Who's Online
8 registered (bilibib, HJP, Blake, mphcarpaintings, SCX358G, Alistair, A11OGE, John Winn), 12 Guests and 17 Spiders online.
LATEST PAINTING PHOTOS - CHUNKY 4/4'S RACING CAR
Little and Large
Grand Day Out
Mog meets Mog
National Motor Heritage Day
All to start again
by Jack The Lad
22/05/13 09:52 PM
Aero Racing 5" driving lamps
by nputtick
22/05/13 02:12 PM
Roadster dashboard
by stumog
22/05/13 11:06 AM
Morgan Aero 8 on a Ferry!
by TheCoot
22/05/13 09:30 AM
Yah - they posted it on-line
by Alistair
22/05/13 08:25 AM
Daft Garage
by Clipper
22/05/13 07:44 AM
Adjusting +8 Tming
by AJSki2fly
22/05/13 07:38 AM
fathergoose, HMSMotorsport, tide, Dk Super Dry 3W, Dr John
2870 Registered Users
Shout Box
Forum Stats
2870 Members
51 Forums
11048 Topics
Page 2 of 3 < 1 2 3 >
Topic Options
#96152 - 21/06/12 07:52 AM Re: Replacing the Door Hinge Pin? [Re: DaveW]
flyfisher Offline
Loc: Perthshire & London
Might try turning the hinge pin.. Also the larger diameter pins sound good as well. Do you need a special tool to fit them or are they just a straight swap? Are they on the heart of England website?
Thanks
Will
Top
#96160 - 21/06/12 08:30 AM Re: Replacing the Door Hinge Pin? [Re: flyfisher]
John +4 Offline
Loc: Bucks
I bought them off HoE. They are a push fit. Obviuosly you do 1 at a time and with the door closed.
Top
#96193 - 21/06/12 02:24 PM Re: Replacing the Door Hinge Pin? [Re: John +4]
Bodger Offline
Loc: Switzerland
On my 4/4 the hinges have worn, not the pins - and the holes of the new hinges didn't align with the old - lots of swearing!
To fit oversize pins I suppose that the holes have to be reamed. How ist this best done?
_________________________
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Top
#96709 - 27/06/12 03:44 PM Re: Replacing the Door Hinge Pin? [Re: DaveW]
Sherlock Offline
Loc: Missouri
I took mine out, laid over a iron block with the pin head hanging over the side , whacked the center of the pin with a peen hammer,tapped back in place. not loose now.
Top
#96720 - 27/06/12 05:30 PM Re: Replacing the Door Hinge Pin? [Re: Sherlock]
smsevencqy Offline
Loc: Southern Sweden
Violence usually works!
Ken.
Top
#96747 - 27/06/12 07:38 PM Re: Replacing the Door Hinge Pin? [Re: smsevencqy]
Richard - Aus Offline
Loc: Perth, WA, Australia
Irish screwdriver smile
Top
#97459 - 06/07/12 06:18 PM Re: Replacing the Door Hinge Pin? [Re: Richard - Aus]
TTC Offline
Loc: Tynemouth UK
I reamed mine out with a 7mm reamer, by hand in situ, mind they are brass on a DHC.
Tony
Top
#97483 - 07/07/12 02:19 PM Re: Replacing the Door Hinge Pin? [Re: TTC]
Bodger Offline
Loc: Switzerland
Thanks, Tony. Mine are brass, too. How did you keep them in line when reaming or is this not critical (reaming the two parts separately)?
Frank
1967 4/4 1500 Comp.
Top
#97522 - 08/07/12 07:50 AM Re: Replacing the Door Hinge Pin? [Re: Bodger]
TTC Offline
Loc: Tynemouth UK
Hi Frank,
As I said I did them in situ so the other hinge tended to keep things in line. However I dont think this is critical as you are only re-cutting the existing hole and cannot go far wrong, why would you need to ream separately???. I got the 7mm pins from H 0f E, difficult bit was sourcing a 7mm reamer.
Tony
Top
#97566 - 08/07/12 02:21 PM Re: Replacing the Door Hinge Pin? [Re: TTC]
Bodger Offline
Loc: Switzerland
Thanks again, Tony. To get a 7 mm reamer should be easier (hopefully)in my "metric" country than in the UK.
Frank
1967 4/4 1500 Comp.
Top
