3 registered (Heinz, Andrew Kidney, MarioCP), 21 Guests and 11 Spiders online.
M3W Tour of New Zealand 2019
Concept Royal Enfield V Twin
Go Outdoors
Morgan 3 wheeler oil cooler
Show us your Bike
Recommended engine oil for a 4/4 engine 1.6 TI VCT
by Heinz
19/03/19 01:52 AM
One Shot Oiler
by britmog
18/03/19 11:32 PM
Finally coming for you
by Bourbonmog
18/03/19 11:23 PM
Continuously asked, Is it Real or a Kit?
by PocketRocket
18/03/19 08:31 PM
Essential Three Wheeler tool kit
by LightSpeed
18/03/19 08:26 PM
Krazy Horse Stage 1 or 2 Exhaust Noise - Advice
by Black Adder
18/03/19 06:44 PM
Bus Gate
by N22MOG
18/03/19 06:00 PM
Jabax4, UTE, robert l, RogerU, GIB
6422 Registered Users
6,422 Registered Members
33 Forums
34,559 Topics
Most users ever online: 341 @ 11/02/18 10:30 PM
gazum
Page 2 of 2 < 1 2
#553519 - 13/01/19 04:37 AM Re: M3W - Harley [Re: nippymog]
Knucklefreak Offline
Regarding using a Harley engine, they are not a direct replacement for the S&S X-wedge. The engine mounting bolts are larger and are spread wider on the S&S motor. Of course mounting plates could be fabricated to adapt the Harley motor and align it with the Morgan drive components.
Using other S&S motors except X-wedges would run into the same problem as they are made to fit Harley mounts. Also, a number of them are for older bikes and are not emissions compliant, but the newer motors might pass emissions.
I always thought the S&S Knucklehead motor would look good on a Morgan but it is not compliant.
#553782 - 14/01/19 02:16 PM Re: M3W - Harley [Re: Knucklefreak]
Dan_Lockwood Offline
Loc: O'Fallon, Missouri USA
Correct, the engine mounting is different. The S&S Wedge motor is designed with vertical mounting in four places, and more typically used in a solid bolt to the frame mounting. They are also a "standalone" motor. That means, unlike the Harley, they do not have any mounting for a transmission as used in a bike application. They use the "old EVO" style separate motor/trans with the side primary doing the alignment and the both units are frame mounted after the primary case has been bolted to both motor/trans for alignment.
Also the S&S Wedge uses Harley's pre-'06 primary side mounting, four bolts versus five bolts. So the Morgan motor to trans adapter will NOT bolt up to '07/later Harley "B" motors. The "B" motor starting in '99 was fully counterbalance with a front and rear counterbalance shaft driven via chain off the cam side of the crank. This allowed the "B" motor to be solid mounted to the bike main frame, sans the "A" non-counterbalanced motor's rubber mounting system for all touring bikes. The "B" motor is ONLY used in Softail frames.
So the motor in the ACE is an '06/pre "B" motor. Harley does offer an '06/pre 120R version of the "B" motor, which is what we've been looking at in all the posted pictures. This motor lists in the $8k range with street pricing in the $6.5k range.
With the "B" motor you can very easily run the S&S Super series carb so you do away with the EFI and whatever troubles that may bring. Thunderheart offers a standalone ignition system that hooks directly up the crank sensor next the alternator plug in the front of the motor, or left rear side of the S&S Wedge. It can be programmed via several preset profiles, or tuned if needed. The Thunderheart runs in the $300 range and then the carb is probably in the $500 range for their carb kit with AC and manifold.
Someone here has converted their M3W to a carb, can't remember off the top of my head though. I remember that it ran well also.
With a carb and standalone ignition, most of the irritating ECM and tune issues go away.
I've ridden several "B" powered Harleys. Most at a stoplight don't vibrate at all. You know they're running because of the loud exhaust. smile They are VERY smooth.
In the realm of the of the 120R motors, they are very highly rated by CVO guys that have swapped out their CVO FL series touring bike 110" "A" motors to the 120R "A" motors. They put out to the rear wheel well over 120hp and equal to that or more in torque.
I think if someone had a S&S failure and was handy with the welder and plate cutting, the 120R would be a great motor for the M3W. But alas, that would take away from the "stock" nature of the M3W. Kind of like putting a SBC in a Mustang, blasphemy to some. Of course exhaust would be an issue, but not out of the question. Especially with several of the M3W members making, or having made, complete new exhaust system for the S&S motors.
Sorry for rambling again guys... smile
Dan
Dan's Car - Bike - Projects Photo Albums
#553803 - 14/01/19 04:35 PM Re: M3W - Harley [Re: Gambalunga]
Glad someone with more knowledge expanded my post. I suspected there would be problems with the drive but didn't know for sure. Still think a 103" Accurate Machine knucklehead would look good up there.
#553838 - 14/01/19 07:53 PM Re: M3W - Harley [Re: Knucklefreak]
In that case, the Knucklehead would bolt right into the S&S mounts as they used the same throughout '36 thru '98, at least for the solid mounted motors. I think in '84 they went to a rubber mounting setup for the motor/trans on the FL series. But the crankcase mounting might still be the same.
I don't go quite that old, but my '76 Shovelhead still has the same mounting bolt pattern as all the rest and the S&S Wedge. A Knucklehead would bolt right into my frame.
I saw some pictures of an older Morgan or maybe a clone that had a Shovelhead in it. I've got pics someplace I'll post later.
Dan
#553881 - 15/01/19 12:00 AM Re: M3W - Harley [Re: Dan_Lockwood]
Earlier motors and later motors will fit in the Shovel but the X-wedge won't without serious rework of the frame. You have to completely rework motor mounts and modify the frame tubes because of the wider v angle on the x-wedge.
#553883 - 15/01/19 02:09 AM Re: M3W - Harley [Re: Knucklefreak]
I would expect that due to the 56 degree V instead of the 45 of the Harley. Also with the longer stroke the head would be a lot taller in the frame, but the mounting bolt pattern should close to the same.
Dan
Page 2 of 2 < 1 2
Moderator:  Aeroman
