Failed Smiths oil pressure gauge
Posted By: Felix42
Failed Smiths oil pressure gauge - 08/06/19 01:07 PM
The oil pressure gauge on my Roadster has stopped working. Seems an odd thing to happen. Anyone else had this experience?
Posted By: Felix42
Re: Failed Smiths oil pressure gauge - 08/06/19 01:34 PM
PS: Berrybrook say it is the gauge and not the sender or wiring etc
Posted By: John V6
Re: Failed Smiths oil pressure gauge - 08/06/19 04:16 PM
No but my fuel gauge has a life of it's own.
Posted By: CBY
Re: Failed Smiths oil pressure gauge - 09/06/19 08:07 AM
Hi,
Have a look to :
http://www.talkmorgan.com/ubbthreads.php/topics/189255/Re:_Oil_Pressures_Query#Post189255
Posted By: Felix42
Re: Failed Smiths oil pressure gauge - 09/06/19 10:19 AM
Very useful - thanks CBY.
Posted By: sospan
Re: Failed Smiths oil pressure gauge - 09/06/19 10:32 AM
Try Caerbont. They took over when Smiths closed the factory in Ystradgynlais.
www.caiguage.com
Posted By: Lowflyer
Re: Failed Smiths oil pressure gauge - 09/06/19 12:11 PM
I assumme that its one of those small gauges that is part of the 3 gauge set up as my 2011 plus 4.
The range of that gauge is 0 to 7Barg, the gauge requires a field resistance range of 10 ohms at 0 Barg to 180 ohms at 7Barg. If you have a suitable potentiometer you can substitute it in place of the pressure transmitter and vary the gauge reading, just connect one end to the spade you pull of the transmitter and one end to engine block (or suitable earth point). You will need a decent multimeter to read resistance.
Regarding the transmitter, ian at Caerbont told me that i required thier model number PTR - 3000 - BN - 10, the 10 indicating that it was 100PSIG transmitter (7 Barg in thier books!). I'm on my second one of these 7 barg transmitters and both have proved inaccurate by approx 1.0 barg at 4 to 5 barg, giving a reading of approx 6 to 6.5 barg which my engine does not kick out.
In furtherance to the above i ordered a transmitter from williams morgan and was sent a 4000 BN 160 which is a 160Psig transmitter. A conversation with Ian again revealed that Morgan always specify this transmitter, ie, the incorrect range for the gauge! However, it appears that the accracy of the 7Barg transmitter is questionable anyway, i tested against a small new bourden tube type gauge which i would assumme was more accurate than the electric transmitter and gauge set up that's on the car. Im not looking for National Physics Lab standards from this kit but would have thought that 5 to 10% accuracy was possible. My latest transmitter would appear to be reading around 25% high.
Posted By: tom+4
Re: Failed Smiths oil pressure gauge - 10/06/19 06:37 AM
© 2020 Talk Morgan - Morgan Sports Car Discussion Forum, Community and News
