wirewheel (29/04/12 03:03 PM)
Edit Reason: Put in web site
Top
#90305 - 29/04/12 03:14 PM Re: Handbrake cable [Re: Jays]
Cain Offline
Loc: Cambridgeshire
Jay I managed from bellow zip tied wiring cables to the handbrake cable.
It was very fiddlie as I have big hands and arms!!!
Top
