Half Hard Top for My Three Wheeler
Posted By: nestor59310
Half Hard Top for My Three Wheeler - 09/09/19 09:06 PM
A member of the French forum MTW made me this semi rigid roof for my three wheeler :
![[Linked Image]](https://zupimages.net/up/19/37/n39i.jpg)
![[Linked Image]](https://zupimages.net/up/19/37/zn1x.jpg)
I receive it next week, and I begin the adaptation on my car....
(Black is not the definitive color)
Posted By: kankeL
Re: Half Hard Top for My Three Wheeler - 09/09/19 09:16 PM
Very interesting!
Posted By: LightSpeed
Re: Half Hard Top for My Three Wheeler - 09/09/19 09:18 PM
Re: Half Hard Top for My Three Wheeler - 09/09/19 09:31 PM
Posted By: OZ 4/4
Re: Half Hard Top for My Three Wheeler - 09/09/19 10:01 PM
Brilliant innovation
Re: Half Hard Top for My Three Wheeler - 10/09/19 12:02 AM
Don’t forget to video the entry and exit into the cockpit with the top in place.
Posted By: PaulV
Re: Half Hard Top for My Three Wheeler - 10/09/19 07:03 AM
Nestor has what I would call a “rigid tonneau”. A “hard top” would be more the coupe add on like on the new Plus6. Not sure what a half hard top would be, nor the correct French (Demi-tonneau ferme?).
Presumably the only issue with ingress/egress is one’s shoulder?
Posted By: pandy
Re: Half Hard Top for My Three Wheeler - 10/09/19 07:17 AM
Oh crikey.
Ian's going to have you for that.
Re: Half Hard Top for My Three Wheeler - 10/09/19 07:42 AM
Here is a first version on the MTW of the person who made me the piece.
He uses the fixings of the original flexible canvas.
The upper part is open V-shaped for easy access to the vehicle
![[Linked Image]](https://zupimages.net/up/19/37/5sfq.jpg)
![[Linked Image]](https://zupimages.net/up/19/37/jl20.jpg)
Posted By: Ricardo
Re: Half Hard Top for My Three Wheeler - 10/09/19 08:41 AM
That looks pretty cool Nestor 😎
Posted By: nippymog
Re: Half Hard Top for My Three Wheeler - 10/09/19 09:07 AM
I really like that - for the less skilled amongst us , one for Garage56 etc?
Re: Half Hard Top for My Three Wheeler - 30/09/19 08:43 AM
First adaptation of the piece :
![[Linked Image]](https://zupimages.net/up/19/40/a6il.jpg)
Re: Half Hard Top for My Three Wheeler - 30/09/19 08:44 AM
Re: Half Hard Top for My Three Wheeler - 30/09/19 08:48 AM
The holes are finished. there are other cuts to make + adjust the piece to the English wheel :
![[Linked Image]](https://zupimages.net/up/19/40/8vo7.jpg)
Posted By: nippymog
Re: Half Hard Top for My Three Wheeler - 30/09/19 10:36 AM
Nice job.
Have you considered using an edge trim to protect things from the sharp edges, something like this
https://www.holden.co.uk/p/edge_trim_pvc_8m1 Not sure how flexible it is to go round the corners though - a little heat might persuade it.
Also, is that the armrest from your car now attached to the cover, or did you obtain a spare?
Re: Half Hard Top for My Three Wheeler - 30/09/19 11:52 AM
Beautiful work👍 Do the louvres relieve pressure or are the cosmetic?
What holds it in place at speed?
Re: Half Hard Top for My Three Wheeler - 30/09/19 01:28 PM
Hi Nippymog,
I thought about sticking an EPDM rubber band under the barrel cover and not on the edge
For the armrest, I will move it according to the use, either on the car without barrel cover, or on the barrel cover ....
![[Linked Image]](https://zupimages.net/up/19/40/imbm.jpg)
Lightspeed,
The louvres are not decorative, they allow that there is no air pressure that is created at this place, there is no speed limit with the barrel cover
Re: Half Hard Top for My Three Wheeler - 30/09/19 01:33 PM
Thanks Nestor.
Posted By: WilsonLaidlaw
Re: Half Hard Top for My Three Wheeler - 30/09/19 03:17 PM
I wonder if you could add something like the apron they use on kayaks, to keep your bottom half and the seat, totally dry. I found over last winter, when unusually, I had my M3W in the UK over the winter after its rebuild at Malvern, that even if you have good water-proof over-trousers on, if you are sitting in a puddle of water, you still get a wet backside.
Wilson
Posted By: rockabilly john
Re: Half Hard Top for My Three Wheeler - 30/09/19 03:43 PM
Nestor, how is your Pool ball gear knob attached?
Posted By: Chris99
Re: Half Hard Top for My Three Wheeler - 30/09/19 04:05 PM
The kayak type spray deck has been suggested before and could cover the entire cockpit.
However viewing the instruments would be an issue (even if the spray deck had a transparent section), and your arms/hands would be under the cover so adjusting goggles/hats/helmets and wiping screens and mirrors would be a challenge.
Still, it's an opportunity for someone to have a go....
