Who's Online
6 registered (Watty, jezzacrawford, uvk33n, A11OGE, morgan12, R1NGA), 9 Guests and 10 Spiders online.
One week old
WJ Brunel
BHM Track day - Goodwood (May 2013)
LATEST PAINTING PHOTOS - CHUNKY 4/4'S RACING CAR
Little and Large
The Preacher
by Jack The Lad
Today at 09:11 AM
Morgan Serendipity
by Clipper
Yesterday at 09:34 PM
New to forum, just M3W dreams
by lotusien
Yesterday at 08:32 PM
Setting Base Idle on 3.9l +8 Help Please
by AJSki2fly
Yesterday at 06:04 PM
Laughing Len
by tmg513
Yesterday at 12:55 PM
Careful- Nanny is watching you!
by GerryWal
Yesterday at 10:06 AM
Hardtops: Who Has One?
by Simon
Yesterday at 09:36 AM
Peter R, willi, lotusien, fathergoose, HMSMotorsport
2873 Registered Users
Shout Box
Forum Stats
2873 Members
51 Forums
11065 Topics
Page 5 of 7 < 1 2 3 4 5 6 7 >
Topic Options
#90561 - 30/04/12 11:26 PM Re: Throttle bodies for 4/4/ Sport [Re: GLLHG]
Heinz Offline
Loc: Cologne, Germany
Originally Posted By: GLLHG
Another way around it would be to get a half bonnet with scoop ( left hand side as opposed to the orginal triumph engined Plus 4 right hand side job) made by someone like Malvern Sheet metal - would cosy you about £495 and apart from being a really pro way of doing it, it gives an excellent air source for the TB's
That´s what I think, I have already got with the +4SS.
Top
#90589 - 01/05/12 08:44 AM Re: Throttle bodies for 4/4/ Sport [Re: Max5]
Heinz Offline
When looking around in the world wide web I found this solution:
http://www.reverie.ltd.uk/product_detail..._code=R01SE6166
or here complete if someone want´s to buy both items together:
http://www.reverie.ltd.uk/product_detail..._code=R01SE0471
The recommended ITG filter as an internal solution means, you would not fiddle with the extra space for the K&N needed and you could lead the cold air intake just in front of the snorkel.
Top
#90606 - 01/05/12 10:25 AM Re: Throttle bodies for 4/4/ Sport [Re: Heinz]
Max5 Offline
I know from experience that the internal ITG filter will not clear the 60mm air horns on the Aero Racing throttle bodies on the 4/4 using the standard PX600 backplate. I don't know what length the air horns are on the +4SS. There doesn't appear to be enough space to use a stepped backplate as it would move the outside of the airbox into contact with the bonnet.
Don.
Edited by Max5 (01/05/12 10:27 AM)
Top
#90770 - 02/05/12 12:11 PM Re: Throttle bodies for 4/4/ Sport [Re: Max5]
Heinz Offline
I have measured the air horns, they are 40mm (as described on the Jenvey page for Mazda 2.0 throttle body kit) and I phoned Jenvey to be sure. So I can use the internal itg filter.
A cheaper solution could be this one:
http://www.pipercross.net/competition/products_600_airbox.asp
But it looks as one would get warmer air only, because the bow departs the intake from the scoop - and with a filter fitted even more, therefore not getting the benefit of cold air, the scoop in the bonnet delivers.
Top
#90839 - 02/05/12 06:19 PM Re: Throttle bodies for 4/4/ Sport [Re: Heinz]
cerealsurfer Offline
The Pipercross 600 is what I had fitted to my 4/4 race car for the last 2 seasons. It's useful as it's lower profile, but there is a trade off in terms of total potential flow.
Top
#90854 - 02/05/12 08:26 PM Re: Throttle bodies for 4/4/ Sport [Re: cerealsurfer]
Heinz Offline
Hi Cerealsurfer
thanks for your comment. In the meantime I have had a closer view to the pic of Don´s 4/4. It looks like the whole engine is leaner and the throttle bodies are more inside the bonnet. On the P4SS the standard Piper cross airfilter is already using part of the scoop. I guess I have bad luck neither with the Reverie nor with the Piper cross solution as both items are more extended than the bonnet allows.
Top
#90855 - 02/05/12 08:33 PM Re: Throttle bodies for 4/4/ Sport [Re: Heinz]
Hi Cerealsurfer
Indeed... You can see from some of my pics on here we ended up cutting a hole in the inner wheelarch to feed the intake pipe through, fed by an intake in the front wing. Intake space is really constrained. There are some shorter TB's out there which help with packaging.
Top
#90891 - 03/05/12 08:09 AM Re: Throttle bodies for 4/4/ Sport [Re: cerealsurfer]
Max5 Offline
Hi Cerealsurfer,
In the depths of my geriatric mind I seem to recall that varying the length of the air horns can alter the characteristics of the power delivery to some degree. Is it shorter horns = more top end power, longer horns = more low end torque?
Don.
Edited by Max5 (03/05/12 08:10 AM)
Top
#90923 - 03/05/12 10:21 AM Re: Throttle bodies for 4/4/ Sport [Re: Max5]
GLLHG Offline
South Wales Correspondent
Loc: South Wales UK
Sorry to 'butt in ' on the question ( which was of course addressedto cereal but my undertsnading is that the shorter the horn, the power shifts higher up the rev range
( I think there was a very good piece on this either on the Jenvey or ITG website)
Regards,
_________________________
GLLHG
Top
#90926 - 03/05/12 10:50 AM Re: Throttle bodies for 4/4/ Sport [Re: GLLHG]
John +4 Offline
Loc: Bucks
In the Williams F1 museum there is an F1 car with early fuel injection direct into the trumpet (air horn) and the trumpet can also be lengthened or shortened to optimise the airflow.
I think the engine is from Renault but it was 10 years ago or so that I had the opportunity to visit them.
Top
