Wrapped headers, removed cats and exhaust baffles
Posted By: Mol
Wrapped headers, removed cats and exhaust baffles - 22/04/15 10:20 PM
I wanted to wrap my headers because it was part of the look I am going for with my M3W. To do the job correctly you have to remove the pipes. The thought of doing this was scary for me at first, but I wanted wrapped headers and my friend who was going to wrap them for me said I had to remove the pipes for him to do it. Since I was going to have the pipes off, I decided I might as well remove the cats and baffles as well.
First you remove the O2 sensor.
Loosen the clamp between the pipe and header.
Unbolt the pipe mounts.
Pull the pipes apart by wiggling and twisting. The residue on this joint is Anti-seize. This product keeps metal pieces from corroding together, so that you can get them apart again if you ever need to. Before you reassemble, you will need to completely clean this off with ultra-fine steel wool and reapply a fine fresh coat. A little goes a long way.
Tail pipe removed.
It is really not that difficult to take this off.
... continued in next post...
Posted By: Mol
Re: Wrapped headers, removed cats and exhaust baffles - 22/04/15 10:39 PM
Removing the headers is not as easy because of inaccessibility. You just have to be patient and know that you can do it.
First you need to bend down the "washer" so you can get the bolts off. This washer is actually not a single washer but goes around both bolts. Use a screwdriver and a hammer to bend it down. Before reassembling you need to flatten the washer out with a hammer. Once installed, you will bend it back up. This keeps the bolts from loosening.
Remove the bolts connecting the headers to the engine. On a couple we found a socket we could fit on. On others I had to use a open faced wrench. It was not easy due to no space to work around, but if I can do it, so can you.
There is a gasket, mine stayed on the engine and was in great shape so I didn't mess with it.
The cat is in that bulgy area toward the end of the header pipe.
I took a big screwdriver and hammer and beat around between the cat and the pipe until I could get it out. It took me almost an hour. There was a point where I was really questioning my actions but I was past the point of no return so I just kept on working at it. Needle nose pliers come in handy here as well. Keep a garbage bag nearby to put all the little bits of metal in.
Done... clean the pipe real good of all the leftover bits as best as you can and now on to the other side.
Posted By: Mol
Re: Wrapped headers, removed cats and exhaust baffles - 22/04/15 10:53 PM
Time to wrap the headers. I am lucky to have a friend who used to build customer choppers and has been wrapping pipes for 20 years, He would not let anyone but him wrap my pipes because he wanted it done right.
Wear gloves, if gives you better grip and the wrap can be itchy.
You need a lot of space. You attach the wrap to something really solid and unwind it all (we attached the wrap to my lift way at the other end of the garage). Then you start wrapping applying steady, tight tension the entire time. Darrian Tefft is a master at this. I am so lucky he did this for me for just beer and pizza. (yes, this is our garage)
No, you do not wet the wrap to apply, that just creates a soppy mess.
Darrian, who is a master welder and now teaches welding, used stainless steel welding rod to secure the wrap. This gave it a wonderful Old School look.
Posted By: Mol
Re: Wrapped headers, removed cats and exhaust baffles - 22/04/15 11:30 PM
Removing the baffles from the long pipe:
There are three of these "sound dampening" baffles. One solid plate about where the heat shield starts and two plates with holes in them about where the heat shield ends. You'll need two different sizes of hole saw and a 2 foot long extension. We had to jerry-rig our tool together and it got modified as we went and learned. I ended up taping all the joints together with aluminium tape (very strong) to keep the thing more solid and from pulling apart.
When using the hole saw, go slow. You should be able to count the revolutions as it turns. Going any faster just heats up, and hardens, the baffles and dulls the saw. We ruined two saws on two baffles before Darrian explained this to me. After that we used just one saw on the last 4 baffles and the saw is still viable.
I have no good photos of this step, sorry.
The baffles may need a little poking at to get completely out so you'll want to have something long and solid at hand before starting this project. We ended up scrounging up a long metal bird feeder pole. Hey... it worked. Another baffle was really hangy-on and we could not get it totally out so just bent it back as far as we could. It ended up shooting out of the pipe 30 seconds after we started it up for the first time after the mod.
