Who's Online
3 registered (Soleng, Whart, JBu1), 10 Guests and 11 Spiders online.
Luggage Packed
1923 Darmont Special 3W
British Ambassador opens China Showroom
Darmont Special 3 Wheeler
More Aeromax Teasers
Morgtastic mate
by oldskoolsboy
19/06/13 08:30 PM
Charles Morgan in Autocar
by Jays
19/06/13 08:20 PM
Experiences with wheels
by Heinz
19/06/13 07:42 PM
SU carbs and fast idle
by Dick H
19/06/13 06:16 PM
AERO REGISTER UPDATED
by Gajet
19/06/13 05:34 PM
Roadster rear brake pipes.
by NeilM
19/06/13 05:18 PM
Spotted Mog
by Gambalunga
19/06/13 03:30 PM
Colin Lewis, farfinator, EdR, Jim Myers, The Seeker
2921 Registered Users
Shout Box
Forum Stats
2921 Members
51 Forums
11356 Topics
Topic Options
#92146 - 12/05/12 08:46 AM rear axle drain plug
Gallanach Offline
The square end of the dif drain plug on my 1994 4/4 has been destroyed, either by speed bumps or heavy handed spannering. Has any one else had this problem and have they come up with a clever solution? Thanks
Top
#92148 - 12/05/12 09:01 AM Re: rear axle drain plug [Re: Gallanach]
tmg513 Offline
Loc: Powick
Depending upon how bad it is you could:
(a) square it back up and get a smaller spanner on it.
(b) get a small set of stillsons on it.
(c) drill it and use a screw extractor on it.
Could you post a photo of it?
_________________________
1972 4/4 2 Seater
2008 Triumph Sprint ST 1050
Top
#92151 - 12/05/12 10:22 AM Re: rear axle drain plug [Re: tmg513]
Gallanach Offline
Thank you tmg513 I have tried a & b and it has just destroyed the plug further. I suspect I will have to take the axle out and drill do you know if you can remove the axle without taking the brake back plates off? Thanks
Top
#92152 - 12/05/12 10:33 AM Re: rear axle drain plug [Re: Gallanach]
tmg513 Offline
Loc: Powick
Can it not be done with the axle in situ? I think I'd be inclined to find a friendly local mechanic and get him to put it up on a lift and see if he can sort it. Obviously you'll need a replacement plug first.
1972 4/4 2 Seater
Top
#92159 - 12/05/12 12:32 PM Re: rear axle drain plug [Re: tmg513]
smsevencqy Offline
Loc: Southern Sweden
Try a pipe wrench, it will do it.
Ken in Sweden
Top
#92163 - 12/05/12 01:00 PM Re: rear axle drain plug [Re: smsevencqy]
Dean-Royal Offline
Loc: UK (up north)
one little trick we used to do, especially easier once Mig welders were made available (brazing prior to that) was to weld a NUT onto the effected stud VUOLA a new head available to your spanner, also the slight heat consentration to the area helped
33 MAX v SPIDERMAN
Top
#92169 - 12/05/12 04:05 PM Re: rear axle drain plug [Re: Dean-Royal]
DaveW Offline
Loc: Yorkshire
Heat is the key to this. Heat plus mole grips are my favourite fix. It's probably been overtightened in the past.
No need to get the axle off.
Red Roadster
Top
#92186 - 12/05/12 05:53 PM Re: rear axle drain plug [Re: DaveW]
ivanford Offline
Loc: Northern Ireland
I would go for mig welding a nut onto it as well. I have sucessfully use this on buggered up locking wheel nuts many times.
Top
#92271 - 13/05/12 06:23 PM Re: rear axle drain plug [Re: ivanford]
Edgar 1969 4/4 Offline
Loc: Lancashire
As Ken mentioned I would try a pipe wrench (Stilsons) first. I would be surprised if you couldnt move it with this providing you have enough room to get a good purchase on the damaged square end.
1969 4/4
2006 70th Anniversary 4/4
Top
