Who's Online
2 registered (deano, Barmar), 9 Guests and 18 Spiders online.
Little and Large
Grand Day Out
Mog meets Mog
National Motor Heritage Day
Top Gear Verdict
by Mi3Wheeler
Yesterday at 08:04 PM
Killerton Classic Car Day
by AJSki2fly
Yesterday at 06:26 PM
I believe the same could be said of Classic Cars
by A11OGE
Yesterday at 10:35 AM
+4's with Ecotec swap, a question for you
by flaagan
Yesterday at 09:24 AM
Rare Astons - Old and New
by Clipper
Yesterday at 07:26 AM
New Member with M3W
by rickmazer
20/05/13 10:44 PM
Prescott photos - with a bit of luck!
by sospan
20/05/13 08:21 PM
gobel, Mats, davewhite, sailingmad, rickmazer
2863 Registered Users
Shout Box
Forum Stats
2863 Members
51 Forums
11039 Topics
Page 1 of 2 1 2 >
Topic Options
#99842 - 30/07/12 09:16 PM Rear Suspension Improvements 60's 4/4
Edgar 1969 4/4 Offline
Loc: Lancashire
I'm sure this must have been covered before.
Will the newer rear suspension set up with the hoop and telescopic shock absorbers fit a narrow track 4/4 from the 60's?. Looking at some photos of the newer cars with the wider track there didnt seem to be that much room hence the question.
_________________________
1969 4/4
2006 70th Anniversary 4/4
Top
#99853 - 31/07/12 07:18 AM Re: Rear Suspension Improvements 60's 4/4 [Re: Edgar 1969 4/4]
Graham, G4FUJ Offline
Loc: Cheltenham, GLos. UK
Talk to Tim Ayres at New Elms. http://www.newelmsmorgan.com/
They now have Rutherford Engineering parts. They will know whether there is a kit available for the earlier cars.
Please post up any results, there's quite a few older cars here.
Good luck!
Edited by Graham, G4FUJ (31/07/12 09:49 AM)
Edit Reason: Added link
'01 Freelander TD4; '90 Defender 90 SW
Top
#99856 - 31/07/12 08:06 AM Re: Rear Suspension Improvements 60's 4/4 [Re: Graham, G4FUJ]
A11OGE Offline
Loc: Reading
Good luck!
Had it done on my 1989 4/4, which I believe is identical to yours, using Rutherford parts. There are (or where 5 years ago) two option avaiable. One needed to make a slight cut in the woodwork, but nothing drastic. As Graham has said, give Tim Ayres a call.
Top
#99860 - 31/07/12 09:05 AM Re: Rear Suspension Improvements 60's 4/4 [Re: A11OGE]
meabh Offline
Loc: southwest France
My 89 plus four (39inch chassis width I think) has a factory hoop.
Top
#99889 - 31/07/12 04:41 PM Re: Rear Suspension Improvements 60's 4/4 [Re: meabh]
Jim Mountain Offline
Loc: Chesham Bucks
the hoop will fit, the chassis is the same, btr axle is wider so gives extra width
Top
#99894 - 31/07/12 05:06 PM Re: Rear Suspension Improvements 60's 4/4 [Re: Jim Mountain]
Martyn Culling Offline
Loc: Snorbans, UK
Unless your car is radically different from my 4/4 made in 1972, a Rutherford kit should fit fine. I have one and fitted it when the factory were still building lever shock absorber cars, ie pre-dates the current hoop etc.
1930 Super Sport Aero 'The Elk'
Top
#99937 - 01/08/12 11:25 AM Re: Rear Suspension Improvements 60's 4/4 [Re: Martyn Culling]
Loc: Lancashire
Thanks for all the information. I am aware of the Rutherford kits and New Elms. I will give New Elms a call as suggested.
1969 4/4
Top
#99980 - 01/08/12 07:49 PM Re: Rear Suspension Improvements 60's 4/4 [Re: Edgar 1969 4/4]
Loc: Lancashire
Spoke to Tim Ayres today and discussed rear suspension options. The Rutherford kit seems to be the most suitable, so will be ordering that once the next batch is ready. Helpful chap and he was born in the same town as me and one of his parents worked for Hawkers, as my Mother did - small World.
1969 4/4
Top
#99996 - 01/08/12 09:28 PM Re: Rear Suspension Improvements 60's 4/4 [Re: Edgar 1969 4/4]
There y'are. Knew Tim and the team would not let you down! thumbs
Top
#100039 - 02/08/12 12:05 PM Re: Rear Suspension Improvements 60's 4/4 [Re: Graham, G4FUJ]
Loc: Lancashire
Much obliged Graham. I took some photo's of your Morgan as its very similar to mine in many ways i.e. nicely used - although I have just started stripping mine down for a re-build, hence the reason I was at Gaydon in the Defender.
1969 4/4
Top
Page 1 of 2 1 2 >
