Who's Online
14 registered (herman01, Jack The Lad, 4/4sportsfun, shiremog, Neilda, tmg513, Bobajobbob, Wirewheel, ralf-o, DJC, sospan, deano, asbojohn, Soggysocks), 25 Guests and 10 Spiders online.
Sunday lunchtime at the pub.
Nordkapp at Donington
Peter Morgan Memorial Races, Donington
Gingin, WA - British Car Show 2013 (Non Morgans)
Spares for a long trip
by CJB
20/05/13 05:06 PM
Any other M3W forums out there?
by Crowbar
20/05/13 05:04 PM
3 wheeler front tires
by rickmazer
20/05/13 05:02 PM
+8 won't start.
by The Wrinklies
20/05/13 09:42 AM
For Sospan
by Jays
20/05/13 08:32 AM
A Great Weekend
by lopesd
20/05/13 07:11 AM
Thermo fan on 1974 4/4 4str
by 1955er
20/05/13 06:20 AM
gobel, Mats, davewhite, sailingmad, rickmazer
2864 Registered Users
Shout Box
Forum Stats
2864 Members
51 Forums
11025 Topics
Page 11 of 13 < 1 2 ... 9 10 11 12 13 >
Topic Options
#99625 - 28/07/12 06:53 PM Re: M3W modifications ? [Re: Mi3Wheeler]
asbojohn Online   content
le Asbo du Bling
Loc: Cambridgeshire
Looking at that I don't think you'll have any problems with size.
I've probably had to leave 10-15mm at one end for the hinge to work, and 20-30mm for the latch.
The only thing I would say is the with the oil tank under the hood it does appear to get hot so this might have an adverse affect on your wood.
_________________________
Why have one colour when you can have them all wink
Top
#99627 - 28/07/12 07:04 PM Re: M3W modifications ? [Re: asbojohn]
Mi3Wheeler Offline
Loc: Michigan, USA
It is 40.7 mm narrower though so mounting it to the far outside might be safe enough. If not, a fresh coat of high temperature paint would probably be good.
EDIT: Maybe next time you are planning on taking a long drive you could toss the household meat thermometer into your metal ammo box and at the end of your drive see how hot it really gets in there. Last thing I would want is a bonnet fire while motoring down the road pale This is assuming most households have some kind of thermometer they use in the oven to check when the quail or turkey is done.
Edited by Mi3Wheeler (28/07/12 07:22 PM)
Charlie, Eccentric American Anglophile
2012 3 Wheeler - Sport Teal/Tan
MOG Great Lakes Member
Top
#99637 - 28/07/12 08:06 PM Re: M3W modifications ? [Re: Mi3Wheeler]
le Asbo du Bling
Loc: Cambridgeshire
I don't think it ges that warm, but it maybe enough to loosen joints, but you may have a solution for the oven fails. coffee
Edited by asbojohn (28/07/12 08:24 PM)
Top
#99675 - 29/07/12 09:00 AM Re: M3W modifications ? [Re: asbojohn]
PaulJ Offline
Loc: Somerset
There is no doubt that there is useful storeage space under the front cowel, and I've been looking at mine working out how to maximise it, and feel that a small gel battery against the left hand side bulkhead would help a lot,and be easy to do, then there is the option of moving the oil tank back in front of the fusebox against the centre of the bulkhead. This would open up a potentialy huge space [relatively speaking of course]. The only thing to be aware of then, is that the steering column is unsheathed, and could get caught up on something and that is the last thing you would want.
If your WW1 box isn't too expensive go ahead and get it Charlie, but I bet you that when you get the car, you'll have other and better ideas on how to utilize space. Sorry if I'm taking some of the forward planning and anticipation out of the game.
Paul.
Black & Tan M3W, Caterham CSR, Mini Cooper D Clubman, Macgregor 26M, Powabyke.
Top
#99687 - 29/07/12 11:29 AM Re: M3W modifications ? [Re: PaulJ]
Mi3Wheeler Offline
Loc: Michigan, USA
I am not planning on making any major changes such as rearranging components under the bonnet. I'm just looking for a way of keeping whatever I store under there from moving about. At the moment eBay has a few of these boxes that I am watching, with the cheapest starting at $9.00.
Only 94 days till my build week..... what anticipation?
Top
#99693 - 29/07/12 11:50 AM Re: M3W modifications ? [Re: Mi3Wheeler]
PaulJ Offline
Loc: Somerset
You are probably right Charlie, I'm sure the designer laid the area out that way for a very good reason. Best of luck with the box[es], if the price doesn't take off, you'll do very well.
Paul.
Top
#99707 - 29/07/12 02:24 PM Re: M3W modifications ? [Re: PaulJ]
Mi3Wheeler Offline
Loc: Michigan, USA
Well, I won the first box I was watching. This one may require some repairs to the latch area and a new leather strap handle but these are easy and I only paid $21.50. Still has original markings on the exterior and the directional-ammo markings inside are still visible! I will not want to paint over this one because of its great patina so I will continue biding on boxes like the $9.00 auction in case I do need to add a coat of heat-shield paint.
Top
#99715 - 29/07/12 03:01 PM Re: M3W modifications ? [Re: Mi3Wheeler]
le Asbo du Bling
Loc: Cambridgeshire
Charlie with delays due to the Olympics world economics and the fact were going to get your build slot bumped until spring 2013. I've worked it out you could collect from MMC in the UK join us on Lap of Wales get the first services done, put it in a crate and then sent home in time for the summer.
Shall we put your name down. stirpot
Top
#99717 - 29/07/12 03:20 PM Re: M3W modifications ? [Re: asbojohn]
Mi3Wheeler Offline
Loc: Michigan, USA
We shall see how things play out over the coming months, but if it looks like I can have our passports renewed in time and all of the trip funds are available... I would rather fly over and hire a RHD Aero or something else I can't readily find state-side and an just arrange to return it at the factory.
But at the rate I am squandering spend on random eBay impulses puts the 5 year fiscal plan into a narrower focus. At this point I am aiming at getting an entire set (1910-1914) of Michigan porcelain license plates. 1911 and 1912 are already on their way to me slowly through the post.
Top
#99746 - 29/07/12 11:49 PM Re: M3W modifications ? [Re: Mi3Wheeler]
Mi3Wheeler Offline
Loc: Michigan, USA
Ooh, I got a deal on a mint 1914 plate this evening, they were white with red that year. 3 down 2 to go.
Top
Moderator:  Aeroman