Now put everything back together. Those bolts connecting the header to the engine were a bitch.
Look how smooth the wrap is. It is 1 inch wrap perfectly "locked" together. The more I look at it the more I can't believe how good it looks.
The wrap stinks for awhile after you install it and patinas quite quickly.
I love the new sound. The sound meter on my phone does not indicate the exhaust is any louder, but it sounds more beefy to me. Mostly the sound is deeper and more throaty. It's got some nice balls now.
Power wise, yes, I can feel a difference. The engine is definitely a lot happier. It's hard to explain the difference, but the mods were totally worth it for me.
I'll post up a video for sound soon.
Now, simply a cool photo for your viewing pleasure... This is from a 1800 mile, in one week, trip to a road known as The Dragon, that we took last year, and we will be doing again in just 3 days:
Posted By: Squirlz
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 12:33 AM
I can describe the power difference. I'm her husband. It used to be when you got much over 4000 RPM there were all kinds of cues telling you to upshift. On our shakedown run, I was bombing along , engine singing happily in 3rd gear, and I thought 'I'm going pretty fast for 3rd gear' and I looked down and saw we were doing 5000 RPM! I'm also easily bouncing off the redline when hammering from a stop and getting rubber in 3 gears! We did not anticipate such an improvement.
Posted By: Richard - Aus
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 12:53 AM
Wonderful write up and very interesting to read. Great sounding results too it appears.
Posted By: fathergoose
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 01:00 AM
thanks Squirlz, I think I will be doing this to mine, at some point down the road.
Posted By: deano
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 03:24 AM
Totally agree, great write up and interesting results on the power/smoothness improvement.
Posted By: Jays
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 06:04 AM
Great post Mol....just what we need here and in the Club Miscellany...except that they fight shy of publishing it.
Great garage by the way....I'm very envious!!
Posted By: Roger Tapley
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 06:23 AM
That's what I call dedication to driving pleasure well done!
Posted By: Aeroman
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 06:25 AM
+1 - would love to hear the new sound, please post a video.
Posted By: Waldemar
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 06:38 AM
wonderful story, thanks a lot wine
Achim
Posted By: wiscos
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 08:43 AM
Truly great and very helpful. Of course, many parts of the globe we need to leave the cats in to keep the vehicles legal...
Posted By: Mi3Wheeler
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 12:07 PM
Good write up, I am excited to hear the difference in person.
Posted By: Smaug
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 12:55 PM
Hi Mol,
super review, will probably be my next project...by the way, thanks again for the 'how to do' on the steering comfort kit. I followed that step by step to do mine, was a pleasure having such quality instuctions for that job.
I can only encourage you to continue, I would suggest to give you a steady Topic named something like "M3W tuning? ...ask Mol" or "Mol's quality' how to' " thumbs
Posted By: MGDave
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 01:19 PM
Hi Mol, Interesting article hope we get to hear it soon. I see you're heading down to the Dragon again, we are planning to be there next Thursday on our way to Aiken SC for the MOG40 event, on the return trip will be cruising the Snake. Hope we can meet up if you're still in the area.
cheers
Posted By: PaulJ
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 01:31 PM
I'm really pleased it worked out and you've improved the car Mol. See, don't take any notice of idiots on public forums - keep doing it your own way.
As a matter of interest, as one or two people have commented, once our cars are three years old, they have to have an annual inspection, which includes a strict emissions test. However, once the test is completed, it is very unlikely that the car will get pulled over for another 12 months, and if the owner has substituted a cat. free pipe, no one would know!
Posted By: Smaug
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 01:42 PM
Speaking '3 years inspection and emission test' by freeing the pipes but leaving the cat in place would it have in incidence on the CO2 emissions? ...and does it affect the noiselevel ( gain not the more bassy sound)? listening
Posted By: Squirlz
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 03:11 PM
We were just thinking at the MSU car show; you haven't even seen her car yet!
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 04:43 PM
Technically we have seen it at the last two MSU car shows, but every time you had a massive crowd around you.
