14 registered (62TC, John +4, Rudolf, RMP, Jays, NeilM, hitech, DJC, Gambalunga, deano, Martyn Culling, Gajet, Quicksilver, cerealsurfer),
Guests and
Spiders online. |
2849 Members
51 Forums
10998 Topics
#93738 - 27/05/12 09:02 AM
Daft Coolant Question
Loc: Perth, WA, Australia
Hi there, I noticed last weekend a couple of drips (and I mean just that) from a coolant hose going to the heater. I tightened up the clamp and all is good (no drip all week). Whilst I am sure that the loss is tiny I would like to check the coolant level. How? I don't have a resiviour as per "modern cars" so I assumed I would take off the radiator cap and then fill until coolant from the "overflow pipe" close to the radiator cap started to flow out. I turned the radiator cap and it seems to reach a "stop" but I cannot lift it up/off. I don't want to force it. Where am I going wrong? System looks like this: Click Here for Graphic Many thanks in advance! R.
Top
#93739 - 27/05/12 09:14 AM
Re: Daft Coolant Question
[Re: Richard - Aus]
Loc: southwest France
Richard, on my first 76 Morgan, the cap had to be pushed down to release it.
Top
#93752 - 27/05/12 11:41 AM
[Re: Richard - Aus]
Loc: Lincolnshire
With a cold engine you just need the water up to the bottom of the filler neck. When it heats up it'll expand and any excess will be dumped out of the overflow. Regards
_________________________
Simon
Top
#93753 - 27/05/12 12:05 PM
[Re: Guten]
Top
#93773 - 27/05/12 05:20 PM
[Re: Richard - Aus]
On mine Richard I fixed the overflow tube into the screw on lid of a plastic cyclists water bottle low down on the bulkhead . That seemed to work.
Top
#93775 - 27/05/12 05:51 PM
[Re: Guten]
Loc: UK (up north)
With a cold engine you just need the water up to the bottom of the filler neck. When it heats up it'll expand and any excess will be dumped out of the overflow. Regards I am going to put my 2pence worth in again as i feel this advise from my experience is not quite right, if you have a standard old type steel radiator that does not have a seperate expansion bottle, you should not be filling this up to the neck, the Top of the radiator is actually the expansion area, remove the Rad cap (when engine is cold) you should see water just above the finns inside the radiator, if not top up until just above these. re fit the cap, if you fill the water to the top of the neck,ie approx 1 1/2 to 2 inches above finns it is possible the excessive water when up to working temp will push out of the overflow, but it is also possible it will start syphoning and not stop this will mean more water will exit the radiator than required and overheating can occur. Hoping not to offend Dean
33 MAX v SPIDERMAN
Top
#93777 - 27/05/12 05:57 PM
[Re: Dean-Royal]
Loc: Lincolnshire
With a cold engine you just need the water up to the bottom of the filler neck. When it heats up it'll expand and any excess will be dumped out of the overflow. Regards I am going to put my 2pence worth in again as i feel this advise from my experience is not quite right, if you have a standard old type steel radiator that does not have a seperate expansion bottle, you should not be filling this up to the neck, the Top of the radiator is actually the expansion area, remove the Rad cap (when engine is cold) you should see water just above the finns inside the radiator, if not top up until just above these. re fit the cap, if you fill the water to the top of the neck,ie approx 1 1/2 to 2 inches above finns it is possible the excessive water when up to working temp will push out of the overflow, but it is also possible it will start syphoning and not stop this will mean more water will exit the radiator than required and overheating can occur. Hoping not to offend Dean Quite right if there wasn't a pressure cap but his attached schematic shows there is one. Regards
Simon
Top
#93782 - 27/05/12 06:21 PM
[Re: Guten]
Loc: UK (up north)
Richard, been in Aus with higher temps than in Britain, iam curious as to whether you have overheating problems in general, ie how does the car cope in traffic jams etc
Edited by Dean-Royal (27/05/12 06:22 PM)
33 MAX v SPIDERMAN
Top
