Who's Online
6 registered (Quicksilver, Ruud Visser, Gambalunga, S Marsh, Maxakarudy, Gin), 17 Guests and 12 Spiders online.
17th of May
How NOT to Go Around Redgate Corner.
Yet Another Bike Photo!
Napier Bentley
Rear fender alignment
Engine monitor light. On 2012 Roadster 3.7
by Randall
18/05/13 09:06 PM
Stainless Reverse and Fog lights
by AJSki2fly
18/05/13 04:06 PM
Police Lotus
by 4/4sportsfun
18/05/13 11:19 AM
Morgans at RAF Benson
by John +4
18/05/13 10:26 AM
A little taster of Cajun for Saturday morning
by 4/4sportsfun
18/05/13 06:41 AM
Mickleover Village Day
by PhilRoyle
17/05/13 06:56 PM
Gumball 3000 and Aero Coupe
by Ale_72
17/05/13 01:53 PM
PGlyde, Mike Sutton, mutley, Brian - NZ, Flagstone
2849 Registered Users
Shout Box
Forum Stats
2849 Members
51 Forums
11002 Topics
Page 4 of 6 < 1 2 3 4 5 6 >
Topic Options
#96426 - 24/06/12 06:04 AM Re: Flashing Immobiliser Light on a new 4/4 [Re: nputtick]
Charlottendal Offline
Loc: Ulricehamn, Sweden
Originally Posted By: nputtick
It's hard to believe that simply extending two conductors to an LED would invalidate any warranty in any meaningful way. and is a very useful deterrent when leaving the car parked, open, in a public place.
This is exactly my point.
//Bosse
_________________________
4/4, Sport White (Ivory) 2011), Smart Roadster Coupé Yellow, 2003
Top
#96427 - 24/06/12 06:19 AM Re: Flashing Immobiliser Light on a new 4/4 [Re: Charlottendal]
Easter Offline
If it we're that simple I think even MMC might have managed it. smile I don't think a Morgan without the visible immobilser is any more likey to be nicked than one that winks
Top
#96433 - 24/06/12 09:05 AM Re: Flashing Immobiliser Light on a new 4/4 [Re: IcePack]
OZ 4/4 Offline
Loc: Sydney, Australia
I have the same issue with my 2011 4/4. The fibre optic solution works. I purchased a length of multi strand cable for a few dollars from a lighting store. AS a test, I used Plasticine to hold the cable square to the light in the body of the immobiliser and a very clear red flashing light appeared at the end. It was a tight fit but it could be made to work on a permanent basis.
I used an inspection camera to look behind the dash but could not find the LED socket (I did not spend much time looking when it wasn’t obvious)
From the front it looks like an easy task to fit the end of the cable in the lens or replace it with a suitable unit. You will need to remove the dash but this is a job I am not prepared to do while the car is under warranty unless I get it done by a licensed auto electrician.
I found it annoying that Morgan tell you the car has an immobiliser and the little light on the dash is the immobiliser indicator but you are not told the two are not connected! As highlighted elsewhere in this thread, car theft is not a major risk to a Morgan owner but anything to dissuade a potential joy rider or opportunist is worthwhile. That’s why the light is there in the first place. The fact that the light is there and not flashing may encourage unwelcome attention.
Top
#96631 - 26/06/12 06:33 PM Re: Flashing Immobiliser Light on a new 4/4 [Re: OZ 4/4]
nputtick Offline
Loc: N.Yorks, UK
The flashing light is, I'm sure, an effective and worthwhile deterrent. However - thinking laterally - it wouldn't even have to be connected to the immobiliser! I'm sure you could just fit a flashing LED circuit and it would do the job just as well.
Personally I'd get my soldering iron out and fix it, warranty or not.
Nigel
Top
#96635 - 26/06/12 06:55 PM Re: Flashing Immobiliser Light on a new 4/4 [Re: IcePack]
trevmar Offline
Top
#96663 - 27/06/12 07:07 AM Re: Flashing Immobiliser Light on a new 4/4 [Re: nputtick]
OZ 4/4 Offline
Nice, I like the concept
Top
#96724 - 27/06/12 05:57 PM Re: Flashing Immobiliser Light on a new 4/4 [Re: OZ 4/4]
DaveV Offline
Loc: Hampshire
Having recently taken the dash of my Plus 4 apart to investigate an overly flashy imobiliser light (see other post) I have some pictures of a Plus 4 dash that may help. If the 4/4/ dash is similar I find it hard to see how there could be an issue unless someone moved the hole for the LED without first measuring the length of wire available. Changing the flasher sounder is not something that is as simple as changing a relay.
Description: Picture 1: the dash tipped forward tacho on the right with the dash wiring assembly still connected.
Description: Picture 2: Now disconnected with back cover removed. You can just make out the ribon cable to the lower set of warning lights.
Description: Picture 3: PCB lifted to show other side. LED wiring now clear small circular thing on right is the flasher sounder
2008 Plus 4
Top
#96771 - 28/06/12 03:18 AM Re: Flashing Immobiliser Light on a new 4/4 [Re: DaveV]
OZ 4/4 Offline
Thanks DaveV, very helpful indeed however I suspect the immobiliser on the 2011 4/4 is different to the one fitted to the Plus 4 and there is no wire to the dash. Recent delivered 4/4s and Plus 4s to this part of the world have been configured this way.
I might just leave this alone for the moment but many thanks for the response and photos.
Top
#96785 - 28/06/12 09:03 AM Re: Flashing Immobiliser Light on a new 4/4 [Re: OZ 4/4]
Jays Offline
Loc: worcestershire UK
I understand from morgan that the immobiliser light is set into the Ford electronics box behind the dash and there is no cable to extend. Fibre optic is probably the only way forward although I'n thinking of a dummy flashing led.
Jay
2010 4/4 "Super Sport "
Top
#96895 - 29/06/12 11:21 AM Re: Flashing Immobiliser Light on a new 4/4 [Re: DaveV]
Thank you very much for the pictures!
Next week I am going to the Morgan Centre Sweden and have it fixed. Then I am going to take some photos from behind the dash. May be it will differ from +4.
If the LED is soldered direct on the circuit board, then it can be unsoldered and lifted up to put a wire to the LED.
If this is impossible, I will bring a light conductor to see if it can be used instead.
To put an dumb flashing LED in the dash, I do not see as an alternative, as one then have to have a separate switch to switch it of under driving conditions.
//Bosse
Top
