Who's Online
7 registered (Bonniya, 1560, Soleng, GerryWal, 64alex, Richard - Aus, deano), 6 Guests and 11 Spiders online.
Luggage Packed
1923 Darmont Special 3W
British Ambassador opens China Showroom
Darmont Special 3 Wheeler
More Aeromax Teasers
Morgtastic mate
by oldskoolsboy
19/06/13 08:30 PM
Charles Morgan in Autocar
by Jays
19/06/13 08:20 PM
Experiences with wheels
by Heinz
19/06/13 07:42 PM
SU carbs and fast idle
by Dick H
19/06/13 06:16 PM
AERO REGISTER UPDATED
by Gajet
19/06/13 05:34 PM
Roadster rear brake pipes.
by NeilM
19/06/13 05:18 PM
Spotted Mog
by Gambalunga
19/06/13 03:30 PM
Colin Lewis, farfinator, EdR, Jim Myers, The Seeker
2921 Registered Users
Shout Box
Forum Stats
2921 Members
51 Forums
11356 Topics
Page 1 of 2 1 2 >
Topic Options
#98851 - 21/07/12 06:09 PM S1 dies
Viper Offline
Sir S1'a'lot
Loc: Sevenoaks,Kent
Idles OK when its cold but as soon as its slightly warm it cuts out.
Any ideas?
Thought it might be the MAF sensor??
_________________________
Life is a bowl full of cherries....there you go wink
Top
#98877 - 21/07/12 10:17 PM Re: S1 dies [Re: Viper]
asbojohn Offline
le Asbo du Bling
Loc: Cambridgeshire
Would seem a good place to start, can you get and diagnostic kit on it.
When I had issues with my S2 took it to local BMW place
Why have one colour when you can have them all wink
Top
#98892 - 22/07/12 06:14 AM Re: S1 dies [Re: asbojohn]
346VAB Offline
Loc: London
Hi, diagnostics just read error codes and the RAC/AA can do that FOC, try Googling BMW 540i cuts out when hot and see what results you get. Having read some of the threads it would point towards the MAF.
Kind regards
Chris
Aero 8 Series 1
Audi TT Mk1
Top
#98902 - 22/07/12 10:37 AM Re: S1 dies [Re: 346VAB]
mogic Offline
if you unplug the MAF sensor, the ecu will revert to a default settling. Should the car perform normally with this disconnected, the MAF is at fault.
Top
#98912 - 22/07/12 12:25 PM Re: S1 dies [Re: mogic]
Graham, G4FUJ Offline
Loc: Cheltenham, GLos. UK
Or it may just be poor connections to the MAF itself...
Cheers,
'01 Freelander TD4; '90 Defender 90 SW
Top
#98972 - 23/07/12 04:47 AM Re: S1 dies [Re: Viper]
orthodoc Offline
Loc: Kent, Spain, Denmark
Had that on my S1 - Air Mass sensor fault read
Keith @ BHM diagnosed it over the phone! thumbs
New joints for old!
Top
#98988 - 23/07/12 08:35 AM Re: S1 dies [Re: orthodoc]
terryg Offline
Loc: (too) nr Slough
Had a similar fault on another car. Replaced the MAF to no avail, and tried a few other things too. Problem persisted... until we looked at the catalyst! The matrix had broken apart and a large 'lump' was loose in the housing. After a short period of running the lump had been pushed by exhaust gas into the exiting pipe, blocking it - result, engine died. It wasn't until after some cooling that the lump fell back to re-open the pipe.
Almost certainly not your problem but an interesting variation all the same - that took some finding.
Terry (+8)
Top
#99461 - 27/07/12 12:17 PM Re: S1 dies [Re: terryg]
Philippo Offline
Loc: Toulouse, France
Hello Viper
Did you get to the bottom of your problem?
I replaced the MAF on my S1 three years ago, though the symptoms were very different; I had one cylinder bank running rich, which, I don't understand since there is only one MAF that feeds info to ECU.
For info, though car couldn't be more different, Just replaced the crank position sensor on another car (Smart City Coupe) after similar symptoms to yours, e.g. engine cutting out when warm. Problem solved.
Cheers
Philip
Philip
Top
#99463 - 27/07/12 12:20 PM Re: S1 dies [Re: Philippo]
Dean-Royal Offline
Loc: UK (up north)
Originally Posted By: Philippo
Hello Viper
Cheers
Philip
Just replaced the Crank Sensor on the Smart for same reason. sorted
33 MAX v SPIDERMAN
Top
#99891 - 31/07/12 04:50 PM Re: S1 dies [Re: Dean-Royal]
Philippo Offline
Calling Viper. The suspense is killing me, what was the problem?
Cheers
Philip
Top
Page 1 of 2 1 2 >
