7 registered members (+8Rich, planenut, SeptemberWarrior, twotribes, Old man, ChrisConvertible, KennethM), 120 guests, and 18 spiders.
+8Rich 273
John V6 169
15 months to the day...
by 3Gs. 21/08/19 07:34 PM
It’s Coming !
by sospan. 21/08/19 03:33 PM
Another M3W Exhaust Supplier
by Rog G. 21/08/19 03:12 PM
BHM Plus 6 Test Drive
by RBW. 21/08/19 01:44 PM
A real Porker
by +8Rich. 21/08/19 01:22 PM
Oil leak
by ADM3W. 21/08/19 12:51 PM
"SPORTY" exhaust note ...
by dmh. 21/08/19 12:21 PM
My Morgan related badges
North Coast 500
4/4 visiting the lighthouse at Närsholmen
My 65 Plus 4 Four Seater won a trophy
1978 450SL
Graeme1950, Trev55, Slacker, RogerT, tigertom
6640 Registered Users
Forums33
Topics35,930
Posts580,131
Members6,640
Most Online459
Aug 3rd, 2019
kingsley mkh
Page 9 of 9 1 2 3 4 5 6 7 8 9
Re: These models don't come to market too often. [Re: +8Rich] #559862
14/02/19 11:02 PM
14/02/19 11:02 PM
Llanelli
Ray Offline
Ray  Offline
Llanelli
The 1.8 duratec is rated at 125 bhp. On paper!
Re: These models don't come to market too often. [Re: +8Rich] #559903
15/02/19 09:43 AM
15/02/19 09:43 AM
I
IcePack Offline
IcePack  Offline
I
Thank you Salmo. Very interesting. I have to admit on my car 1 st is quite a challenge as when really trying you get to 6000 rpm what feels like almost instantly. The other gears are fine, giving a lively performance. 5th is useable at 40mph and at 70mph indicates only an extra 300 rpm from the original 3.73 diff. The car is also shod with 275/70/R15 which I guess make a small difference too.
Imho just goes to show how each car can be made to suit the driver. All part of the fun of ownership.
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: These models don't come to market too often. [Re: +8Rich] #560009
15/02/19 05:03 PM
15/02/19 05:03 PM
cerealsurfer Offline
The main difference is that the Ford box was designed for the transit... hence very low ratio first and second... once your into third things begin to even up as most gearboxes have a 1:1 4th.
The Mazda box was designed for the Mx5 - something much closer to the Morgan so unsurprisingly they have a higher 1st and 2nd ratio’s.
That said - both the MX5 and certainly the transit are heavier and the Morgan’s life is likely to have a lower duty cycle of cruising... so the 3.xx rear diff’s are used to in part fix the imperfect ratio issues you have with mainstream gearboxes designed for cars with different weight/usage/torque characteristics.
Re: These models don't come to market too often. [Re: +8Rich] #560015
15/02/19 05:09 PM
15/02/19 05:09 PM
The 2.2:1 1st gear ratio of my 72 4/4 which uses a Quaife QBE15Z gearbox is ideal for the 2lt Zetec it has combined with the 4.1 rear diff. The closer ratio’s i’ve Selected allow much better use of the engine curves either driving at the top end or on the torque curve.
The 2.03:1 and 4.1 diff of my 275bhp 2lt Zetec requires a considerably more aggressive start that makes most people cry in sympathy.... but it does 60+ in first and gets there very very quickly!!
Re: These models don't come to market too often. [Re: +8Rich] #560311
16/02/19 08:59 PM
16/02/19 08:59 PM
Cologne, Germany
Heinz Offline
Heinz  Offline
Cologne, Germany
Today was the second day in wonderful weather I drove the nice Eifel area B-roads. Yes, the Mazda gear ratios are fine. But...the axle ratio would be better if it is shorter, 3.9 or 4.1.
And the 5th still would have enough reserve not being too short when driving a motorway.
I wrote that 2 years agor Techniques and Williams told me that I cannot chage the diff concerning the BTR axle but I must buy a whole axle which is too expensive for the fun of it. Does someone have new infos, is it possible in the meantime to change the diff only?
Now, if anyone says, why don't you just downshift to get higher revs? It's not the same thing.
With the shorter rear axle ratio, the lever and thus the added torque is in each gear equally effective and that at all revs.
The fact that the Mazda transmission has the small gears "longer" is all the more advantageous with a shorter rear axle ratio.
Moderated by  Aeroman, Simon
