I've overstocked with emergency sumps during my research period, so can dispose of one if anybody is interested.
It's origin is Mondeo V6. I have given it a thorough clean. To use in an emergency it will either need the ST220 sump gasket, which is a composite alloy/rubber, or could be fitted for a short period with a paper gasket or silicon sealer. Note that this sump differs from the standard Morgan sump by having a thinner flange and does not use the Fel-Pro rubber O profile gasket from the Ford Escape (post 2004). It does not have the extra hole drilled in the vertical offside face which fixes it to the bellhousing, but this is a fairly simple mod - see my sump thread.
I would like £40 including postage.
It's a fix which will keep you mobile until you can source a replacement or have a repair sorted.