Posted By: RedThree
Re: Wrapped headers, removed cats and exhaust baffles - 23/04/15 04:45 PM
Good write up - hadn't thought of tying off the wrap and winding the header towards it. It's amazing just how easy it is to take off and replace the headers after you've done it for the first time though.
As for the cats; I'll be leaving mine in but if I manage to acquire a set of headers that don't have them so that there can be an annual swap for the MOT then...
Posted By: Draggin
Re: Wrapped headers, removed cats and exhaust baffles - 14/06/16 01:59 PM
Hypothetically i wonder what size hole saws?
Posted By: KenShapiro
Re: Wrapped headers, removed cats and exhaust baffles - 14/06/16 03:14 PM
Done quite a few wraps. Never heard of or considered removing the headers to accomplish it.
Posted By: Draggin
Re: Wrapped headers, removed cats and exhaust baffles - 14/06/16 04:04 PM
I think they were off to pull the cats, and once off, why not wrap them without the suspension in the way?
Posted By: Chris99
Re: Wrapped headers, removed cats and exhaust baffles - 14/06/16 04:44 PM
Great post and the dragon looks an awesome bit of road.
For info, a 3 wheeler does not require a UK MOT emissions test - confirmed by Andymot (our "tame" MOT tester) with a link to the MOT regulations in another thread.
Re: Wrapped headers, removed cats and exhaust baffles - 14/06/16 07:21 PM
I would agree but that's not what he said.
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 31/01/19 05:58 PM
I realize this is an old thread. But I'm curious if removal of the cats and baffles plus the addition of a less restrictive intake, a) essentially results in a 'MMC Stage 1' upgrade, b) if it requires an ECU tune or does the (US-spec) ECU have enough bandwidth to adapt, and c) if a G56 Stage 2 upgrade that includes an ECU tune would be happy layering on top of the 'homemade' Stage 1.
Asked another way, would this mod save the cost of a Stage 1, particularly if the goal is Stage 2 anyway?
Posted By: rockabilly john
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 10:08 AM
Don't you need the Cam upgrade to accomplish this?
Posted By: Chris99
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 12:48 PM
There's a bit of inconsistency in the stages depending on whether you are talking MMC, G56 or Krazy Horse. Basically the standard ECU should be OK until you upgrade to the 569 cams.
MMC/G56:
Stage 1: Exhaust and air filter, fine with standard ECU
Stage 2: Add upgraded cams and ECU
KH:
Stage 1: Exhaust and air filter, retain standard ECU
Stage 2: Add ECU and dyno tune
Stage 3: Add cams and dyno tune
Stage 4: Add 128ci big bore kit, roller rockers, ported cylinder head, throttle bodies, high flow injectors and dyno tune
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 01:26 PM
Correct. Which includes an ECU reflashed for the cams, so wouldn't it assume the engine is breathing better too and factor that increased air flow into its equation?
So if the goal is Stage 2, why not just help the engine breath better on your own? If the noise proves unacceptable, buy a set of Stage 1 pipes. Does this make sense? I'm trying to figure out why a MMC Stage 1 is worth $2k.....
Posted By: Bitsobrits
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 03:20 PM
Something to keep in mind with upgrades is that while the factory "locked" ECU is adaptive to a large degree, the adaptive fuel/spark maps it creates are lost when the ECU is disconnected from power i.e. the battery is disconnected. It will of course "re-learn" the current engine set up on re-connection, but that takes some time/miles.
The "unlocked" ECU gives you the option of merging the "learned" adaptive maps with the baseline map, thus creating a new baseline map stored in non-volatile memory. Adaptation to changing conditions still occurs, but referenced to the new baseline.
Posted By: M3W55
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 03:28 PM
My Stage 1 is being done at the factory while it is there for other work. MMC insist on an ECU reflash for that. Is there any notable benefit, since it seems that most Stage 1 adopters on TM seem to get by without touching the ECU?
Posted By: Chris99
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 04:06 PM
I've used a battery disconnect when not using the car since new and never had any issue with the ECU "forgetting" the adaptive settings - either when standard, Stage 1 or, as now, KH stage 3.
I ran the standard ECU with the MMC Stage 1 and switched to a KH unlocked ECU when I had the cams upgraded.
