Who's Online
1 registered (lotusien), 4 Guests and 13 Spiders online.
BHM Track day - Goodwood (May 2013)
LATEST PAINTING PHOTOS - CHUNKY 4/4'S RACING CAR
Little and Large
Grand Day Out
Mog meets Mog
Norfolk here I come
by pandy
23/05/13 03:50 PM
Supplied plastic hub dish
by Michael H
23/05/13 03:06 PM
New member using my Dad's Morgan, Love it!
by Alasdair Davis
23/05/13 10:30 AM
Jach supplied by MMC
by Robbie
23/05/13 09:57 AM
Thanks for the tip Graham
by Jack The Lad
23/05/13 09:12 AM
Modern or Old?
by PaulJ
23/05/13 08:58 AM
All to start again
by Jack The Lad
22/05/13 09:52 PM
Peter R, willi, lotusien, fathergoose, HMSMotorsport
2873 Registered Users
Shout Box
Forum Stats
2873 Members
51 Forums
11055 Topics
Page 1 of 2 1 2 >
Topic Options
#90597 - 01/05/12 09:16 AM Covers for rear leaf springs
John +4 Offline
Loc: Bucks
I have noticed from time to time a clonk from either side at the rear. I thought it was the warning triangle , first aid kit etc I keep behind the seats.
However to ensure the car was really dry after the rain it got on Sunday I removed the rear carpetto let it dry inside the house.
I took the opportunity to teak oil the wood but I also noticed the covers for the rear springs miss several screws and are loose. They are I think the culprits of the clunk.
Does anyone know the spec of the screws and if the go into wood or metal?
Has anyone had the same problem & solved it?
Top
#90602 - 01/05/12 09:52 AM Re: Covers for rear leaf springs [Re: John +4]
Robbie Offline
Loc: Co Wexford, Ireland
Do you mean the plastic tool tray which is underneath the plywood?? If it is, it is possible that one or more of the tools/jack are "Clunking" off the underside of the wood - the plastic tray is not very stiff and will flex. I suggest you place a thin layer of foam(or neoprene, Dave!!) on top of the tool tray underneath the plywood. This should stop the "clunk"
Cheers!
PS better still - remove the plastic tray and install a better "box" to hold the tools
_________________________
Robbie
Plus4 Aston Martin Mendip Blue
09-WX-2269
"Lord Plus Faw of Kilgibbon"
Top
#90610 - 01/05/12 10:45 AM Re: Covers for rear leaf springs [Re: Robbie]
John +4 Offline
Loc: Bucks
No not the tool box. I don't have one. I mean the covers where the leafspring are bolted at the front of the chassis.
See this link
http://www.gomog.com/allmorgan/allmorgan27.htm#Leaf
They are the bits shown in blue.
Top
#90625 - 01/05/12 02:11 PM Re: Covers for rear leaf springs [Re: John +4]
Robbie Offline
Sorry John - I have no knowlegde of what could cause a clunk there. Perhaps the bolt is Loose??
Robbie
09-WX-2269
Top
#90626 - 01/05/12 02:13 PM Re: Covers for rear leaf springs [Re: Robbie]
John +4 Offline
Loc: Bucks
No the covers themselves are loose & many screws are missing.
I just want to know what ype of screws to use to fix it.
Top
#90630 - 01/05/12 02:49 PM Re: Covers for rear leaf springs [Re: John +4]
Hamwich Offline
Loc: Gloucestershire, UK
I solved the problem of my rear spring covers rattling by the simple expedient of chucking them away. I was worried at first that I would get water, mud, and other crud coming into the cockpit, but it just doesn't seem to happen. Mine were secured with basic woodscrews, bu then my car was built in 1986, when MMC quality standards were in the Stone Age compared to what they are now.
I have to say though that I think they are unlikely to cause a clonk, I would be checking rear spring bolts and linkages, battery security, U bolts, and rear wheel tightness.
Top
#90632 - 01/05/12 02:54 PM Re: Covers for rear leaf springs [Re: Hamwich]
John +4 Offline
Loc: Bucks
Fair point I will do that while the rear shelf is out as well but I checked it before & found nothing.
Top
#90650 - 01/05/12 04:12 PM Re: Covers for rear leaf springs [Re: John +4]
M3W Offline
Loc: Sweden
thinkingCan you not just remove one of the remaining screws and bring it to your local screw shop? If the originals been assembled with an electric screw driver they might have been over tighten and you now need to jump up one size in thread diameter to make them grip in the wood? Or make the hole smaller again with wooden glue + tooth picks/matches.... wine
Top
#90653 - 01/05/12 05:02 PM Re: Covers for rear leaf springs [Re: M3W]
John +4 Offline
Loc: Bucks
Yes that is what I will do if I don't have some suitabe ones. I think though there is a mongrel group of them. My concern was wether they all went into wood.
As for the knock I can reproduce it by bouncing the cover. All the suspension nuts are tight.
Top
#90671 - 01/05/12 06:34 PM Re: Covers for rear leaf springs [Re: John +4]
Jays Offline
Loc: worcestershire UK
John......this photo might give you some idea of whats behind the cover!
Jay
2010 4/4 "Super Sport "
Top
Page 1 of 2 1 2 >