The low cost alternative is to use the tonneau cover as a blanket which several people have said works well.
Re: Half Hard Top for My Three Wheeler - 30/09/19 04:58 PM
Chris,
I was thinking of a kayak apron, sitting a bit lower down, running from below the dashboard at around waist level. The waterproofing of jackets seems better than trousers, although when I did London to Brighton in a 1904 30HP Panahard (sitting quite high with no windscreen) on the year (?2012), when it poured with rain non-stop all the way, even in a newly waxed heavyweight Barbour, I was soaked right through by the time I reached Marine Parade.
Wilson
Posted By: Chris99
Re: Half Hard Top for My Three Wheeler - 30/09/19 05:27 PM
Interesting, but how are you going to get rid of the water that will be collected?
Re: Half Hard Top for My Three Wheeler - 30/09/19 07:09 PM
For my part, I do not drive when it rains.
And if I'm ever surprised by a downpour, I take out a golf umbrella 150cm in diameter and I wait for the stop that the rain stops ...
Posted By: SFG
Re: Half Hard Top for My Three Wheeler - 30/09/19 07:40 PM
This is what you need. You can attach a hot water bottle to the drain tube if you want more sophistication. Remember, no-one looks at instruments.
I would think Barbour or Siebe Gorman would knock one up for you.
I want royalties
![[Linked Image]](https://www.tm-img.com/images/2019/09/30/999AB75D-6D8D-4C91-A5CD-9D021B902EA0.jpg)
Ps I failed art o-level
Re: Half Hard Top for My Three Wheeler - 30/09/19 07:42 PM
I don't know what the later cars are like but there are plenty of holes in the floor of mine to run a couple of drain tubes to. However as I only use mine from April to the end of September (it went into its winter storage yesterday) in the south of France, it would not be mod for me. Like Nestor above, I really only drive mine in the sunshine.
Wilson
Re: Half Hard Top for My Three Wheeler - 30/09/19 07:43 PM
I want royalties
Brilliant!
Posted By: ShaunD
Re: Half Hard Top for My Three Wheeler - 30/09/19 10:50 PM
Hope that’s a gear stick! 😊
Posted By: Bitsobrits
Re: Half Hard Top for My Three Wheeler - 01/10/19 12:01 AM
Oh no...here come the polished knob jokes
Posted By: atalante83
Re: Half Hard Top for My Three Wheeler - 01/10/19 04:16 AM
Not very useful for me.
You are obliged to be alone .
Posted By: SFG
Re: Half Hard Top for My Three Wheeler - 01/10/19 06:44 AM
A minor modification.........
Re: Half Hard Top for My Three Wheeler - 12/11/19 04:50 PM
Here is the barrel cover version 2 being modified at my coachbuilder ...
![[Linked Image]](https://zupimages.net/up/19/46/3s3n.jpg)
Re: Half Hard Top for My Three Wheeler - 12/11/19 04:51 PM
Unfortunately this second version of barrel cover is missed ....
Re: Half Hard Top for My Three Wheeler - 12/11/19 04:53 PM
Here is the 3rd version ! :
![[Linked Image]](https://zupimages.net/up/19/46/abzf.jpg)
Re: Half Hard Top for My Three Wheeler - 12/11/19 04:54 PM
Next step, creating the louvers.....
Re: Half Hard Top for My Three Wheeler - 12/11/19 04:57 PM
The same louvers as on this MTW, 8cm wide :
Posted By: Dada
Re: Half Hard Top for My Three Wheeler - 12/11/19 05:33 PM
Hi Nestor, do you know someone in Lille or around that is able to make louvers of several size at reasonable cost please
Re: Half Hard Top for My Three Wheeler - 12/11/19 05:56 PM
Call Steve from VHClassic au Poperinge Belgium
Posted By: Dada
Re: Half Hard Top for My Three Wheeler - 12/11/19 05:59 PM
Thanks !
Re: Half Hard Top for My Three Wheeler - 28/11/19 11:36 PM
Re: Half Hard Top for My Three Wheeler - 28/11/19 11:38 PM
Strongly the end of the winter, we can leave the MTW :
Re: Half Hard Top for My Three Wheeler - 29/11/19 03:28 AM
Very nice👍
Re: Half Hard Top for My Three Wheeler - 29/11/19 06:01 AM
I have to think about a quick fastening system, knowing that I want to avoid drilling into the bodywork
Re: Half Hard Top for My Three Wheeler - 29/11/19 06:04 AM
Nice work
Re: Half Hard Top for My Three Wheeler - 06/12/19 09:48 AM
another three wheeler under construction in the same garage ....
Re: Half Hard Top for My Three Wheeler - 06/12/19 12:26 PM
Is all the wood being replaced with aluminum?
Posted By: Rog G
Re: Half Hard Top for My Three Wheeler - 06/12/19 12:52 PM
Its is an F type 3 wheeler from 1930/40's, which as original would have had a wooden frame panelled in steel.
