2006 Roadster Exhaust flange gasket
Posted By: John V6
2006 Roadster Exhaust flange gasket - 01/11/19 04:25 PM
My Roadster exhaust has a blow on the drivers side where the manifold meets the cat. This is a triangular gasket.
The MMC parts book has it as part MX1309 Ex flange gasket.
None of the usual suspects stock it but it looks like a common item fitted to many vehicles.
Does anyone have a spec for it?
Posted By: Heinz
Re: 2006 Roadster Exhaust flange gasket - 01/11/19 04:59 PM
I wrote this in the „any known issues 3.7“ thread:
„It's been 12.5 years since I had given up the series 1 Roadster, so the exact memory has faded a bit. But there is a connection with a flange gasket. Either it was between the manifold and the catalytic converter or behind the catalytic converter I can't remember exactly. This gasket (on both sides) never lasted longer than 4000 km. You can hear it immediately when it blows and the performance is significantly lower.“
Meanwhile I am pretty sure it was the same gasket as you describe John. I do not know a parts number but it could be worth to think about a stronger replacement gasket which a exhaust maker could perhaps cut to the right dimensions, or if different suppliers are there to chose the strongest offer. This gasket is a weak point.
Posted By: John V6
Re: 2006 Roadster Exhaust flange gasket - 01/11/19 05:48 PM
Heinz,
this went at 44,500 miles. I never heard of other failures.
Posted By: CooperMan
Re: 2006 Roadster Exhaust flange gasket - 01/11/19 05:50 PM
Never had one let go in 50k miles on an S1, so for me that's reliable
John, I think Brands Hatch had them in stock for a fellow S2 owner last year
Posted By: flyfisher
Re: 2006 Roadster Exhaust flange gasket - 01/11/19 06:08 PM
This went on my Dads Series 1, Simon at Sifab had them in stock if not it was from Revolutions in Perth
Posted By: SimonH
Re: 2006 Roadster Exhaust flange gasket - 01/11/19 10:36 PM
The gaskets are rubbish, I gave up in the end on the Roadster Lightweights as I was changing so many and glued the flanges with High Temperature Silicone...
Simon @ Sifab.co.uk
Posted By: Heinz
Re: 2006 Roadster Exhaust flange gasket - 01/11/19 10:54 PM
At that time I drove the Roadster very sporty. I was 14 years younger than now. Actually, I always demanded full power because it was a lot of fun. And on the motorway I liked to drive 190 km/h over a longer period of time, in dry conditions and without traffic. Mostly the gaskets got broken when I went in second gear to highest rpm. It can be that other experiences are more positive as described above in the posts. I always had trouble with these seals.
Posted By: BertR
Re: 2006 Roadster Exhaust flange gasket - 02/11/19 02:26 PM
Heinz, I share with you the joy of driving the Roadster at high speed, it is an adventure. I recall driving Munchen to Amsterdam couple of years ago. Earplugs are a must, what a noise!
Posted By: Heinz
Re: 2006 Roadster Exhaust flange gasket - 02/11/19 03:35 PM
Yes I used ear plugs as well at that time when driving so fast, Bert. And I trusted the aluminum 5 bolt wheels. I am not sure if I would drive so fast with centre lock spoke wheels.
© 2020 Talk Morgan - Morgan Sports Car Discussion Forum, Community and News
