11 registered (BLG83, PaulJ, watasnake, gatewright, deano, PJB, jonathan7barrow, NeilM, Rufus3, Michael H, Martyn Culling),
Guests and
Spiders online. |
2873 Members
51 Forums
11060 Topics
#96152 - 21/06/12 07:52 AM
Re: Replacing the Door Hinge Pin?
[Re: DaveW]
Loc: Perthshire & London
Might try turning the hinge pin.. Also the larger diameter pins sound good as well. Do you need a special tool to fit them or are they just a straight swap? Are they on the heart of England website? Thanks Will
Top
#96193 - 21/06/12 02:24 PM
[Re: John +4]
Loc: Switzerland
On my 4/4 the hinges have worn, not the pins - and the holes of the new hinges didn't align with the old - lots of swearing!
To fit oversize pins I suppose that the holes have to be reamed. How ist this best done?
_________________________
1967 4/4 1500 Comp. 1935 Super Sports Barrelback
Top
#96709 - 27/06/12 03:44 PM
[Re: DaveW]
Loc: Missouri
I took mine out, laid over a iron block with the pin head hanging over the side , whacked the center of the pin with a peen hammer,tapped back in place. not loose now.
Top
#97459 - 06/07/12 06:18 PM
[Re: Richard - Aus]
Loc: Tynemouth UK
I reamed mine out with a 7mm reamer, by hand in situ, mind they are brass on a DHC. Tony
Top
#97483 - 07/07/12 02:19 PM
[Re: TTC]
Loc: Switzerland
Thanks, Tony. Mine are brass, too. How did you keep them in line when reaming or is this not critical (reaming the two parts separately)?
Frank
Top
#97522 - 08/07/12 07:50 AM
[Re: Bodger]
Loc: Tynemouth UK
Hi Frank, As I said I did them in situ so the other hinge tended to keep things in line. However I dont think this is critical as you are only re-cutting the existing hole and cannot go far wrong, why would you need to ream separately???. I got the 7mm pins from H 0f E, difficult bit was sourcing a 7mm reamer.
Tony
Top
#97566 - 08/07/12 02:21 PM
[Re: TTC]
Loc: Switzerland
Thanks again, Tony. To get a 7 mm reamer should be easier (hopefully)in my "metric" country than in the UK.
Frank
Top