Re: Half Hard Top for My Three Wheeler - 20/01/20 09:42 AM
Polishing finished
I must definitively solve the problem of fasteners
![[Linked Image]](https://zupimages.net/up/20/04/3w9a.jpg)
![[Linked Image]](https://zupimages.net/up/20/04/2xzi.jpg)
Re: Half Hard Top for My Three Wheeler - 20/01/20 10:27 AM
You could use Tenax fasteners which work with the same pegs as the "lift the dot" fasteners but are released by pulling up the knob rather than tilting.
![[Linked Image]](https://www.tm-img.com/images/2020/01/20/Tenax.jpg)
Wilson
Posted By: CooperMan
Re: Half Hard Top for My Three Wheeler - 21/01/20 01:43 PM
Or the traditional Dzus, like you have on the 'bonnet' ?
Re: Half Hard Top for My Three Wheeler - 23/01/20 04:29 PM
Is it more intended to insert into the fabric? :
https://www.youtube.com/watch?v=EbvOIkbNEUQ
Re: Half Hard Top for My Three Wheeler - 23/01/20 05:22 PM
Yes it is originally intended to insert into fabric but you could bond it with high strength epoxy to your aluminium tonneau. This would be next to invisible and the advantage compared with the lift the dot, is that you can release from the pin on the main body, by just pulling straight up on the knob. Many years ago I used them on a blanking plate where the spare wheel would normally be, on a racing 4/4, where we needed access to be able to change the differential quickly to alter the gearing for different circuits.
Wilson
Re: Half Hard Top for My Three Wheeler - 30/01/20 10:59 AM
Visit my saddler
Test of a custom mohair binding :
![[Linked Image]](https://zupimages.net/up/20/05/gih4.jpg)
my saddler's workshop
On the right of the photo, my Half Hard Top
He is very competent, but he is not the king of storage!
Re: Half Hard Top for My Three Wheeler - 30/01/20 12:45 PM
How do you get a Lift Dot locking mechanism to work with a rigid material?
Posted By: Jays ex Nero
Re: Half Hard Top for My Three Wheeler - 30/01/20 01:25 PM
Lovely work and a rather interesting workshop! As Wilson has suggested I’d try Tenax fasteners.
Posted By: PaulV
Re: Half Hard Top for My Three Wheeler - 30/01/20 01:26 PM
I'm guessing... a large hole under the mohair, and mohair patch is attached to the metal on one side of the patch?
Re: Half Hard Top for My Three Wheeler - 30/01/20 07:47 PM
Here is the drawing of the flexible tie that the saddler will make for fixing the hard top
Re: Half Hard Top for My Three Wheeler - 30/01/20 07:51 PM
On this link, the photos I had made of the same saddler, when he had built a caferacer saddle on a 1976 Honda twin that I owned :
https://motoancienne.superforum.fr/t10499p25-ma-honda-cb-125-jx-de-1976
Re: Half Hard Top for My Three Wheeler - 20/03/20 09:52 AM
fasteners completed :
Re: Half Hard Top for My Three Wheeler - 02/04/20 08:18 AM
Re: Half Hard Top for My Three Wheeler - 02/04/20 10:34 AM
Are you going to rivet or bolt them to the cover?
Re: Half Hard Top for My Three Wheeler - 09/04/20 11:22 AM
Re: Half Hard Top for My Three Wheeler - 09/04/20 01:03 PM
Looks nice👍
Posted By: The Austrian
Re: Half Hard Top for My Three Wheeler - 09/04/20 03:21 PM
How can you read the speed?
Or did you put some markings on the speedometer?
Posted By: PaulV
Re: Half Hard Top for My Three Wheeler - 09/04/20 04:44 PM
Next step: make the passenger screen removable or foldable? That would reduce the drag!
Re: Half Hard Top for My Three Wheeler - 09/04/20 10:57 PM
Austrian : We can clearly sees the speedometer, the hard cover barrel has the same shape as the standard fabric one
Paul : Good Idea, maybe some screen brookland....
Re: Half Hard Top for My Three Wheeler - 14/04/20 03:53 PM
good vision on speedometers :
Re: Half Hard Top for My Three Wheeler - 14/04/20 03:56 PM
new aluminum sanding for a nice finish before painting :
![[Linked Image]](https://zupimages.net/up/20/16/ya56.jpg)
Re: Half Hard Top for My Three Wheeler - 14/04/20 03:58 PM
pinstriping project once the cover barrel is painted blue ...
Re: Half Hard Top for My Three Wheeler - 15/04/20 01:16 AM
Looking good👍
Re: Half Hard Top for My Three Wheeler - 19/04/20 10:21 PM
I continue the adjustments because for the moment there are still noises of vibrations
I can already confirm that this device a real advantage for comfort
Re: Half Hard Top for My Three Wheeler - 07/09/20 08:03 AM
Re: Half Hard Top for My Three Wheeler - 07/09/20 08:07 AM
I have been driving for several months with my half Hard Top
It's very comfortable, especially with the temperatures starting to drop in the north of France
off put, a little vibration at a certain engine speed, I have no problem with this device ....
I'm not going to paint it yet, to keep making adjustments if necessary ....
Re: Half Hard Top for My Three Wheeler - 07/09/20 09:48 AM
Did you roll the edge of that hard tonneau? I sure like the look as is, in polished alu.
