11 registered (Andy1952, rickmazer, Allen, jbk, DJC, DocNik, Mi3Wheeler, Alan Patterson, Max5, tmg513, Michael H), 10 Guests and 10 Spiders online.
LATEST PAINTING PHOTOS - CHUNKY 4/4'S RACING CAR
Little and Large
Grand Day Out
Mog meets Mog
National Motor Heritage Day
Aero Racing 5" driving lamps
by nputtick
22/05/13 02:12 PM
Roadster dashboard
by stumog
22/05/13 11:06 AM
Morgan Aero 8 on a Ferry!
by TheCoot
22/05/13 09:30 AM
Yah - they posted it on-line
by Alistair
22/05/13 08:25 AM
Daft Garage
by Clipper
22/05/13 07:44 AM
Adjusting +8 Tming
by AJSki2fly
22/05/13 07:38 AM
Top Gear Verdict
by Mi3Wheeler
21/05/13 08:04 PM
fathergoose, HMSMotorsport, tide, Dk Super Dry 3W, Dr John
2870 Registered Users
2870 Members
51 Forums
11046 Topics
Page 3 of 3 < 1 2 3
#95745 - 17/06/12 12:14 PM Re: Screen Frame & Sidescreen 'Weatherproofing'. [Re: S Marsh]
shiremog Offline
Loc: North Essex
I had quite a bad leak on my 2005 Roadster at the top of the screen. I discovered that it was coming in at the top of the screen pillars. I did a similar fix to Dave's, but found it still leaked, although a lot less. I finally tracked the last bit down to the gap between the header rail & the bracket, where the weld stopped short of the end. A piece of insulating tape wrapped around the joint proved the cure & a lasting job was done by running a bead of hot-melt glue down the join. No more leaks for 5 years or more.
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
#95752 - 17/06/12 01:07 PM Re: Screen Frame & Sidescreen 'Weatherproofing'. [Re: shiremog]
Gambalunga Offline
Loc: Mandello del Lario, Lake Como,...
Nearly 5,000 km and so far our Morgan has only seen a couple of very light showers, barely enough to get the car wet. No water in the car when I have washed it but that is not the same as being on the road.
Having read all the threads about water entering the car I am a bit nervous about our first encounter with real rain.
Plus 4, Sport White (Ivory) Mulberry trim
#95754 - 17/06/12 01:18 PM Re: Screen Frame & Sidescreen 'Weatherproofing'. [Re: Gambalunga]
Richard - Aus Offline
Loc: Perth, WA, Australia
This is the problem with all such forums we all get paraniod about things that may or may not effect us.....just my view. Look at it this way - if you read this forum from start to finish other than the passion for ownership - you would not own a Morgan for fear of king pins, rain, creaking springs etc.....now the truth is something else.
...I'll go and put my soap box away now.
#95757 - 17/06/12 04:37 PM Re: Screen Frame & Sidescreen 'Weatherproofing'. [Re: Richard - Aus]
Gambalunga Offline
Oh I agree Richard. Worth adding that it seems with a Morgan if there is a problem you just fix it, at least that is what most people seem to do.
I find that water that can accumulate in the channel for the sliding window and is a a bit annoying. I am thinking of drilling a small hole in the front corner, where it seems to accumulate, to let it run out.
#95784 - 18/06/12 02:05 AM Re: Screen Frame & Sidescreen 'Weatherproofing'. [Re: Gambalunga]
Or as GoMog puts it....
The correct approach to a Morgan mirrors the correct approach to life. Enjoy it, don't fret about it and be confident that, whatever happens, you can fix it.
#95791 - 18/06/12 07:01 AM Re: Screen Frame & Sidescreen 'Weatherproofing'. [Re: Gambalunga]
Easter Offline
I recently spent a day driving across Northern France in the rain and kept a bar towel handy for the inevitable leaks, a lot depends on speed and wind direction. Drilling a hole in the side screen frame would be considered a modification to your Morgan and void your warranty.... smirk2
#95804 - 18/06/12 08:07 AM Re: Screen Frame & Sidescreen 'Weatherproofing'. [Re: Easter]
Robbie Offline
Loc: Co Wexford, Ireland
"Drilling a hole in the side screen frame would be considered a modification to your Morgan and void your warranty.... smirk2"
Careful ....."Sir" may take you to task!!!!!! grin2 happy3
Robbie
Plus4 Aston Martin Mendip Blue
09-WX-2269
"Lord Plus Faw of Kilgibbon"
#95852 - 18/06/12 03:58 PM Re: Screen Frame & Sidescreen 'Weatherproofing'. [Re: Easter]
Gambalunga Offline
I went to examine the car today and I think filling the slot with an extrusion is the best bet. I will also get some neoprene to fill the gap at the top of the windscreen pillar.
#95888 - 18/06/12 07:29 PM Re: Screen Frame & Sidescreen 'Weatherproofing'. [Re: Gambalunga]
Paul F Offline
Loc: Costock, UK
Every Morgan owner needs to know where his towel is - at all times.
(with due deference to Douglas Adams)
Costock, UK
1985 4/4
Disco 3
Page 3 of 3 < 1 2 3
