Fitting Lucas Beehive Lamps - any tips?
Posted By: Edwin
Fitting Lucas Beehive Lamps - any tips? - 21/01/22 04:49 PM
I removed all the hardware on my 65 Plus 4 for a respray. She's back from the paint shop and now I'm putting her back together. I have found that the Beehive lamps are a nightmare to install. You have to fiddle with the rubber to catch the chrome ring. Is there some special tool or technique that would make this a more pleasant task?
Posted By: Jack & Jill 602
Re: Fitting Lucas Beehive Lamps - any tips? - 21/01/22 05:28 PM
Might have your rubber housings gone hard with age?
Posted By: Arwyn Williams
Re: Fitting Lucas Beehive Lamps - any tips? - 21/01/22 08:05 PM
Special tool? Yep, one of those wooden stirrers you get in coffee shops, about 6mm across with a radiused end.
Absolutely perfect for teasing the chrome ring into the rubber
Arwyn
Posted By: RichardV6
Re: Fitting Lucas Beehive Lamps - any tips? - 22/01/22 08:20 AM
Would warming the rubber first with a hairdryer help [Linked Image]
Posted By: John V6
Re: Fitting Lucas Beehive Lamps - any tips? - 22/01/22 09:54 AM
Or in hot water & lubricate with washing up liquid
Posted By: Edwin
Re: Fitting Lucas Beehive Lamps - any tips? - 22/01/22 03:55 PM
I did purchase all new rubber (everywhere possible) to replace the original ones.
I've got 3 out of 4 installed, with the last one refusing to cooperate.
Posted By: CooperMan
Re: Fitting Lucas Beehive Lamps - any tips? - 22/01/22 04:52 PM
Bit of beeswax furniture polish to act as a rubber lube will help
Re: Fitting Lucas Beehive Lamps - any tips? - 22/01/22 11:02 PM
Have you tried the final chrome ring in one of the other rubber housings to determine where the fault is?
If these are new chrome rings try one of the original ones.
Posted By: Edwin
Re: Fitting Lucas Beehive Lamps - any tips? - 16/02/22 12:07 AM
Using a heat gun made the job quite easy. Still required some fiddling, but it no longer felt like the parts were fighting me.
© 2023 Talk Morgan - Morgan Sports Car Discussion Forum, Community and News