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 04:40 PM
After hearing mixed messages on this topic between the forum and dealer, I contacted the factory in Oct. and was informed that an ECU flash was 'most probably' unnecessary for Stage 1.
In contrast, my US dealer feels its 'likely' necessary due to the already lean nature of the mixture to meet DOT requirements but not 100% sure. The only consensus seems to be that if you don't reflash and the ECU triggers a fault code, it's time to reflash.
Personally, if I weren't interested in Stage 2 (cams) and sure I'd hold firm at MMC Stage 1, I'd take the reflash to be sure. But at the absurd quoted $2k for a set of Stage 1 pipes, filter and minimal ECU tune, I can't help wonder if the true value play is the path I'm considering.
BTW, my battery is disconnected for the winter. I would imagine that once reconnected with a homemade Stage 1, it wouldn't take long to discover if this theory holds. Unfortunately, I haven't heard that Stage 1's are shipping yet and I'm impatient.
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 05:07 PM
[/quote]
[/quote]
That the adaptive maps are stored in volatile memory and lost upon power disconnect is not conjecture on my part or internet lore-I took that information from the S & S Protune manual page 87 paragraph 9.5.
In your case I would imagine the adaptation was slight enough you did not notice the change and/or the new maps built quickly enough to mask the change.
In my own car, after a change to a cat-less straight through exhaust, the change from adaptive maps to baseline map after using the battery disconnect was quite noticeable, and it took 15-20 miles of running for the engine to return to its previous happy self. Merging the maps eliminated this. In all I did three maps merges after 100+ mile variable condition drives. The last one showed minimal change from the 2nd one, so I've stopped there. The Protune software allows you to visually and numerically compare maps, assuming you saved your previous versions
Posted By: kankeL
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 07:29 PM
Steve, did you purchase the ECU from Garage56? Was the installation straightforward?
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 09:57 PM
Yes, from G56, with the fan kit upgrade installed, even though I don't have the fan kit yet. While I wouldn't call the installation easy, it was straightforward. Straightforward because you just unplug it (battery disconnected!) and remove the two mounting screws. It's not easy because getting to the two mounting screw involved working around tightly grouped wiring, and the connector I was finally able to remove from underneath the dash after removing the center under dash trim pad. I would also say a ball end hex key is required for the mounting bolts due to angle constraints. Seems the ECU is the first thing they mount on the chassis before everything goes on! After installation my speedo didn't work, because in my struggle I had dislodged a wire in the connector from the front wheel sensor. Was easy to fix (just push it home) but took a bit of internet searching to find some clues on why speedos stop working, and therefore which wires to examine.
It occurred to me at the time I should build a small sleeve/box to mount that would allow the ECU to just slip out. Didn't want to take the time.
The port for plugging in the computer cable is fairly accessible, but has very small screws you must not lose. During my driving/tuning weekend I left the cable plugged in with a cap over the computer end when not in use. Kept the risk for screw loss to a minimum.
Posted By: kankeL
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 10:46 PM
Thanks! Will order myself a new ECU wink
Posted By: Chris99
Re: Wrapped headers, removed cats and exhaust baffles - 01/02/19 11:57 PM
This would include a new, unlocked ECU as the standard one can only be reflashed with a MMC file.
So the $2k probably breaks down to approx $800 exhaust, $800 ECU and $400 air filter and fixings
Posted By: 2Sharp
Re: Wrapped headers, removed cats and exhaust baffles - 02/02/19 04:57 PM
When you install your new ecu I would suggest ditching the screws in favor of Velcro. Unfortunately I figured this out after fitting the new ecu.
I have not played around with the software but likely need to to merge the maps.
It is hard to tell what did what but the engine is transformed to me as the power is much more linear and the below 3k feels much more lively. I had the factory stage 1 which was good but much better now.
It is a shame we don’t have a tuner like the two options in the UK in the US
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 03/02/19 01:15 PM
Not exactly. The quote includes sending my own ECU back to MMC for a reflash. What makes more sense to me is $1200 for Stage 1 (pipes and filter alone) plus the components of Stage 2 with the unlocked ECU all in one go. Doesn't make sense to pay for the ECU twice. Am I missing something?
