Who's Online
13 registered (dino642, Dave Turner, Neilda, Soleng, tmg513, Halcyon, Thorsten, DJC, flyfisher, sawman, Sir Percival, Marc Pedersen, petemog), 17 Guests and 10 Spiders online.
LATEST PAINTING PHOTOS - CHUNKY 4/4'S RACING CAR
Little and Large
Grand Day Out
Mog meets Mog
National Motor Heritage Day
Aero Racing 5" driving lamps
by nputtick
22/05/13 02:12 PM
Roadster dashboard
by stumog
22/05/13 11:06 AM
Morgan Aero 8 on a Ferry!
by TheCoot
22/05/13 09:30 AM
Yah - they posted it on-line
by Alistair
22/05/13 08:25 AM
Daft Garage
by Clipper
22/05/13 07:44 AM
Adjusting +8 Tming
by AJSki2fly
22/05/13 07:38 AM
Top Gear Verdict
by Mi3Wheeler
21/05/13 08:04 PM
fathergoose, HMSMotorsport, tide, Dk Super Dry 3W, Dr John
2870 Registered Users
Shout Box
Forum Stats
2870 Members
51 Forums
11047 Topics
Page 3 of 3 < 1 2 3
Topic Options
#93275 - 23/05/12 01:40 PM Re: CAR DESIGN THAT DRIVES YOU MAD [Re: John +4]
Dean-Royal Offline
Loc: UK (up north)
How about clutch on a 504 pick -up, with fixed prop, full back axle out, bit different to MK2 Cavalier, side plate off the Gear/Box, clutch changed in 40mins, go on Vauxhall notworthy
Edited by Dean-Royal (23/05/12 01:42 PM)
_________________________
33 MAX v SPIDERMAN
Top
#98357 - 17/07/12 01:48 PM Re: CAR DESIGN THAT DRIVES YOU MAD [Re: Dean-Royal]
terry1956 Offline
Loc: yeovil
the bloo-- bad suspension on the morgan, at times the rocking motion makes me feel sort of sea sick.
Top
#98762 - 20/07/12 07:10 PM Re: CAR DESIGN THAT DRIVES YOU MAD [Re: terry1956]
howard Offline
the auto gearbox on my wife's Smart roadster. 5 second wait before a connection is made. Pity since the rest of the car is excellent.
Elise R, Starlight 35 and R1200GS
Top
#98768 - 20/07/12 07:49 PM Re: CAR DESIGN THAT DRIVES YOU MAD [Re: John +4]
sospan Offline
Loc: Llanelli
4/4 rear lever arm dampers - the casing does not leave enough room for good spanner fit.
One came a bit loose.
Trouble is the damper housing gets in the way of an open ended spanner and ring spanners were too fat to fit over the nut. I ended up grinding back an old ring spanner to make it thin enough to fit but not too thin to split.
GGGGRRRRR!!!
The spanner is now a permanent fixture in my toolroll just in case....
Top
#98778 - 20/07/12 08:41 PM Re: CAR DESIGN THAT DRIVES YOU MAD [Re: sospan]
Viper Offline
Sir S1'a'lot
Loc: Sevenoaks,Kent
Ferrari California ....... Everything about it
The ugliest car on the road, a total mis match of lines.
Horrid....truly horrid
Life is a bowl full of cherries....there you go wink
Top
#98806 - 21/07/12 08:15 AM Re: CAR DESIGN THAT DRIVES YOU MAD [Re: Viper]
Alistair Offline
Smile, it confuses them
Loc: Hampshire
For me the frustrating wait whilst the autobox on my Mercedes responds to the instruction to change from forward to reverse or vice-versa.
If you are executing a U-turn in traffic (it is a large car despite its good turning circle) it seems to take forever to make the transition. My VW was a lot faster in making the change.
Its not 1 - pause - 2, its is more like 1 - - - - pause - - - - 2
getting in and out of parking spaces must put my blood pressure up a couple of notches.
Fleet reboot in progress.
Top
#98895 - 22/07/12 07:15 AM Re: CAR DESIGN THAT DRIVES YOU MAD [Re: Dean-Royal]
Pete.G Offline
Loc: South Hams, Devon
Sprite Mk1 bug-eye , bonnet hinges - ended up replacing.
Mini early – already been said – distributor behind front grill so got a soaking each time it was wet. Floor starter button awkward to get to and fix
Pete
Currently 05 plate Freelander
Mog Owner 1980 - 1986 & hopefully again soon
Top
#98903 - 22/07/12 10:38 AM Re: CAR DESIGN THAT DRIVES YOU MAD [Re: Alistair]
Dean-Royal Offline
Loc: UK (up north)
How old is the car, or more to the point the GearBox, as hit done lots of work?
33 MAX v SPIDERMAN
Top
#98904 - 22/07/12 10:42 AM Re: CAR DESIGN THAT DRIVES YOU MAD [Re: howard]
Dean-Royal Offline
Loc: UK (up north)
We have a Smart in the Family, my daughter drives it, i know what you mean, i when driving it tend to just release the pressure of the throttle a little to let the gear change, i find it is better to use manual mode when the Car is first started from cold for app the first 2-3 miles then flick into Auto Mode, see if that helps.
33 MAX v SPIDERMAN
Top
Page 3 of 3 < 1 2 3