Re: Wrapped headers, removed cats and exhaust baffles - 04/02/19 01:44 PM
Hi Molly, what wrap did hoy use?
Thanks.
John.
Posted By: Draggin
Re: Wrapped headers, removed cats and exhaust baffles - 19/02/19 07:11 PM
Personally i used the thermo tec stuff
https://kirkusblog.com/2018/12/06/adventures-in-morganeering-exhaust-wrap/
Posted By: Taffmog
Re: Wrapped headers, removed cats and exhaust baffles - 20/02/19 12:52 AM
Great post Mol and brilliant pics, I think I’ll have a go on mine soon....
Posted By: Draggin
Re: Wrapped headers, removed cats and exhaust baffles - 21/02/19 09:43 PM
Have a look at my method, I do not remove the pipes
Posted By: LightSpeed
Re: Wrapped headers, removed cats and exhaust baffles - 23/02/19 08:09 PM
Here is a newbie question, how do you clean the wrapped headers?
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 24/02/19 07:30 PM
Replace the wrap? Re-spray with high-temp silicone? Start with a dark color? Not much experience with mine yet but I doubt it will take a scrubbing. Not that hard to replace.
Re: Wrapped headers, removed cats and exhaust baffles - 25/02/19 02:39 AM
06032
I understand one reason for the wrap is to protect the turn signal lamp from excessive heat, but is the only other reason to have it is for appearance?
Posted By: Michael H
Re: Wrapped headers, removed cats and exhaust baffles - 25/02/19 05:33 PM
06032
And that's about it! I've tried wrapping the headers with different materials and abandoned all of them. It keeps the heat in the pipes when cooling them would be much better. Wraps were originally used inside engine compartments to keep that space cooler. They were not designed for external use. Mine all degraded over time, became brittle and came off in pieces. Getting wet occasionally probably did not help, either.
Re: Wrapped headers, removed cats and exhaust baffles - 02/03/19 02:58 AM
I've recently had my headpipes silver ceramic coated. Not real wild about their somewhat "blingy" appearance, but will see how they age once the weather breaks and we can get some heat and miles on them.
Posted By: kankeL
Re: Wrapped headers, removed cats and exhaust baffles - 02/03/19 04:36 AM
Pictures, please? 😎
Re: Wrapped headers, removed cats and exhaust baffles - 02/03/19 04:24 PM
Somewhat visible here-I'll take better photos later today.
Re: Wrapped headers, removed cats and exhaust baffles - 02/03/19 05:04 PM
Nice idea!
I too think getting heat out of the pipes rather than holding it into the pipes is a better idea and if a person wants to protect their turn signal lamps I suspect a heat shield for each lamp could be made out of aluminum tubing.
Posted By: britmog
Re: Wrapped headers, removed cats and exhaust baffles - 02/03/19 06:06 PM
Here’s how they work—ceramic coatings and exhaust wraps help contain the gaseous heat within your exhaust pipes. This causes the gasses to heat up and expand. Since the exhaust gas is trapped within the system, it expands the only direction it can—out of the tailpipe. As a result, exhaust flow is boosted, allowing a rush of fresh air to enter the engine’s cylinders, increasing horsepower. Both ceramic coated headers and exhaust wraps improve horsepower, however, ceramic coating is better than exhaust wrap as it does not trap moisture although more costly. The ceramic coating should dull over time.
Re: Wrapped headers, removed cats and exhaust baffles - 02/03/19 07:30 PM
Here's a more representative photo of the ceramic coated headpipes. From my experience with this particular coating product from my local powder coater, it takes thousands of miles over several years to show appreciable dulling. On my occasionally tracked Lotus Elan (so much more high rpm running) the dulling effect occurred more rapidly than on my more sedately driven E-type. Both of those cars have the ceramic over stainless steel tubular manifolds, so similar to the Morgan.
These pipes have only a few minutes of idling time on them to check for leaks. It will be a couple of months before the snow is gone and roads are clear enough for a real run in. frown
One of the downsides to coating the head pipes is the color mismatch with the rest of the stainless exhaust. The ceramic coating is closer to polished aluminum (whiter) than the more bluish-brown of the stainless. The woven mesh of the flex couplings were simply masked off during the coating process, btw.
Posted By: kankeL
Re: Wrapped headers, removed cats and exhaust baffles - 02/03/19 07:45 PM
Looks very nice, Steve! 👍
Re: Wrapped headers, removed cats and exhaust baffles - 03/03/19 02:34 AM
+1 , very nice looking! Can I assume that it could be a different color if desired, although i like what you have done.
Is it easier to clean than stainless?
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 03/03/19 01:58 PM
My takeaway: The caveat to ceramic or wrap is that increased heat and expansion is counter-productive without creating a clear pathway for escape in an already restrictive system. Hence removal of cats/baffles.
A corollary I've heard is that the temperature at the tip of the exhaust should be hot, such that only one finger's width can tolerate the heat. And that's how you'll know if the exhaust is flowing freely. Maybe just an old 'gear head's' tail....
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 03/03/19 03:49 PM
Steve - is this a screened vented cover? Source info? Sure beats wedging it open at the bottom.
Re: Wrapped headers, removed cats and exhaust baffles - 03/03/19 06:23 PM
Answering a couple of questions:
The ceramic coating is available in a few colors, including black, which vary by manufacturer. The powder coater you use to do the coating will impact the choices available to you.
The coating is so much easier to maintain than bare stainless, which is why I used it on my other cars. No bluing, no discoloration, no polishing. Basically you do nothing but wash it once in awhile to remove bugs and other detritus.
As for the screened cover, at the moment it is cosmetic only. My intent is to find a suitable waterproof filtering medium to insert under the perforated cover, then place holes in the S&S emblem area. The pre-perforated cover is 1/16" thick stainless I bought online for a few dollars and has the edges peened over to give it the 3 dimensional look.
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 03/03/19 07:40 PM
As for the screened cover, at the moment it is cosmetic only. My intent is to find a suitable waterproof filtering medium to insert under the perforated cover, then place holes in the S&S emblem area. The pre-perforated cover is 1/16" thick stainless I bought online for a few dollars and has the edges peened over to give it the 3 dimensional look."
Ahh...clever.
I wonder how waterproof the material needs to be if at present its deemed ok to wedge the entire bottom open!? I'm trying to think of a fabric that blocks water and particles but breathes: a replaceable section of breathing mask material, cotton tent fabric, landscape fabric, dense sponge?
Re: Wrapped headers, removed cats and exhaust baffles - 03/03/19 08:45 PM
Waterproof only so it doesn't rot. Needs to allow some amount of air but no grit. So something simple and inexpensive. Perhaps just a bit of stainless steel wool.
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 08/03/19 06:37 PM
Finally...FINALLY....got a chance to go for a long ride (very comfortable at 32F and snow on the ground) to try out the combo of a baffelectomy, stealth intake and Ohlins (only the front so far).
Result: Louder only when you'd expect it to be, crisper throttle response, much happier throughout the rev range, do need to watch the RPM's now.....and the Ohlins, oh my, the Ohlins give the front end a lightness beyond my expectations. Very noticable. Happy, happy!
Re: Wrapped headers, removed cats and exhaust baffles - 09/03/19 02:12 AM
Tell me about the Olin shocks, what model are they?
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 11/03/19 12:52 AM
Custom spec. If you search on this site, you'll find a data sheet and contact at Ohlin/U.S. You'll need to confirm a few measurements.
Re: Wrapped headers, removed cats and exhaust baffles - 11/03/19 12:54 AM
Thanks, found it.
Re: Wrapped headers, removed cats and exhaust baffles - 11/03/19 01:14 AM
Will this do?
These are not mine, but have been uploaded at some time by another M3W member.
John.
Re: Wrapped headers, removed cats and exhaust baffles - 11/03/19 01:19 AM
lightspeed, pm sent.
john
Posted By: 06032
Re: Wrapped headers, removed cats and exhaust baffles - 11/03/19 11:24 AM
If you're a suspension nut, you'll appreciate this 'yellow' upgrade. I swapped my OE' Spax units after only 300 miles.
© 2019 Talk Morgan - Morgan Sports Car Discussion Forum, Community and News
